Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Why is the side of my side by side is hot to the touch.It was moved from another house but was upright .It burn when I reach into it
  • 3 Answers
A heating element/hot gas line is placed around the doors to prevent condensation on the outside of the unit.
Posted on Apr 26, 2010
Our kirby generation 3 trips out when the rubber protection sides touch a wall or object
A hot wire is hitting the frame. Unplug it take your time and remove the housing around the motor and you will find the stripped wire. Cover it with GOOD electrical tape and you should be all set
Apr 27, 2016 | Kirby Generation 3 Bagged Upright Vacuum
Upright freezer trips circuit after moving across room
If compressor is hot, it could be an issue with the starting components. Let it cool down for about an hour an it is room temperature to the touch. If the breaker trips when the compressor attempts to start, I would look at the start components. It may be just a case of unusual timing that they went bad at this time. Make sure there is nothing else on the circuit you have it plugged into. Could be an overloading issue of the circuit.
Aug 04, 2017 | Refrigerators
Eureka whirlwind+
It's a little tricky but here's how you get to the belt:
  1. Once you have removed the housing and the roller, turn the vacuum so that you are facing the pin the turns.
  2. Pull the belt to the back of the unit with your right hand so that the belt is against the pin on the front side and with your left foot apply pressure to the carriage where the roller sits. This action causes the plastic housing next to the pin to move toward the front of the vacuum providing enough space to slide the belt off easily.
  3. Be careful that you do not apply too much pressure with the foot.
May 02, 2012 | Eureka Altima Upright Vacuum Model 2996AVS...
Arm blades not spinning.
Next time, you will remember to keep appliances upright during a move.
Sep 28, 2017 | KitchenAid 24 in. KUDM25SH Built-in...
I have a GE GMR04HASCS Compact Refrigerator.
Refrigerators do not react well to being carted around in any position but upright.
Oct 29, 2017 | GE GMR04HASCS Compact Top Freezer...
Freezer is hot on the sides is this normal?
Good day,
Yes, that is normal. It is ideal to not be in a hot room but as it reaches temperature and begins to cycle off and on it will become somewhat cooler.
Jul 20, 2010 | Frigidaire 11.6 cu. ft. / 328 liter...
My freezers compressor is getting very hot and the freezer is not freezing
Fridgidaire Upright Freezer appears that the compressor is getting hot enough to burn ( serious discoloration) the linoleum below the freezer.
The compressor is hot to the touch.
Freezer is working just fine.
What to do?
May 15, 2010 | Frigidaire FRS26R4A Side by Side...
Motor housing is hot
This model has 2 side filters, check and clean those. Be aware that this is a quick clean vac, not to be used for extended periods of time to replace a full size upright. clean the inside filter in the dirt cup.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Apr 16, 2010 | Hoover S2220 Flair Bagless Upright Vacuum
Top of Dryer getting scalding hot
hi there try drying a load without your house ducting.if its restricted at all this cause the heat to not leave the dryer a designed by manufacture and their for get hotter.can be other things but thats most common.ps should have good air flow leaving dryer when vent off.but because fine at house just moved from i think new house is the problem.God bless ,tom
Jan 05, 2009 | Dryers
Burned out headlight/bulb bmw 1991 325i 2dr
It's a bulb replacement. If it's anything similar to my Audi, there is a cover on the back of the headlight housing that you pop off. Then you can reach in, pull the wire connector off the bulb, and unclip a metal retainer over the bulb, and pull the bulb out. Installation of the new one is the reverse. Just be SURE not to touch the glass part of the bulb. Skin oils can cause a halogen bulb to burn very hot and burn out very quickly. If you do touch the glass, wipe it gently but thoroughly on a cotton cloth to clean it off before you install it.
Oct 31, 2008 | 1991 BMW 3 Series
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
88 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
