Question about Lexmark X5150 All-In-One InkJet Printer
Cartridge error after installing new cartridge
    President:
  • Lexmark Master
  • 2,017 Answers
Check to see if the installed cartridge is the correct one for the printer. If the cartridge is the proper part number, remove the ink cartridge and make sure all the packaging tape has been removed from the copper circuitry strip on the backside of the cartridge. Reinsert the cartridge and try printing again.
If the error continues, remove the cartridge again and clean the copper circuitry strip on the backside of the cartridge, and the contacts inside the printer, by following the instructions below:
1. Use a clean, dry, soft, lint-free cloth. Locate the copper-colored circuitry strip on the back of the cartridge.
2. Wipe the copper-colored strip with the dry cloth. Use an upward motion, from the nozzle end to the top of the cartridge. Do not wipe the nozzle end of the cartridge or touch the nozzle plate. Wipe the contacts only once.
3. To clean the printer contacts, carefully look for fibers or contamination on the electrical contacts inside the carriage assembly, but do not wipe the printer contacts with any object. The contacts in the printer can be damaged if too much pressure is applied during a wiping process. Try to remove any visible attached debris within the carriage assembly by gently pulling the debris off with your fingers. If the carriage contacts show noticeable damage, contact the Customer Care Center listed in the printer's User's Guide.
Reinsert the cartridge and try printing again. If the error continues, the cartridge may need to be replaced.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Posted on Apr 26, 2010
Brand new lexmark original cartridge is not recognised. error report' no cartridge'. all contacts cleaned machine dismantled and cleaned and reassembled. has done this before on occasion with refilled...
1. Open the top front cover of the printer. If the display DOES NOT read Close cover or Insert cartridge, the 32 error is not caused by the toner cartridge and printer service will be required to fix the problem.
2. Make sure the correct toner cartridge is installed for this printer model.
1. Check Lexmark for a list of compatible cartridges for your printer.
2. If the wrong toner cartridge is installed, remove it and install the correct one.
3. If the correct toner cartridge is installed, it may not be seated correctly. To ensure that this is not the cause of the error, do the following:
1. Turn off the printer.
2. Reseat the toner cartridge.
3. Close the lid.
4. Power the printer back on and check the display.
4. If reseating the toner cartridge does not clear the error message and the error started as soon as you installed this particular toner cartridge, the cartridge may be broken. You can check this as follows:
1. Power off the printer and then reinstall the old cartridge. (You can also try a different new cartridge to see if that clears the error.)
2. If the error does disappear, the problem may lie with this cartridge. Please contact the point of purchase, especially if the cartridge is brand new out of the box.
5. If the error cannot be cleared by putting in a new toner cartridge or one that is known to be working, the printer may require service to fix the problem.
May 02, 2011 | Lexmark X2350 All-In-One InkJet Printer
Lexmark c534dn unsupported cartrige
This error message appears on the printer screen when the printer thinks the wrong toner cartridge is installed. To clear it or identify a service requirement, follow the steps below. NOTE: If you succeed in resolving the problem at any stage during the procedure, you not need to perform the remaining steps.
    3. Close the lid.
Feb 15, 2011 | Lexmark C534dn Laser Printer
New cartridge, says cartridge error
1. Try removing the cartridge and unplug units a/c power.
2. Find a damp cloth and wipe the output ports on the bottom on cartridge. .
3. With a Q-tip, go over the round copper pumps on the cartridge tray. ( Where the cartridge makes contacts. )
4. Close door and power up unit.
Unit will give you a error message cartridge not installed.
5. Install the new cartridge.
Close door and fallow any additional instructions given.
( A ) If this does not resolve your problem, re-install old cartridge and see if you get the same error message. If you do not, replace the new cartridge.
Hope this has resolved your problems.
Please rate your techs.
Oct 06, 2009 | HP Officejet J3680 Multifunction Printer...
Installed new black ink cartridge on Kodak ESP7. Cannot get rid of Error Message (saying need to install black cartridge!). Help!
Kodak had a batch of bad cartridges, I got 3 of them. All come from China. I used the online chat to describe the problem. They promised to send me new cartridges.
Jack
May 11, 2009 | Office Equipment & Supplies
Have put in a new colour cartridge but the note on the printer comes up error 50C
Cartridge Error 50C
Your print cartridge has shorted.
  1. Power off your All-in-One and unplug it.
  2. Plug in your All-in-One again and turn it on.
  3. Uninstall and then reinstall your cartridges.
  4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Error: Black Cartridge Missing
The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing
The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error
Complete the following instructions:
  1. Power off your All-in-One.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 03, 2009 | Lexmark X5150 All-In-One InkJet Printer
We purchased a new cartridge because it said install new ink cartridge,we installed new cartridge it still says install new ink cartridge and will not receive or send faxes
it will not send or receive a fax if the error is still there. Clear the error by trying these steps:
-open cartridge door and remove the cartridge
-unplug the power cord at the back of printer
-after 30 seconds, plug the cord and turn on the printer. It will ask for the cartridge.
-Open the cartridge door and insert the cartridge
-close the access door
-if the error is cleared, try faxing again.
I hope this helps.
Regards,
Mar 02, 2009 | HP 640 Inkjet Fax Machine
How do I install a new cartridge holder?
hi dear
this the error code
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
First, download the software at http://www.box.net/shared/4yblbn34kg
Secondly, to run the software your printer has to be in service mode. Do that by
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
At this stage, your computer will detect a new hardware
Run the software.
oke
May 30, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Cartridge error
remove the cartridge & install the new one cartridge other wise
May 10, 2008 | HP Photosmart C5180 All-In-One InkJet...
Cartridge
we have a link on how to fix your own printer through this link(check for search box further down page)
Jan 28, 2008 | Lexmark X2470 All-In-One InkJet Printer
Lexmark X5150 All-In-One InkJet Printer Logo
101 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
