Question about Emerson EWV601 S-VHS VCR
Emerson vcr won't accept a tape
My emerson VCR won't accept a tape. I could try to force it in the machine, but the machine won't accept the tape down inside of the maching...can this be fixed?
  • Anonymous Apr 12, 2009
    wont allow tape to go all the way in
    Scholar:
  • 110 Answers
Yes, it can be fixed, but the cost may not be worth it.
There are several components which may be the problem, ranging from a gear, a sensor, the load motor, or it may even require replacement of the entire cassette loading assembly.
Without an inspection, it's impossible to tell exactly what the problem is, or likely cost to repair.
It may be much cheaper to replace the machine.
Posted on Mar 24, 2008
VCR won't record, just ejects tape
You have not mentioned the make and model number of the vcr. Any way the problem is due to end sensor or related circuit. End sensors are photo diods which you can check the shorting with a multy meter.
Jan 13, 2013 | Emerson Televison & Video
VCR making noise and won't take tapes
THE VCR SECTION WILL NEED LUBICATING INSIDE THE TV WOULD OF DRIED THIS OUT DUE TO THE HEAT FROM THE TV OVER TIME.THERE IS A LOT OF MOVING PARTS IN A VCR A MUST ALL WORK TOGETHER.
Apr 24, 2010 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
How to repair Panasonic VCR Combo PV-D4742 which flutters at playback. DVD unit works fine.
your videoplayer(vhs) heads are dirty, use a vhs cleaning tape, buy from your local music store, or ask them where to get one, or your the videotapes you are using are worn, try other newer less used tapes if they work fine then the tapes your trying to play are worn, otherwise dirty play heads are the problem.
Jul 01, 2009 | Emerson EWD2203 DVD Player/VCR
VCR won't accept new recording tape
I asked earlyer but i can't find my questin that was submitted earler today i gave you my email address with no results. I want to know where the nearest tv vcr reparemand is to Spencer okla my email is davidcurle@sbcglobal.net and my phone No.is 580-782-2888 My mother is moving to Spincer Okla. and needs her vcr forward and reverse fixed,in her emerson tv/vcr combo
Apr 02, 2008 | Emerson EWC1902 19 in. TV/VCR Combo
Emerson ewd2203 video/dvd combo
Do you know why the tape was stuck? How did you get it out? On most vcr's there's a mode switch connected to the mechanics of the vcr. If the mode switch isn't in stop position, the unit will try to get it there and shut off if it can't. Bad belts, bad idler wheel, dirty mode switch, mechanical timing off (maybe due to forcing a stuck tape out?)... all these can cause this.
Geno
Feb 27, 2008 | Emerson EWD2203 DVD Player/VCR
Vcr will not accept video tape
A common problem on this unit is the Mode Switch. It gets dirty or sometimes breaks and must be replaced - definitely not a job for the unexperienced. If you mess up just a tiny bit, especially during re-assembly, your VCR unit will never work right ! Sorry for the bad news.
Jan 31, 2008 | Emerson EWC1303 13 in. TV/VCR Combo
What do I do when my Emerson TV keeps turning off by itself?
I had the same problem with mine turning off after 3-5 seconds. After much research I found a suggestion that on some combo units the vcr part could have a power supply cutout if it is not working correctly. I tried to insert a tape and found that the tape mechanism would not accept a tape. I used a little bit of force and managed to insert a tape. I then played the tape forwards and backwards and the power stayed on! I ejected the tape and found the TV then worked just fine. The power has now been on for over one hour. I hope this give you another avenue to try and fix your problem.
Nov 30, 2007 | Televison & Video
Emerson vcr #vcr755
have you tryed to clean the ace head??? The ace head means audio-control-erase. and is on the right side of the mechanism. this head looks like a big cassette type head and is statioary. This head can be cleaned just like an 8-track{remember those??}or cassette head by applying rubbing alcohol to a q-tip and clean the head from top to bottom. this head also may need cleaning if your tapes seem to speed up and slow down for no reason and at random. Thats because the lower part of the head is the control head and that gives the machine pulses to tell the machine what speed the tape is recorded in then the capstain motor has an fg sensor(freqency generator} and they all go thru a comparitor and the sum of both pulses gives the machine the proper speed setting. Hope this was laid out in understandable english. Good Luck
Apr 26, 2006 | Emerson EWV403 VHS VCR
Emerson EWV601 S-VHS VCR Logo
390 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
