SOURCE: i cant send or recieve text messages or calls
go to "manage connections" from the home screen. make sure you have checked the box beside "mobile network"
SOURCE: i dropped my blackberry curve 9000 on my house
your unit has a problem with the LCD..
it is better to replace the LCD before it can damage all the parts of your unit..
SOURCE: My blackberry tour won't send sms messages, but
I request you to check the message centre number and confirm it with you are operator (customer service).
SOURCE: Cant send or recieve mms messages nor surf web..
You have to have the MMS service activated on your number as it is an additional expanse it is offered separately.
SOURCE: i try sending text messages with blackberry bold
Hello,the problem you are facing is simply caused by either of the two things listed below,
1.mistakenly deleted your message center number
2.having a problem with the service provider sending system.
When you mistakenly delete your message center number,all you need to do is just to look for someone who uses the same network with you,and you visit the person's message center number on the message settings.it's not necessary the person must be using a blackberry,it could be a nokia,samsung and others.all you need from them is the message center number.
Having problem with the service provider means probably they might be experiencing a bad network quality from their server,so i will advice you call them to get them aware about the problem you facing.i hope this helps and also solve your problem.
thanks for using fixya,
take care.
