Question about Sony Handycam DCR-VX2100 Mini DV Digital Camcorder
In playback mode my camera skips, and sometimes play choppy
Hello my name is Anthony, and here's my problem: After recording video with my Sony vx2100 I play back the footage and it skips like a dvd with finger prints or something. Then when I download it to my editing software I can see where the clips that skips a separated from the rest of the video. Any thoughts?
SOURCE: Hi8 playback problem
your guides have come loose , probably - the digital sound will be next to go because the bottom edge of your tapes are being folded - open the cassette tape lid by pressing the small pin near one hinge and gently lifting the door - if there are any creases ? get the guides aligned ! to protect your library ; ( if there are no creases , try a sony d8 cleaning tape - once ! before getting a repair quote ) ;
Posted on Jul 29, 2007
  • 221 Answers
SOURCE: Rewinding Troubles
return it to b+h for warranty repair. sounds like a tape path alignment problem.
Posted on Oct 26, 2007
  • 32 Answers
SOURCE: Sony HDR-HC3 camera won't connect in HD mode in iMovie HD or FCP HD
What software are you using to capture the HD footage? Are you using the supplied software, or another package. It is likely that you have a software incompatibility. i.e. windows will recognise DV natively, but HDV requires specific codecs and software installed on your PC.
Posted on Jan 03, 2008
SOURCE: Playback is choppy
I had this problem very recently. In fact I borrowed camcorders from my friends too and after short periods, they too started having the same problem. Essentially, it looks like there is some choppiness every second or so - like there is noise in the audio and video. After a lot of looking around, I finally found a suggestion posted that ACTUALLY WORKED on all 3 camcorders:
I placed an empty tape in the camcorder and recorded a few seconds into it. Then I removed that tape and tried to play the previous tapes that were showing the choppiness. No problems any more. Everything works fine.
What I still do not understand is why 3 camcorders (all DCR-TRV103s) all showed the same problem (with different tapes by the way). And since I still have lots of tapes to copy, I need to know why this problem is happening so I can minimize its occurrence while I complete the copying process.
People have suggested that my tapes are old and may be offering resistance to the camcorder. So I have ordered a rewinder to spin the tapes a bit before trying again. The two possibilities suggested around this was (1) some mechanical switching took place which got reset when recording; and (2) something got corrupted in the software that manages the playback buffer and that software was rebooted when it went to recording mode.
So while this will hopefully answer your question, I'm also looking for explanations for why this happened to me on 3 different camcorders.
Posted on Mar 18, 2008
ctf1800
  • 4402 Answers
SOURCE: Gray Horizontal bars in playback mode on Sony DCR-TRV33
tape path needs to be aligned.
Posted on Apr 11, 2008
Hello, my name is ryan, i have a sony dcr vx2100 and whenever i record video and go to play it back, the video skips and is very choppy. I was told to try a head cleaner which I tried and it didnt help at...
This is most likely caused by a damaged or misaligned video drum and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I
Dec 31, 2010 | Sony Handycam DCR-VX2100 Mini DV Digital...
Audio
You have nicely proved that u have done the basics to solve the problem. Dont worry Sir, we will look into this and get back to you.
Thankyou
Apr 06, 2008 | Sony Handycam DCR-VX2100 Mini DV Digital...
I just got my Xacti CS1 and after I shot a couple of test videos, I checked the playback. On the camera screen, playback is flawless, it's quite great, however, when I play the videos back on my macbook in...
http://us.sanyo.com/dynamic/product/Downloads/VPC-CS1_OM_English-6223243.pdf
p.60 of the manual describes different recording modes with lower resolutions (1280x720) pixels and lower frames per second (30fps).
I would choose from the menu to record in a lower resolution and lower fps mode so that the quicktime program can display the video at a good rate for you.
I don't know what kind of macbook you have, but usually such problems are due to the older macs not having enough speed to display high definition video with all its data all at once.
I used to have problems a few years ago, before i upgraded my hardware on PC's, with choppy video that was High Definition.
Jul 30, 2010 | Cameras
Recording onto a mini dv tape from Mac computer Via firewire
I have successfully recorded to a mini Dv tape from my computer however I connected my PC to the VX2100 using the RCA inputs. I have an adapter that I purchased from best buy that provides the RCA input/output. If your able to connect that make sure to...
1. Turn you VX2100 to Play/Edit mode (not camera mode)
2. Insure the program on your mac has an external output otherwise you won't be able to record.
3. See if your video editing software (if your using one) has an option for record to tape or to camera. I use Vegas Studio and it has an option for that.
Hope this helps. Good Luck!
Jun 23, 2009 | Sony Handycam DCR-VX2100 Mini DV Digital...
Sony DCR-TRV510 Playback Blank or Choppy
I recently had similar problem. Sony Phone tech support was very helpful. The answers were strange. You need to make sure the cameral is turned off, unpluged and take the battery out for at least 5 minutes. (something to do with reseting firmware). That sort of worked when coupled with there last comment which was to RECORD about 15 seconds and play it back. Mine was instantly healed!
Jan 13, 2009 | Sony Handycam DCR-TRV510 Digital Camcorder
My dads camera has a triangle on it and its beeping instead of playing.
Check the mode settings. Make sure it is in playback for playback(vtr) operatioin and standard videotaping modes otherwise. Check the manual.
Dec 20, 2008 | Sony Handycam DCR-VX2100 Mini DV Digital...
VX2100 record settings for slow motion playback when editing
you can't ! you have to slow you footage afterwards.
Anyway, try to record with a slow speed shutter (1/30th of a second or less) to fluidify your images but if you want to slow down your footage, it's probably because the scene is "fast" and this doesn't could help you anyway !!!
Dec 18, 2008 | Sony Handycam DCR-VX2100 Mini DV Digital...
Sony vx2100...blue playback screen
in either case the head condition is bad.. pls inspect the tips on the head whether it is not damaged in the cleaning.inspect the drum hours also..
Nov 08, 2008 | Sony Handycam DCR-VX2100 Mini DV Digital...
Audio
it is the tape running path makes the problem and normally happens in a long run. realign the tape path by carrying to a sony service centre...
Jan 14, 2008 | Sony Handycam DCR-VX2100 Mini DV Digital...
Rewinding Troubles
Oct 12, 2007 | Sony Handycam DCR-VX2100 Mini DV Digital...
Sony Handycam DCR-VX2100 Mini DV Digital Camcorder Logo
176 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
