Question about Fisher and Paykel DD605BK Dishwasher
During wash cycle it gets stuck and won't move past the wash cycle. On a regular wash it is at 28minutes and when it is on a fast wash it is at 25 minutes. If I stop it and turn on the rinse cycle it will run through the 12minute rinse cycle with no problems. It is only the top dishwasher that does this, the bottom one is running just fine.
I've got the same problem with the bottom drawer on the DD605. No fault codes were set. I checked the heating element and it produced heat quickly. I suspect that the water temp sensor isn't satisfied, and the timer is waiting for the water to reach the correct temperature. I called F&P's 24/7 helpline and they seemed to have no knowledge of this issue (clearly, it's not uncommon), other than suggesting that I disconnect it from the power supply for one minute, which didn't solve the problem.
Posted on Apr 26, 2010
  • asharmain
    asharmain Jun 08, 2014
    Eventually got it serviced - The element was the problem. Replaced it and now its all good. The rotors were also changed as they had worn out as well. .
    New Friend:
  • 3 Answers
I have the same issue and have tried the power option also. Still gets stuck at 25 mins.
Anyone know what the next step in the cycle is ? to help troubleshoot.
Posted on Mar 14, 2013
GE Washer stuck in wash cycle and not draining.
humming is usually the result of bad motor windings , are u saying it washes for 20 minutes or just stays on that cycle without doing any washing? a non moving drum can be a bad motor coupler or belt if belt driven.
Mar 30, 2015 | GE Washing Machines
Hi my washing machine works perfectly fine but the water don't pump out srew out bottom filter is clean and I clean it on a regular basis. Defy 1300 laundromaid. Thanks please help
You probably have a rock or some object stuck in the pump blades. Take out the pump and turn the blades get out the obstruction
Nov 26, 2014 | Washing Machines
Washing machine won't spin
Sounds like corrosion in the motherboard . Get an electronics serviceman to take a look, could just need soldering point to point connection. Hope this helps.
Jan 14, 2013 | Washing Machines
Washer moves during spin cycle
If this is a newly installed washing machine have you taken out the four big bolts on the back of the machine? It holds the drum to prevent it from moving during transportation when it was delivered. if machine runs during fast spin it will make the machine vibrate heavily causing it to move
May 27, 2012 | Westinghouse WWS833ES Super Capacity Top...
WATER IS COMING OUT FROM THE BOTTOM OF THE WASHING MACHINE ONCE THE WASHING HAS STOPPED, IT DOES NOT LEAK DURING CYCLE AND IT SPINS AND DRAINS FINE..
i would inspect both the hoses on the pump
no leak during cycle is explained because water is moving through them to fast to leak when the machine settles it starts to leak
Oct 15, 2009 | Hotpoint Aquarius WD63 Front Load...
The dishwasher has been running for 3 hours and seems to be stuck on 1 minute left. Upon opening, there was sudsy water remaining in the bottom, but the dishes looked clean. The washer just won't go to...
SHU 53 MODELS To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ ?21? = version 1 with jumper). When wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button. To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display alone). Cycle Countdown display will show ?88″ when REGULAR WASH button is pressed and ?8h? when Delay Start button is pressed. To start testing, press both the SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended, Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added together, (e.g./ ?6? = faults 2 + 4). 0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault 1 = Aqua Sensor (?Sensotronic?) fault 4 = Filling fault F = Filling fault (display occurs during wash, not test) To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty. If water level switch (f1) has failed (opened), display will show fault code ?4″ and unit will continually fill and drain where testing won?t be completed. If flow switch (e5) has failed (opened), display will show ?0″, water won?t heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code ?8″ immediately and testing will end shortly after water has started circulating.
Aug 01, 2009 | Bosch SHU5315UC Dishwasher
Maytag Lat 8434 Top Loader will not cycle
sorry but i dont have much experience with this particular model, so i really have no advice for you, please repost
Dec 03, 2008 | Washing Machines
Maytag Washing Machine Problem
yes it does sound like a bad timer
Nov 25, 2007 | Washing Machines
Maytag LAT9356AAE drive pulley stuck during spin cycle
I had the same problem called a repair guy who told me the transmission is ceased up and the main bearing and seal is shot. Told me that Maytag uses defective parts in their machines and recommended direct-drive washer. Repair would cost more than to buy new. Sorry!
Nov 09, 2007 | Washing Machines
Fisher and Paykel DD605BK Dishwasher Logo
875 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
