Question about Toys
Yiboo apache won't take off anymore. Changed blades and charged for over an hour. Blades spin but no lift.
  • olsonparkcit Apr 26, 2010
    Didn't help. Still won't lift and body of helicopter spins clockwise.
    Yiboo ah-64 apache rc helicopter 3 channel. Won't take off and body spins clockwise. Changed blades and charged. tried tightening shaft as per instructions by other tech.
  • 12,061 Answers
Hi, this usually happens due to one of the counter rotating rotors, isn't rotating, at all, or properly, check that out. What gives it away, is the helicopter is turning, this can only happen, if It's a normal helicopter, with a tail Rotor, and it rotates, then it's the tail rotor. If in a counter rotating rotors, then one of the rotors isn't working correctly.
Posted on Apr 26, 2010
  • 2,069 Answers
Check, there is a small set screw on the bottom gear that holds in the upper shaft. You can see these gears through the belly of the helicopter go in and re-insert the rotor shaft and tighten the set screw. applly locktite to the threads to prevent it from backing out.
Sky rover won't lift off
er ericI know it sounds daft but the possibility of the blades spinning
the wrong the motor battery either charged the wrong way by mistake or connected the wrong way round its the only thing that comes to mind I've done it
Dec 12, 2017 | Washing Machines
I replaced the blades on my copter but it. Won't hover I changed all the blades and it just sets on the floor and won't take off.
did you put the blades on the right way
you will notice that the leading edge of the blade will be slightly curved and this curve has to be at the top of the blade so that as it is spinning it creates lift and so lifts the chopper of the floor
Nov 12, 2015 | Syma S111G Infrared 3CH Micro RC...
My hercules doesnt lift. rotors turn but it spins counter clockwise uncontrollably.
i am really glad that this isnt a REAL helecopter. if you got it for christmas, you might want to return it- that is, after you verify that it is FULLY charged. this sounds like a half charged battery, that isnt spinning the bigger blades as fast as it should.
this could also be caused by any obstructions to the blades ability to rotate freely, something stuck to the blades- adding weight, bent blades, or internal belt/gear issues, regarding regulating the main blades, and the rear stabilizing blades timings.
if, before the charge, the dying battery caused the copter to crash, a blade could easily be bent, or have mud or something on it, weighing it down.
if the copter really is indestructable, i would go right back to a bad battery.
if the rechargeable battery got a memory after 4 days, i feel bad for you and your kids.
Dec 29, 2014 | Hercules Unbreakable Radio - controlled...
Why is my flymo 360 eg not collecting the grass
If you have changed blades or have low lift blades this will be the problem. For good grass collection you should have high lift blades
Apr 30, 2014 | Garden
It spins out of control ever since I hit the wall it will not trim anymore I changed all the blades and it did not fix the problem
Check the linkage to the motors for the tail. Seems like it disengages somewhere, that or the fins on the tail blade are lose.
Jan 25, 2013 | Toys
Hello Fixya experts, I'm having a SYMA 9077 Double Horse Eagle. The problem is it doesn't lift off but just spins on the ground. The bottom blades are CCW, the top ones are CW. Plz help me analyze this...
The problem may be due to broken blades or untrimmed. Change the blades with new one is the first option if the same is all right trim your copter through trimmer button on remote. sometime copter not fully charged and this problem occurs.
Jan 05, 2011 | SYMA Toys industrial 9077 Double Horse...
My blendtec blender doesn't blend as well as it once did. The motor seems to be running fine, but I am not sure if the blades are spinning properly.
You have already found what is the problem the blades.
The blades after a lot of working hours with ice they have mainly three problems.
One the sharp adjes have created a lot of teeths and are not so sharp any more so the blending is not smooth anymore.
Second problem they have loose a title so they have move from corect place some milimeters and this change the wave motion and again the beleding is not so smooth as before.
Third the blades are secure on an axis which is located in two bearings which have een wearing out so the rotating motion of the blades again is not so smooth as before.
So if you are not able to fix the blades kit or to find someone in your area to do it profetionaly and cheap one good idea is to buy a new blades kid.
Good luck
Aug 17, 2010 | Blendtec ABC Work Top Blender
Yiboo AH-64 3D RC Mini Apache Helicopter, out of the box, charges, but will not do anything, channel C
Mine worked good for 3 days then died..Top blades wont spin.. It worked really well. The guy at (as seen on TV) shop that sold it to me actually seemed to tell me "Do not buy this!" But I bought it anyway at his word that I cannot bring it back no matter what after 24 hours..spent 90 bucks on this junk and there is NO SOLUTION
Oct 02, 2009 | RC Toys
MY YIBOO CHINOOK HAS A BROKEN MAIN BLADE HUB. WHERE CAN I FIND REPLACEMENT FOR MAIN BLADE AND SHAFT?
I found this on xheli.com. Syma S022 big CH-47 chinook.
Looks like the same heli as Yiboo. Lists all spare parts.
Good Luck. Please post results if you order from this site.
I also have the Yiboo CH-47, have not needed parts yet, just got it for xmas from my wife.
Sep 15, 2009 | RC Toys
I have an apache 3 channel helicopter.the top blades no longer spin so the helicopter just spins clockwise very quickly
Same problem I had. There are two motors. One to spin the top blade and a second to spin the bottom. My motor was defective out of the box to spin the top blade. Very poor quality as my AH 64 had a bad circuit board. I had to take parts from one to fix the other.
Sep 04, 2009 | Apache RC Mini Helicopter AH-64
Toys Logo
498 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
