Question about Asko W6021 Front Load Washer
Machine won't spin
The machine appears to wash properly but when it gets to spin it stops. I have cleared the part below and checked that there are no little objects that have been caught in there. Also I have turned the machine off and opened the door manually then restarted the machine again.
  • Asko Master
  • 2,605 Answers
Hi, can you start the unit without any clothes in it, let it fill with water as usual and then observe if it tumbles in both directions during the wash cycle ? ( I don't mean the entire cycle, just long enough to insure it rotates in both direction ). Then turn it to drain and insure it drains completely, observe the spin cycle if you can and report if it only spins in one direction slowly. This will go a long way in diagnosing your Asko washer. Let me know what you find. If it only goes one way, the motor needs new brushes and possibly a complete motor if the armiture is damaged. Good luck. Macmarkus :)
Posted on Apr 26, 2010
Won't final spin ?
What is the model number of your unit?
Nov 04, 2012 | Washing Machines
Frigidaire Affinity ATF7000E Front Load Washer won't stop spinning with 1 minute on timer- it continues until I hit cancel. I don't like to babysit a machine but have to make sure it doesn
If the unit is washing properly, as far as you can tell, but it won't stop spinning, then I would have a professional look at the control panel and timer to be diagnosed because there seems to be in miscommunication.
Sep 14, 2012 | Frigidaire Affinity ATF7000E Front Load...
My Asko washing machine model w6021 won't spin, At
It very well could be a programming issue. You would have to know what version of software each board had in it. Boards can be used in different machines where some functions just are not used as they are in the better models. There should be a stamp or something indicating the software version on the board, a chip, something. I would not run it like it is or something else is going to go.
May 19, 2012 | Washing Machines
Why is my frigidaire washer not spinning?
  1. Stopped Mid-cycle
    • If your Frigidaire washing machine started spinning, but then stopped, verify that the power cord is still connected to the outlet. See if the outlet blew by plugging in a different appliance into the outlet. See if you blew a fuse. A blown fuse usually is either black or has broken wires. Replace the fuse. If you have a circuit breaker instead of a fuse box, reset the circuit breaker if it's been tripped. Check the lid switch, which is located inside the main housing of the washing machine, near the door frame. If the switch is burned out, order a new part from a Frigidaire parts dealer.
    Pump
    • The pump's sole responsibility is to remove water during the spin cycle. If the pump isn't working properly, see if it's clogged with debris or clothing. Use needle-nose pliers to remove these items. Check the pump pulley, which is connected to the pump. This component must move freely for the pump to work. If it won't turn, purchase a new pump pulley since you can't usually fix this component.
    Lid
    • Check the door latch assembly if the door isn't closing correctly. If any of these components are broken, order a new part from a Frigidaire parts dealer. If you do not, the washer won't start spinning since it believes the door isn't closed. Your Frigidaire washing machine won't start the spin cycle until the lid or door is closed. Always close the lid, and remove any items preventing the lid from fully closing. Always close the dispenser drawer.
    Additional Concerns
    • Never over- or under-load your washing machine. Your Frigidaire washer may not enter the spin cycle if the load is too large, since this can damage the washing machine. Remove a few pieces of clothing. If the load is too small, add a few similar items to the washing machine. Check the internal belt, drive motor and motor coupling. If any of these components are broken or very worn, they may not work properly, preventing the washer from entering the spin cycle. Order replacement parts from a parts dealer. Check the tub and basket bearings, and get new ones if the current ones have broken components or are defective.
Sep 27, 2011 | Washing Machines
I have a Kenmore Elite He3. It won't complete any wash cycle without stopping and displaying HF. I can restart it but it continues restarts the wash cycle again. Therefore a Heavy Duty wash cycle of...
Hi
Error code FH appears when No water is detected entering machine or Pressure switch trip is not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. Press PAUSE/CANCEL twice to clear the display. If there is no water entering the unit then make sure that the inlet valves are working fine. You may need to check the continuity at the inlet valves. If the valves are fine then check whether inlet water hoses as they might be plugged. Also check for inlet water screen at the valve. However, if the water is entering into the washer then the Drain pump might not be working. Also inspect the Pressure Switch hose whether it is in good condition and properly connected to Tub and Pressure switch. Also check hoses for leak and inspect the flow meter. Hope this helps...
Daniel
Aug 31, 2011 | Kenmore HE2 Plus Front Load Washer
My beko washing machine is stuck on the end spin cycle and stops and starts a spin in short bursts.it has water in it and wont move on from this.
Hi jennyandeddy,
Most likely your washing machine is trying to drain, but cannot, and as such cannot start to spin.
Please follow my Tip below, for detailed directions on how to access, drain & clean your Drain Pump Filter (Please Note: Your Filter compartment is located at the Bottom Right):
DRAIN PUMP FILTER
Hope this helps :-)
JEDEMEYER1
* If you found this solution helpful, please rate it
Jul 13, 2011 | Washing Machines
MY BEKO 765s washing machine, has stopped working mid load, on the display it is flashing iL but its smaller, it has also gone onto pause, and wont go on to start, also on flashing on 1200. This was a...
Hi if your beko 765s washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Dec 31, 2010 | Televison & Video
The machine won`t wash and the letters LD are appearing in the timer slot ?
Hello there:
Ld Long Drain Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Press STOP/CANCEL to clear the display. unplug the POWER cord .or turn off the maching for 10 min and retry if this stil does not help check each of these things i have mentioned below and replace or repair as needed
· Check wiring harness
· Check pump motor
· Check circuit board
Sep 26, 2010 | Washing Machines
Drum does a small turn then stops but wont empty -wont wash either beko 1000 rpm
Hi if your beko 1000 spin washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Aug 23, 2009 | Washing Machines
Asko W6021 Front Load Washer Logo
360 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Joseph Hoffmann
marley mcelhinney
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
