Question about Dell E173FP 17" LCD Flat Panel Monitor
When i turn on the monitor, no picture--just blinking lights
    President:
  • 1,561 Answers
Have you check all connection to see if they are right, check if no cable was unplug, if you have and yet no picture display, It could be that the picture board on your monitor has started malfunctioning, since the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Posted on Apr 26, 2010
Testimonial: "Prompt response."
I have not picture.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Jan 23, 2016 | Televison & Video
Slim and secure blinking green light
Same problem here... Blinking green light. Purchased new battery and is still doing the same thing. Very disappointed-these cameras are not cheap. :(
Mar 10, 2012 | Summer Infant Slim Secure Handheld Video...
No picture screen black
un plug the monitor cables power cord everything turn off the computer the reconnect everything power back up turn on the monitor should work then
Feb 06, 2010 | Dell E173FP 17" LCD Monitor
After hibernate mode monitor blinks on and off. The monitor is on power is being feed to monitor however if you turn the power button on and then off the picture on the screen will blink on and then off
If it is your computer that is in hibernation then blinking on the monitor light is normal
Just bring your computer out of hibernation and the screen will come back to life too
Aug 22, 2009 | Dell Computers & Internet
Why f257 turns on no picture light blinking?
Sounds like you have a video card issues..Also try turning off Monitor first, then shutdown PC. Then Turn monitor back on first then PC..It should sync up...
May 18, 2009 | Computers & Internet
Green Power light blinking
Check the resolution in the Windows while connected to the old monitor. If greater than 1280 X 1024 and/or the refresh rate exceeds 75 Hz, the monitor may not respond. But you should at least see the BIOS splash when the computer is turned on. If that does not appear, maybe a problem has occurred in the monitor. Another indicator: if you turn the monitor power button off and then back on, you should get some sign of life such as "no signal", or "out of range". If nothing appears, that would indicate some problem within the monitor.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Jan 04, 2009 | AOpen F70PS 17" Flat Panel LCD Monitor
ACER AL1715 PowerLed blinking only,no picture,flash about .5secs
This sounds as if you are using the hibernate feature in windows reboot it and reset the power options to hibernate never check the vid connection as well
Dec 19, 2008 | Acer AL1715 17" LCD Monitor
Mag Innovision 765S power supply light blinks and monitor power led blinks and no picture
I'd suggest looking at the mainboard. I assume the blink is rapid? A slow on, followed by a short off and back on again is normal. The fast blink thing is a mainboard issue, and the absence of blink (or light) is power "supply dead."
There is a problem transistor on the mainboard that seems to be the problem most of the time. Replacing it takes about 5 minutes if you have the tools and the talent, and the parts cost under 3 bucks at Radio Shack. Just pick up a pack of NPN switching transistors and de-solder / solder your way to a working monitor. There's usually only one on the board, so it's easy to spot.
Nov 18, 2007 | Mag Innovision InnoVision LT 765S 17" Flat...
Nokia monitor doesn't work
Have you tried another monitor connected to the same computer? A blinking light usually means it's receiving no signal from the PC.
Aug 23, 2007 | Nokia 445 Pro 21" CRT Monitor
Dell E173FP 17" LCD Flat Panel Monitor Logo
348 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
