Question about Roper Washing Machines
Roper mdl # RAB4232EW1 ser # CH2417891 Rev D Works fine on hot however no cold water. Checked supply valve & proper connections. Is it the Rorary switch or is there an internal valve?
  • pvcruiser Apr 27, 2010
    Exactly the problem.
    Thanks,
    G.W.
    President:
  • 1,554 Answers
The cold waster inlet valve is most likely not working. Set the water temperature to warm; if it turns out to be hot instead of warm then the cold water inlet valve is indeed not working.
Swap out the wiring connections of the two valves to further check cold inlet water valve. Access to the water inlet valve assembly (part number 3360392) requires the removal of the console and the cabinet. Disconnect power to the washer prior to servicing to avoid the risk of electric shock.
Remove the screws attaching the front bottom corner of the console to the top of the washer then slightly pull the console forward to clear the console tabs from the slots on the top of the washer. Once cleared, flip the console to the rear of the washer and disconnect the lid switch wiring harness from the cabinet.
the cabinet is attached to the rear of the washer by two brass-colored retaining clips. Insert the blade of a flat-bladed screwdriver into the lip of the clip on the cabinet side then push the handle rearward to release the clips.
Once the clips are released, open the lid and grab the front rim of cabinet then rock the cabinet forward and move it away from the machine.
The water inlet valve assembly can now be accessed. Swap the wires of the two valves then set the water temperature to warm; if it turns out to be cold instead of warm then the cold water inlet valve is indeed not working.
Make sure the wiring connections are clean a snug fit before replacing the water inlet valve assembly. If you have an volt-ohmmeter, set it to the R X 1 scale and check the continuity of the cold water inlet valve. Replace the water inlet valve assembly if it reads open.
Remove the inlet and outlet hoses from the valve assembly then unscrew it from the rear of the washer. Connect the outlet hose to the new valve assembly then screw it into position in the rear of the washer.
Connect the inlet hoses and reinstall the cabinet.
Bring the cabinet to the front of the washer then slide the front bottom rail of the cabinet under the rail at the base of the machine then lay down the cabinet into position. Make sure the slots in the cabinet sit into the tabs at the base of machine.
Secure the cabinet to the back of the machine with the two retaining clips. Insert the clips into the slots on the back of the machine then push it down into position to the slots on the cabinet.
Reconnect the lid switch wiring harness to the cabinet then align the console tabs with the slots on the cabinet and insert the tabs into the slots and secure the console to the top of the washer.
Connect the water fill hoses properly to the water inlet valve assembly and you should now be able to fill the washer with cold water.
Posted on Apr 26, 2010
  • Jahn27
    Jahn27 Apr 27, 2010
    It's a pleasure to help you. Thanks for using Fixya.
I just installed a tuscany brookesville pulldown kitcken faucet. I cannot get any hot water. I checked the line and I have water to the connection. What do I do?
Hi Wilber- are you using the Watts brand "Floodsafe" auto-shutoff connectors for your hot & cold water supply lines?
Refer to the following link, please: http://www.watts.com/pages/whatsnew/floodsafe_connectors.asp
Feb 23, 2015 | Plumbing
Cold water fills very slowly
Possible the INPUT FILTER of the COLD water is clogged or the INLET valve is faulty. check the power from the board.
Jan 02, 2013 | Roper RAS8445KQ Top Load Washer
Cold water doesn't run into washer on any part of the wash/rinse cycle. Checked cold water line but not plugged uphecked back of washer where water line connects and no clog there either. Makes a...
Sounds like the valve isn't working properly.
One way to test is to turn off the water supplies and at the back of the machine switch the hoses.
Turn on the water and see if you get cold and not hot . If so replace the valve assembly
Jan 23, 2011 | Maytag Washing Machines
We are not getting hot water into our washer. All
Most likely the hot water solenoid on the water inlet valve has failed.
If the cold works - look at changing the solenoid - or the entire valve.
Thakns for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 30, 2009 | Roper RAS6233KQ Top Load Washer
The cold water fill just trickles, I removed filter it was not clogged, hot water runs fine. I checked water flow at faucet, I checked for kinked hose. Did not find any obvious problem. Is there a check...
Good day,
The washer has a dual valve, Hot and cold. The cold side has failed. Valve needs to be replaced. Very common problem.
Before changing, turn off cold water supply, remove cold water hose at the machines valve, and turn on to check for proper pressure.
Dec 04, 2009 | KitchenAid KAWS850L Top Load Washer
LTE6234DO Whirlpool Thin Twin-No hot water
The inlet valve that the hoses attach too the solenoid for the hot side may be stuck closed or clogged with sediment. May need new inlet valve.
Mar 18, 2009 | Whirlpool LTE6234D Top Load Stacked...
Washer only washes on hot
Some washing machines allow cold water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally.
If you're sure the machine is not working the way it used to--or should--check the following.
  • Is the cold water turned on? If not, turn it on.
  • Is the washer getting hot water but no cold water? If so, check to see if the control panel settings are correct.
  • Is there cold water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, you need to replace the valve.
  • Nov 06, 2008 | Roper RAS6233KQ Top Load Washer
    Washing maching won't rinse in cold water
    hi is this hot and cold water piped machine? ie two connections on rear of machine for hot and cold pipes ? if so are your pipes connected properly on machine and the water supplies? if cold supply is connected to hot supply then wash inlet allows water in washer then washes in cold? but when rinse is due? the elec valve that has hot water pipe connected?? is failing to open allowing water flow of hot on rinse so advise recheck pipes for flow of water from both? when disconnected from machine if flow ok then possible valve blocked/faulty hope you can understand above? if you can give more info on your machine it would help to offer a remedy?
    Nov 01, 2008 | Hotpoint Washing Machines
    ROPER TOP LOADING WASHING MACHINE
    Check the lint filter at the end of the hose. The filter is actually inside the washer. My husband cleaned it out and now ours works great. Both hot and cold had stopped running in because of our hard water.
    Sep 20, 2008 | Roper RAS8445KQ Top Load Washer
    Rinse cycle, water won't work
    It sounds like you either use warm or hot water for the wash cycle. If this is the case, you probably have a cold water solenoid problem on your water inlet valve (also known as a mixing valve on some washers). Most people use warm or hot water on the wash cycle. The water inlet valve has two solenoids. One for hot and one for cold. It uses a combination of the hot and cold solenoids to make warm water. The rinse cycle on most washers is a cold water rinse only, however. This would explain why the water appears to flow normally when it fills during the wash, and only trickles when it rinses. If you live in an area that has hard water, or if you use well water, these valves commonly clog with sediment. You can shut off the water, remove the hoses, and attempt to clean the sediment screens to see if the water flow improves. If it doesn't, you will need to replace the valve. The following link epxlains how:
    http://www.fixya.com/support/r600647-replacing_water_inlet_valve_kenmore
    I know the link says this is for a Kenmore or Whirlpool, but also applies to a Roper. A replacement valve can be ordered on line at searspartsdirect.com. Just type in the model number and the part you need is located under the "Controls and Rear Panel" heading as item number 18 (part #285805). This is a very simple and inexpensive fix if you wish to perform the repairs youself. Not to mention, you can potentially will save hundreds by avoiding the labor charges of a service call. I hope this helps you. If you require additional assistance, please let me know. Hopefully, a good cleaning will do and you won't require parts.
    Sep 12, 2008 | Roper RAS8445KQ Top Load Washer
    Washing Machines Logo
    67 people viewed this question
    Top Roper Washing Machines Experts
    Dan Webster
    Dan Webster
    Mike
    Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
