Question about Smeg A2.2 Gas Kitchen Range
Oven on Smeg A42-2 cut out and is not working it is six years old , it had a new element fitted in 2008
    Habit-Forming:
  • 193 Answers
May be thermostat or control card
Posted on Apr 26, 2010
Fitting heat element sa410x
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Feb 11, 2012 | Smeg Ovens
Hi, we have a se280x oven and its about 4-5 years old and inherited this when we moved in 2 years ago. But the oven seems to heat sometimes or not constantly and especially seems like e the upper and...
Apr 15, 2011 | Smeg SE280X Stainless Steel Electric...
How to fit a fan element for a smeg se335ss-5 oven
Jan 31, 2011 | Smeg SC712U Oven
Smeg cucina SE375 single electric oven not heating-grill and lights etc working ok and fan making noise-oven approx 18 months old
Jan 14, 2011 | Smeg Ovens
Smeg suk91mfx shelves not fitting anymore on oven.
buy a pack of 2 oven shelf guards from lakeland 10.99. cut them in half and slide onto the ends of the 2 shelves. works perfectly.
Nov 18, 2009 | Smeg SUK91MFX5 Dual Fuel (Electric and...
My oven is not heating up. It is 11 years old, smeg S>P>A> 42016 GUASTALLA
check your element with a continuty meter and your cut out stats
Sep 30, 2009 | Kitchen Ranges
It would appear that the main oven element is not working. I had a power cut whilst using the oven recently and have only just realised that the oven will not heat up. Everything else is working ok. If it...
If it is a fan forced oven, the element is round in shape and goes around the fan blade on the back wall of oven.
To replace: Turn off power!!
-Remove side racks from oven, then remove rear panel.
-You should now see fan blade and fan element.
-You need to remove oven from cavity, then remove rear outer panel.
-You can now access element- it will be held in place by 2 small nuts either side of element wiring connections. Disconnect element wires, unscrew nuts. Element is now removed!
Reverse procedure to reassemble and test. If oven is heating OK, also check main oven thermostat is regulating temperature (ie clicks on and off), as sometimes thermostat can fail if element has blown
Aug 10, 2009 | Smeg Ovens
SMEG DO4SS-5 double oven not heating up
If the fan is running, then it is safe to say that the oven element has gone.
Replace with a new one,(element that is).,
Plz rate this solution.
Thanks.
Dec 15, 2008 | Smeg Ovens
Smeg oven
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Dec 08, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Smeg A2.2 Gas Kitchen Range Logo
290 people viewed this question
Top Smeg Kitchen Ranges Experts
Richard Ballard
Richard Ballard
Level 1 Expert
Joseph Mueller
Joseph Mueller
ashburton
Are you a Smeg Kitchen Range Expert? Answer questions, earn points and help others
