Question about Miller Syncrowave 200 Tig Welder Cover 300059 New
Miller 250 I have HF but it won't jump to an arc unless I floor the pedal and touch the tung to the steel. When I get an arc, I have to back off real fast before I burn through. When I stop I can start again no problems unless I let the gas cycle stop, then it's the same start-up problem
keemo68
  • 1263 Answers
SOURCE: miller Syncrowave 250 / no tig arc start
seems that you have a ground issue. make sure the ground clap is on barte metela and secured tight. make sure your tungsten electrod is about 1/8 of an inch form the edge of the cone. you will find that you will get a faster arc this way.
Posted on Apr 19, 2009
  • 87 Answers
SOURCE: When I strike an arc with my miller 180SD
Check your foot controls first the POT my be acting up change it out w/another if you have one,
Posted on Oct 21, 2009
seanpwright
  • 2030 Answers
SOURCE: Miller syncrowave 250 tigrunner with gas flow
Your problem is in one of two areas. The controller board inside the unit or a bad trigger on your gun.
Posted on Feb 02, 2010
  • 5603 Answers
SOURCE: miller 250 dx tig willnot
The inverter or control of it has failed. Unit will require servicing. If you are not electronically adept, this is NOT DIY. Do your best to check the control pedal wiring, especially connectors and the cord near connectors.
Posted on Jun 25, 2011
luis_david
  • 407 Answers
SOURCE: Not getting a starting arc when foot pedal is
Hi:
The foot control has a micro switch in it, this one must be worn out. Take it to your nearest werlder shop (like praxair... www.praxair.com ) and ask for the microswitch by brand and model of your foot control. It's easy to replace. Probably the welder shop must order it, since it's noy pretty common for this switch to go bad, but it happens, specially on old welders.
Posted on Jun 26, 2011
What polarity do I use for tig welding aluminum, and what color electrode for miller hf-p dial arc
Jackie, watch the linked videos on tigging aluminum. "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
May 31, 2016 | Miller Welding Tools
225Bobcat gen.runs but will not excite when trying to strike arc
#Tags bobcat 250 welder service manual
coop.bounceme.net/term/bobcat-250-welder-service-manual
Why does my miller bobcat welder generator not stay at an idle when swithed to low idle, insted it goes back and ... Won't strike an arc,fuses ok brushes and slip.
Aug 11, 2015 | Electrical Supplies
Miller syncrowave 300 no power light and no weld power however have 480v input fan runs and can hear gas start when foot petal pushed
The first thing to check would be to see if you have open circuit voltage at the weld output terminals when you push the pedal. Make sure the high frequency is off if you are going to to check with a multimeter. After that if you do have OCV but no high frequency to start the arc, try it in start and in continuous. When you put it in continuous it bypasses a control relay. Also check the HF points to make sure they are clean and gapped to about ten thousandths.
Mar 05, 2014 | Hobart Handler 140 Mig Welder
How make tig welder to mig welder
switch from tig welding to mig by switching your current from AC to DC for mig. change from your tig gun to your mig gun. turn water flow off. proper ground and weld away.
Mar 29, 2013 | Miller Welding Tools
The tig welder will arc but there is no amperage and nothing is heated up it acts l;ike there is no amperage?
Make sure you have a good ground. With high frequency you can get it to still arc but have a bad ground.
Jun 11, 2010 | Miller Hf 251D 042388 Tig Hi Freq For...
My tig welder wont arc unless I touch the metal with it
my guess would be the type of welding machine you have.usually there is extra switch which says start control also continious cycle , sometimes smaller machines dont have these switches to allow a wider variety of tweeking the welder ,also its ok if you have to touch the base metal cause thats what starts the contact with the work peice ,keep a arc after touching about 1/4 inch away from work peice ,also a good steady hand rest will make a good welder in any situation this should allow the arc to remaim stable with a comntinious weld arc puddle. happy welding
May 22, 2010 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
Miller dialarc hf. foot pedal does not work
check pins a and b thats for the contacter closer. short those two out in the machine. and see if it.makes the hf come on.
Apr 05, 2009 | Welding Tools
Miller Syncrowave 200 Tig Welder Cover 300059 New Logo
71 people viewed this question
Top Miller Welding Tools Experts
Kory Ronning
hubiam
hubiam
Level 1 Expert
John Trevino
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
