Question about Roper RS22AQXKQ Side by Side Refrigerator
Creaking noise coming from ice maker?
I was told to empty the ice maker and now it's not working at all. The creaking noise is slowing driving me mad. Any suggestions?
Hear a creaking noise under the dash on the driver side, it goes away if i accelerate or hit the brakes. it seems to be vacume related. could it possibly be the brake booster. It makes the noise constantly...
The exact nature of the creaking is important, and you have not provided enough info to narrow down the problem. The only "creaking" noise I have ever heard like that was coming from the front wheel. If it is going "creak -creak-creak" and changes as the car changes speed, I would check that.
Mar 04, 2018 | Buick Century Cars & Trucks
Creaking noise coming from side freezer
The noise is most likely coming from the ice maker as the paddles are pushing the ice cubes from the ice maker into the holding bin. They do not move very quickly and can cause this sound. hope this helps.
Dec 20, 2010 | Amana 26 cu. ft. Side-By-Side...
Kenmore elite side-by-side ice maker creaking!
Look behind the freezer rear trim panel for frosted/iced evap. coils and thaw if necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 29, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
A creaking noise when the freezer is opened & then closed
In some freezers they build up excessive vacuum which pulls the plastic housing away from the internal polyurethane insulation, hence the creaking sound. You can make a vacuum breaker by attaching a small stick or similar to the bottom of the door gasket, this will break the vacuum without losing temperature.
Mar 12, 2009 | Refrigerators
Ice maker not working
make sure the wire rod on the ice maker is in the down position in order for it to make and release the ice
Dec 13, 2008 | Maytag MFD2560HES Bottom Freezer French...
Shaky steering and creaking noise from the front drivers side when I turn
Might want to change front struts and strut plates.My strut plate on pass side made that creaking noise,once i changed it i never heard it again.
Jun 16, 2008 | 1995 Chrysler Sebring
Strange Noise - Creaking
I had the same problem. My fridge would make a creaking sound as soon as the freezer was closed. I took 10 minutes to trouble shoot the problem and pinpointed that it was coming from the icemaker. After wondering if I was going to have to replace it, I noticed a piece of ice wedged in a way so that the ice maker arms could not fall into the basin to make ice. The sound was the motor creaking because of the jam. Removed the ice and the sound went away. Now, I'm sure the motor will **** out in a few months since it has been jammed for 2 weeks burning up the motor. Oh well. Hope this helps.
May 01, 2008 | Kenmore 73503 Stainless Steel Bottom...
Groaning frig
BFULLAWAY had the answer, I believe. My ice maker does the same thing, groaning and creaking for a few seconds, stopping briefly, then starts creaking again. This is due to ice stuck inside and it will make no ice as a result. Usually I see a piece of ice protruding and knock it out. Happened recently, but I saw no ice. Took a cup of hot tap water (not boiling) and poured it into the compartments where cubes form. (Made sure ice tray was in place to catch water.) I banged on the side and a misshapened cube fell out. Creaking/groaning stopped and unit began to function normally.
Apr 28, 2007 | Jenn-Air JFC2089HE French Door...
Roper RS22AQXKQ Side by Side Refrigerator Logo
Top Roper Refrigerators Experts
John Tripp
John Tripp
Bruce Denton
Gil Shultz
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
