Question about Whirlpool GU2400XTP Built-in Dishwasher
Dirt on dishes
After wash the top shelf only dishes dried food on them also around the top and side of door.I have rinse aid and salt in I have also cleaned top arm that is under the dishes
  • Whirlpool Master
  • 43,501 Answers
Here is a tip that will help you...
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Posted on Apr 27, 2010
Milky water when rinsing in dishwasher & gritty covering on dishes
I have spent many years (47) in the catering industry using catering dishwashers, under counter models, corner- wash stations and also conveyer machines..
The milky water is a by-product of the wash water and rinse water mixing.
The spray are has to rotate freely or the dishes won't wash or rinse properly. They spins a lot faster than you realise and this adds pressure to the water, but also a pulsating effect to remove dirt.
Over doing the salt can cause more problems that it solves. The gritty film may indeed BE salt. I actually prefer Calgon as a softener.
My advice is to remove both top and bottom spray arms. Check the slots/holes for obstruction, and run water through them under a tap, outside to inside (the opposite to how it is in the machine) rocking the arms up and down to allow any obstructions to flush out. Lemon pips and toothpicks are out biggest problem! Put the arms back and make sure they spin freely. Sometimes they just lock up for no apparent reason!
Use CLR descaler in the machine to clean it using the instructions on the bottle. Then run the dishwasher using the recommended doses of detergent and rinse aid.
Jan 19, 2016 | Siemens Dishwashers
We have a Zanussi that has been fine for 2 years but the last week it has turned a powdery white inside and on the door with all the dishes becoming chalky. There is rinse aid and salt. Hope you can help
Dishwashers have a part usually called a separator or accumulator which traps the dirt from the water during the wash cycles while the water is continuously recycled to clean the dishes. At the end of the cycle the separator is flushed out and the trapped dirt goes down the drain. If it doesn't get flushed out the dirt builds up till it starts showing up on the dishes. Some separators have a hole on top and one on bottom with a valve which stops up one hole or the other depending which cycle it's running. The valve can be stuck or broken causing the problem.
Jul 15, 2010 | Zanussi 24 in. ZSF6150 Free-standing...
My dishes come out dirtier looking after washing in the machine.
check the water temperature is reach the desired setting,clean the rinse arm and check the rinse soaf if working at end of wash cycle.
Jun 05, 2010 | Whirlpool 24 in. GU3200XTP Built-in...
Filters clean, arms unblocked, salt and rinse-aid ...
Yes! you are already having the answer. check your water inlet flow. Clean the strainer at the machine water hose connecting end.
Check the drain filter also. Refer user guide for instructions on cleaning.
May 19, 2010 | Dishwashers
White film and food particles on dishes
Did you check the incoming water quality, regarding hardness!
If your washing machine supports salt addition technique, fill the appropriate box and fill the salt that is meant for washing machines. Salt works as a softener.
Finally check your rinse aid also for it's fill in the dispenser meant for it
Apr 11, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
White film left on dishes, does not seem to be cleaning thoroughly
could be several things... usually it just needs rinse aid.. all dishwashers spot or leave dishes cloudy without rinse aid.. or your water is just to hard, in that case you will need to soften it with salt, check the owners manual to see how that is done.. also run the dishwasher right after you put the dishes in, if you leave them for a day to wait to fill it up then the dried food gets like cement.
Dec 01, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Door is wet with condensation at the end of the cycle although dishes are dry
this problem should be under dishwashers not washing machines! however this is caused by lack of rinse agent this aids the drying process and removes moisture from crockery check levels if ok try using detergents with salt and rinse aid combined may be dispenser is not working properly.
Sep 26, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Not rinsing soap still on dishes
try washing the dish washer out with a good drain unblocker the system gets cloated up with grease, then use a dishwasher salt with the washes this will help to remove the suds ets, most dishwashes have a compartment to put either liquid or solid dishwash aid in try a different aid, also if you use tablet form i desolve it first in hot water in a small container
then place that into the dishwaser on the lower shelf, that helps
Aug 16, 2009 | Dishwashers
Dishes aren't clean. i have run vingegar and CR through the cycle but dishes and glasses still have a film.
The most common cause of film left behind is a broken heating element.
The heating element is not only used during the dry cycle, but also to raise the water temp. during the main wash cycle to activate the dishwasher detergent. Fixing the heating element should "clear" this problem right up!
Aug 04, 2009 | Zanussi 24 in. DA6141 Built-in Dishwasher
Indesit D63 dishwasher dishes not getting clean
Dishwasher seems to cycle through but dishes are still dirty, like there is no water being sprayed?
Jan 23, 2008 | Dishwashers
Whirlpool GU2400XTP Built-in Dishwasher Logo
155 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
