Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
Plugs fouling out
It appears that my plugs are fouling out (damp with gas) on my 12 year old 22 hp V-Twin B&S keeping it from starting. I have had not a lick of problems with this motor, it appears to have plenty of compression when turning th motor over and placing my hand over the open air intake. I'm hoping this is an easy fix rather than loading my mower up driving 30 miles into town, waiting a week or two and paying someone to diginose something I could have easily replaced myself had I known what part was the problem. Any suggestions?
Thanks,
Benny from Missouri
    Problem Solver:
  • 9 Answers
It sounds like you may have water collected in the carb bowl. the fuel gets diluted to the point that the engine won't run and yet when you pull the plug it is wet with the diluted fuel. Drop the carb bowl and see if water is in it or if you have a drain plug just drain it. Check the fuel tank to see if there is water in it also and drain and clean if nesecarry. The water comes from condensation.
Posted on Apr 26, 2010
Spark plugs foul immediately
Fouled plugs may be caused by oil leaking into the cylinder. Does it smoke when running (cold), are you using up the crank oil. Black smoke is excess gas comsumption, blue smoke is oil burning. If your plug is fouled with black carbon, you are most likely running to rich.
Apr 07, 2014 | Briggs & Stratton Briggs Stratton Vanguard...
Kohler command 20 twin engine - no spark
If there's no spark, then either the spark plug has come into contact with gas, or the ignition coil is bad. Try either replacing the spark plugs, or removing the old ones and seeing if the tips are damp.
If replacing them doesn't work or the plugs are dry, then try replacing the ignition coil.
Feb 15, 2013 | Kohler 20 Hp OHV Command V-Twin Engine...
Hi I have a 22 hp briggs in a husqvarna rider. Started running a little rough at season end last year. This year it started, but ran only about 2-3 min, then would not start at all, put in new plugs (old...
This a common problem after they have set up over the winter. Water has probably condensated in your gas tank and now it is in the gas line. The tank should be drained of old gas and the gas line to the carb should be removed from the tank and blown out with compressed air to remove all old gas/ water. Attach the gas line back to the tank and refill the tank with new fuel. This should take care of the problem. To avoid this next time, just fill your gas tank to the top at the end of the season and leave it full through the winter.
Mar 28, 2011 | Briggs & Stratton Briggs Stratton Intek V...
I have a B & S vanguard 20 H.P. vert. shaft, 8 years old on Simplicty tractor. Keeps fouling plugs. Clean or replace plugs and it runs fine for about 1/2 an hour then starts to miss, blacksmoke, and...
Anti-foul plug adapters might be a temporary solution (treats the symptom and not the cause).
Personally, I would take it to a good, reputable, small engine repair shop that has verifiable references, and have them repair it.
Aug 03, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
2004 v twin 16 hp 500hours on it runs but spits fuel throught carb when giving gas runs like its missing on one cylinder replaced carb, plugs, fuel filter, it has 120 lbs of compression in each cylinder...
You should take one of the heads off and look at the valves. You may have deposits building up no the valves.
120 pounds compression sounds pretty good for a six year old engine with 500 hours on it. It probably started life at 9 to 1 and now is around 8 to 1.
May 05, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton 22 HP V-Twin won't start
Take it back , it is still under warranty if you just bought it.
Jul 25, 2009 | Garden
My B & S fouls plugs, runs rough, almost stalls when blade
THE PROBLEM SOUNDS LIKE THE CARB IS RUNNING TO RICH OR TO MUCH GAS IS BEING PUMPED INTO THE CYLINDER. IS THERE ANY SMOKE AND WHAT COLOR SMOKE
Jul 11, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs&straton model28n707 type0173-01 won't start
Ours did the same thing. It turned out to be a bent push rod. The intake valve keeps seizing after it's shut off. We free the valve, straighten the push rod and it will run till we shut off. Then same thing. Valve seizes and bends the push rod. We have a call into Sears to see if warranty will fix.....
Jun 25, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
497 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
