Question about Garmin Approach G5 Handheld GPS Receiver
When I turn the Garmin on only the Garmin name shows on the screen. To turn it off I have to remove the batteries.
  • cdj1951 Apr 26, 2010
    I have a Garmin Approach Golf GPS - this solution did not work. Nothing changed on the screen when I turned it on after continuously pressing the upper left corner of the device.
    I put in new batteries and downloaded firmware; my computer is not recognizing the Garmin Approach 5 when I connect to USB so the program cannot find the Garmin to download the software. As soon as I plug in the USB connection cord it turns the Garmin on rather than using the "on" button.
    Guru:
  • 302 Answers
Your problem Most probably can be solved by restting your device. It would have been easier if you had mentioned the Model No. of your device. Following is general method shown for resetting most Garmin devices.
http://www.mydigitallife.info/2009/06/09/how-to-reset-garmin-nuvi-gps-device-access-maintenance-mode/
Try this method out. ihope it solves your problem. be sure to take care about all the warnings regarding data loss mentioned in this guide.
Posted on Apr 26, 2010
  • Mohsin Idrees
    Mohsin Idrees Apr 26, 2010
    Try doing it with fresh pair of batteries, Maybe it may help if you do it after keeping the unit without batteries for say 2-3 hours. Otherwise it seems like a firmware problem, Hopefully if you can update its firmware i am pretty sure your problem can be solved, If you are unable to update the firmware due to any number of reasons, then you might want to contact garmin support directly. here is the link to the Garmin Firmware Update page.
    http://www8.garmin.com/support/agree.jsp...
  • Mohsin Idrees
    Well I cant think of any other solution right now, maybe some other more experienced guys may help you out but i think you should atleast call garmin support people and expalin your problem to them.
How do I turn on my Garmin Nuvi?
Go to Garmin and download and install Garmin Express, Plug your GPS into your PC. The GPS should power on and Garmin Express should identify it and tell you of any updates. If the GPS does not power on (it should go into usb mode), then contact Garmin for warranty work. You can also check the power adapter in your vehicle. If the red light does not come on, the adapter either has a blown fuse or went bad, causing your GPS battery to be discharged. It is quite possible that your battery is discharged. You might leave it plugged into your PC overnight if the battery is dead.
Mar 28, 2017 | Garmin nuvi GPS
GpS gARMIN nUVI 40 ONLY SHOWS gARMIN NAME ON SCREEN AND WON'T DO ANYTHING ELSE
I have a similar nuvi model and this happened to me. I contacted Garmin who said that I need to update the software on my model. Plug your nuvi into a pc. Hopefully the pc will recognise the device and it will launch some Garmin web page. From there, read the instructions on the page and see if you can update the software. If there is no response from the device when plugged in, visit Garmin's website and find your device. There should be an option to update software. Try it this way. Hopefully this sorts the problem. I leave mine in the car a lot and in freezing conditions and while it does drain the battery a bit, I don't have the problem you are having. Good luck.
Feb 04, 2013 | Garmin nuvi 40 - GPS receiver
I have a garmin nuvi sat nav which is just over a year old when unit is turned on all that shows on screen is the name garmin loading maps flashing on and off
Did you try a reset. Turn off the unit. Hold the bottom right side of the screen and turn the GPS back on. It will make you confirm you want to reset. It will clear out all you favorites etc.. so copy them first if needed. Then I would go to the Garmin site a register and update the unit. See if this works
I will attach Garmins contact info. Thanks for using FixYa.
http://www.garmin.com/garmin/cms/site/us/support/supportcontact
May 15, 2011 | Garmin Nuvi 265W GPS Receiver
Plugged device into car outlet. Device comes on, shows Garmin name and then shuts off and does nothing more. Prior to this happening screen displayed "battery low".
DC power will not properly charge the battery. It is possibly damaged. Change i. Preferably charge it via AC before using on DC.
But change battery....
Jul 05, 2009 | Garmin nuvi 205W GPS Receiver
Garmin Nuvi 255 won't charge with the car charger.
You may need to replace the battery.
The video on the link below shows how to replace the battery in a Garmin Nuvi:
How To Change The Battery On A Garmin Nuvi 760
Feb 21, 2009 | Garmin Nuvi 255 GPS Receiver
My garmin streetpilot c340's screen turns on and then goes black. I have it plugged into my car but it still won't stay on.
I found the solution on another blog. He said to try resetting the reset button . It worked. The button is located under the front screen. Remove screen frame by fingernail under the Garmin name. I'm thrilled. navinscs
Jan 25, 2009 | Garmin StreetPilot c340 GPS Receiver
My Garmin nuvi 200 stoped working so I went to get new batteries for the cord. They tried to replace them but the Garmin still did not work. They sold me a universal cord with a plug that goes with the...
I had the same problem with my Nuvi 760 turning itself off right after the "Loading Maps..." screen but I found the answer in the Q&A section on Garmin's website.  It's actually very simple and you'll kick yourself...  Charge it up all the way!  It does that when the battery is really low.
Apr 16, 2008 | GPS
Garmin GPsmap276c won't go to any screens or shut off
Hold the enter key while powering on, reloads software
Mar 09, 2008 | Garmin GPSMAP 276C GPS Receiver
Low Battery
Recharge the battery or plug it into your car cigarette lighter and turn the unit on.
Jan 06, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Approach G5 Handheld GPS Receiver Logo
124 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
