Question about Western Digital Caviar WD200BB 20 GB Hard Drive
WD200 internal Hard Drive
Hi, Just installed a 20Gbt HDD, runs fine some of the time, but more often I hear a series of 4 "clicks" and the drive is not recognised by the BIOS, and therefore can not start Windows (XP)
  • 2 more comments
  • mkingy Mar 24, 2008
    Thanks for the quick responce, but not what I really wanted to hear! as I have just bought it on eBay. I suppose there's no way the problem could be with jumper pins, or BIOS setup etc.?
  • Anonymous Apr 24, 2008
    HDD sufers hover heating even there is cooling fan, it does not recognised bu BIOS sometimes, and sometimes run then stops and making same noise.
  • alok1965 Sep 19, 2008
    i have a couple of wd200 s with problems like errcode 1780 - jumpers not set ... some others make clicking sound when the mc is powered .. kindly help....alok
  • Anonymous Dec 27, 2008
    Clicking in every 2 minutes
  • 518 Answers
FYI, if the bios or jumpers are wrong, it won't work at all. You can try running chkdsk /f from the run window. That may fix it if it bad sectors, but odds are kman is right.
Posted on Mar 24, 2008
  • 99 Answers
Your Hard Drive is failing or has completely failed.
Cannot fix, only replace.
Hope this helps.
Inspiron 570
Safest is way to install a removable drive tray such as Welland EZStor ME-751 Trayless HDD Rack 5.25" Bay for 3.5" SATA HDD/SSD - Anti-Shock, Scratch-Proof.
Then you can swap HDD anytime.
You can also install new (now upgrade) Windows 8.1 on a 2nd HDD internally. But sometimes the 2nd OS can damage the first OS if ou are not careful with C: drive letter.
Jan 06, 2014 | Computers & Internet
Bad sector problem, and hdd is not working proparly, hdd ditecting problem
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which willscan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
Nov 17, 2010 | Fujitsu 160GB 2.5" 7200rpm Internal Hard...
Hi wd200 hd with serious clicks
You can't change the internal parts, you'll lose all your files on the disk if you do so. This is called the 'click of death' and it means that your disk has physical problems with it (and it's not repairable, you'll have to get a new hard disk drive to replace it.) There are many short-term remedies that will allow you to try and get some if not all your files off it before it fails for good; take a look at Google for some advice.
If the information is very, very important then it's a good idea to call up a data recovery service; it's effective but can cost a significant amount of money.
Jul 12, 2010 | Western Digital Caviar WD200BB 20 GB Hard...
1tb simpledrive will beep, click, but not work. No joy.
power source jack/plug might be the problem if it has been bumped about or if it was powered up and running before plugging in to the comp.....
i had the problem of my 1tb ext/hdd no longer being recognized because when i plugged it into my comp, the jack was live and not switched of at the wall. the only way i got it to work was to pull it out of the casing and switched it with the 320 ext/hdd i have as they are they same brand..just diff sizes. going to put the 320 into comp to become master drive as the internal is a measly 40g. i think i had burned out the connector pins on the power jack when it was plugged in live. i hope this is an idea for you to try.
Aug 24, 2009 | SimpleTech 1TB External USB 2.0 Hard Drive...
My western digital Passport 320Gb usb drive is not detected
hi ,
looks like u primary hard drive is inside the laptop and so should be displayed as c : drive ,
and the reason , the external hard drive is not displayed seperately is csue ., the external HD  may be added as slave to the internal HD .,
can u tell me ,make a right click on c:/ drive and choose properties : and tell the totalsize dispalyed
Jul 23, 2009 | Western Digital Passport WDXML800UE...
"no boot sector on internal hard drive"
i think you need to re-install your Operating System again since you got a new HDD wich is tottaly empty i assume so try to install your OS on the new HDD
let me know if it helped
Jan 02, 2009 | Dell Inspiron 6000 Notebook
Hard drive
it might be because of virus,that stop you to enter your hard disk when you click on it..install anti virus like avg 7.5,mcafee ,norton to check for the virus .
also goto start >open Run>cmd to open command prompt and type
to check your driver for errors.
Apr 24, 2008 | Computers & Internet
Hard drive
hi dear
use a cd booting
in command prompt c:\
type c:\fdisk /mbr
to fix your master boot record\
and make your partiiton active.
after that installing your windows XP
Mar 15, 2008 | Maxtor Hard Drive
How can i installed driver of sata hdd for linux red hat
if you are installing red hat 8 and higher there is no need to install extra driver because linux is the only operating system which will install everything including drivers, office suite,programming tools etc .... as far as my suggestion dnt install old versions of linux instead install new version ... there are many linux available
ex: fedora core 4,5,6 ,knoppix live cd linux ( which boots linux from cd no need install it) ,ubuntu,red hat,mandrake,suse ....
you can download it from net 4 free as linux is open source 4 all ...
be careful while installing linux especially during partitioning..... if u make a mistake you will lose all datas
Feb 04, 2008 | Seagate 80GB 7200 rpm SATA/150 8MB Serial...
Western Digital Caviar WD200BB 20 GB Hard Drive Logo
886 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
