Question about QVS NetStar (UPS650A) UPS System
My PC is geting switch off when Power flatcutations come,even ups is connected and no back up comes from UPS, after that UPS takes >4 seconds to switch to mains supply.
  • 5,603 Answers
A four second transfer time is way too long by at least an order of magnitude. There is no way the power supply in a PC can maintain for that long a time.
If you are in a real critical environment I would recommend going to a UPS which runs continuously and runs off a battery which is charged whenever utility power is available. That way there is no transfer time.
These offline units are harder to find however.
I suspect your UPS system is defective.
Posted on Apr 26, 2010
  • vs2391 Aug 08, 2011
    my ups is not providing any power even if main power is on. Can anybody plz tell me where does i have to check for the faults very first
@MY APC UPS SURT15KRMXLI is not charging after installation on single phase input
we have installed a new ups but the battery light indicates red light even though its on charge
Aug 12, 2011 | APC SMARTUPS RT 15KVA RM 230V...
My UPS burnt due to short circuit in main line. After that the UPS don't give back-up even for second. After recharging the battery and connected to the UPS, the UPS don't give power at the output from...
if there was a short circuit, chances are that its toast. get a new one. DON'T ATTEMPT TO OPEN IT YOURSELF. THESE THINGS STORE POWER SO YOU CAN BE ELECTROCUTED EVEN IF YOU UNPLUG IT.
Feb 02, 2011 | Computers & Internet
My UPS does not start
I'm guessing that during the power outage, the ups battery completely discharged. Now it will take about 14-15hrs to recharge it.It will not support any devices until it is fully charged. Remove all load devices and let the battery restore to full charge before re-connecting the devices. If the battery does not recover, it needs to be replaced.
Apr 16, 2010 | APC MasterSwitch Power Receptacle - Power...
The unit beeps
I am getting these directly from the user manual (available here: http://www.apcmedia.com/salestools/ASTE-6Z7VAQ_R3_EN.pdf)
Issue: On Battery - UPS is supplying battery power to the load connected to the Battery outlets.
Visual Indication: Power On LED - ON (off during beep)
Audible Indication: Beeping 4 times every 30 seconds
Stops When: UPS transfers back to Power On operation, or when UPS is turned off.
- OR -
Issue: Sleep Mode - During On Battery operation the battery power has been completely exhausted and the UPS is waiting for utility
power to return to normal.
Visual Indication: None
Audible Indication: Beeping once every 4 seconds
Stops When: Utility power is restored, or if utility power is not
restored within 32 seconds, or the UPS is turned off.
All other issues are CONSTANT tones, which you did not specify, or there are no audible tones associated with it.
Apr 07, 2010 | APC Back-UPS ES 350 - UPS ( external ) -...
Had a power break, expected power to come back so
t_sleeswijkv, Your unit may need factory servicing. Could have been hit with a large overvoltage transient spike that may have damaged unit electronics. Give a call to APC or visit their website for more advice on best way to proceed. I hope it never happens to my APC 1250. I did a DIY replacement of 2 batteries in mine back in 2007 because one went bad. If your unit not covered by warranty open it and take pics of what stuff got burned-up or fried. let us know what you find. 12fixlouie on fixya
Mar 17, 2010 | APC Back-UPS Pro 1100 (BP1100) UPS System
No power
are there any LEDs illuminating near the switches? if no, this means that the ups is off. switch the ups on by pressing the ON button momentalily until the start of the second beep then release it. the ups will do a self test then it will stabilise after a few second. if it does not come ON, connect the ups to power then attempt to switch it on. if it comes ON then you have to check the integllity of the batteries. if it still does not give power then you have to call the APC service enginneer in your region .
Jan 20, 2010 | APC Smart-UPS 1000VA UPS System
After switching on the power supply, my pc takes around 3-4 minutes to start with APC UPS, earlier it was responding within half a minute
Have you taken it off the UPS and tried connected direct to an outlet.
Does it take the same amount of time?
If so you have a software or hardware conflict that is new and needs to be researched carefully.
try using the windows error log to see if there any startup errors.
Nov 26, 2009 | APC Back-UPS CS 500VA UPS System
How to charge ups for pc's
Your PC connection must always come via UPS, and your UPS will always keep charging.
UPS Power cable should be connected to DC, and your PC power cable should be connected to UPS.
And this way your PC will always be safe.
Nov 06, 2009 | QVS NetStar (UPS650A) UPS System
After a power outage my apc has this clicking sound. every 4 seconds or so it sounds like it clicks and then a slightly different click 4 seconds later. However, when everything is powered up it doesn't...
I found this on the APC website;
Question: What would cause a Back-UPS Pro, a Back-UPS Pro USB, a Back-UPS RS, a Back-UPS CS, a Back-UPS LS, or A Back-UPS XS to beep once every 5 seconds with no output power?
Answer: One beep every 5 seconds is an indication that the UPS has entered what is called "Low Voltage Sleepmode".
The Back-UPS product has transferred to battery power due to a low voltage condition at the wall. The Back-UPS has remained Onbattery until its runtime was totally exhausted, however, there was still enough voltage present at the wall to trickle charge the battery.
This is considered to be a normal operating state. When the voltage returns to normal the Back-UPS will wake up and restore power to the battery outlets.
Nov 02, 2009 | APC Back-UPS ES 350 - UPS ( external ) -...
When power it on nothing comes up. in front has light 1-4 and only 1 and 2 light up. I have had this problem with other when I plugged in to many usb connections and dell had me reset something on the...
Hi there.
They probably had you clear the CMOS jumper or take the motherboard battery out.
The CMOS jumper looks like this >>>>
It is the little piece of plastic next to the motherboard battery, if its there move the jumper to the other (on) position for 5 seconds.
If there is not a jumper there take the motherboard battery out for an hour making sure the power cord is removed from the back of the machine.
Please post back if you need anymore advice.
Good luck
Jun 04, 2009 | Dell OptiPlex GX620 PC Desktop
QVS NetStar (UPS650A) UPS System Logo
229 people viewed this question
Top QVS Computers & Internet Experts
Bill Boyd
Rani wadia
Rani wadia
Are you a QVS Computer and Internet Expert? Answer questions, earn points and help others
