Question about Fujitsu Siemens LifeBook P5020 Notebook
Boot from CF, SD or PCMCIA
Hi
I'd like to be able to boot from somewhere other than the HDD to speed things up and use less power. Is it possible to do this? What are the steps? How do I tell the BIOS where to boot from? I'm using XP.
Thanks - z
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 77 Answers
WHEN YOU START UP AT THE BOTTOM OF YOU SCREEN THERE WILL BE BOOT OPTION BUT IT DOES NOT LAST LING SO STARD UP ONCE AND FIND OUT WHAT BUTTON TO HIT - IT WILL BE AN 'F 1-12' BUTTON - THEN JUST RE-BOOT AND HIT THE BUTTON
P.S. IT POPS UP AT THE BOTTOM LEFT OR RIGHT OF THE SCREEN AND MOST LIKLY F10 OR F12
Posted on Mar 24, 2008
SOURCE:
When i turn on its taking time to get my disk that is my proplem
the best way is to upgrade ur PC , or format your harddisk or apply this settings as follows ===
Speed Up Windows 7 Boot Up Time Don't Try This To Make Windows 7 Faster:
Try ReadyBoost:
  • 1. Speed Up Windows 7 Using ReadyBoost
  • 2. Check ReadyBoost
  • 3. Speed test your SD Card, CF Card, Flash Drive, HDD
Speed Up Windows 7 BootUpdate 04/21: This tweak does not seem to have great effects on your boot time. Instead use a startup programs manager for Windows 7 and remove as many startup programs as you possibly can.
Do you have a dual-core or quad-core processor? Great, let's lower the boot time of Windows 7:
1. Click on Start, enter "msconfig" into the search field
2. Open the "boot" tab
3. Click on Advanced
4. Check "Number of proccessors" and select "2′ or "4′ from the dropdown menu. (obviously, you can only select it if you have a dual-core/quad-core).
Full Image
Speed up Windows 7: Change Taskbar Thumbnail Preview Time1. Click on Start, enter "regedit" into the search field.
2. Goto: HKEY_CURRENT_USER\Control Panel\Mouse
Speed Up Windows 7 Taskbar Thumbnail Preview
3. Double-click on "MouseHoverTime" and change the value to 100 or lower:
Change the mouse hover time to 100 or lower
4. Voilà, your thumbnail previews should appear a lot faster now. For another great tweak to speed up the Windows 7 taskbar, click here.
Speed Up Windows 7 Shutdown Time1. Open the registry editor (enter regedit into search field)
2. Go to "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control"
3. Lower the value (12000 is the default value = 12 seconds) to a value of your choice
Speed Up Application Access - Increase your productivityFirst of all create a folder "QuickStart" somewhere on your PC. Right-click on your taskbar:
toolbar.jpgLocate the folder "QuickStart" (you just created the folder so yo should know where it is) and then click "Ok". You are almost done, but we don't want that ugly text on our taskbar that is using a lot of space, turn it off:
texttitle.jpgRight-click on the new toolbar and uncheck "Show Text" and "Show Title"! Now drag the toolbar to the left until it's below the main icons and you will have something like this:
Sep 01, 2011 | Acer Computers & Internet
Irql not less or equal blue sreen cf-51
reformatting the disk / restore computer back to company settings...is only the resolution for this...
To reinstall your operating system, you must have a CD drive in your multimedia pocket.
Note: CF-51 (Mk2) and CF-51 (Mk3) can also boot to an external Panasonic USB CD drive.
When the laptop is first powered on, the Panasonic name appears in white lettering with the phrase 'Press F2 to enter Setup' directly below it. When this phrase appears on the screen, immediately press F2 on your keyboard. Put the Panasonic recovery CD in your drive and use the arrow keys to move to the boot tab. Change the order of boot so the CD drive boots first. To do this, highlight the CD drive and press F6 until CD drive is the No. 1 listing. Press F10 to save your changes, exit and follow the instructions when your CD starts running.
Jun 14, 2011 | Panasonic Toughbook CF-51 Notebook
GETTING ERROR: REBOOT AND SELECT PROPER BOOT DEVICE OR INSERT BOOT MEDIA IN SELECTED BOOT DEVICE. WHAT DO I DO?
its not detecting your HDD. on boot enter BIOS & check whether your HDD is being detected by the MB. IF not(most possible) then check the power & data cables to your HDD, Check your SMPS too, if SMPS OK then your HDD is corrupted. GET new HDD
Jan 01, 2011 | Gateway 552GE PC Desktop
Bought a cf 27 toghbook wont boot up? any ideas?
- if you hear some ticking sound when u open it most likely it is HDD issue
- if no sound and power is not lit up it is adapter(try to plug adapter to other power outlet)
- try to drain the excess power by removing battery and adapter then press power button for 20secs
- then put the battery in try if it will turn on
(if yes,good)
(if no,put the adapter in - if able to charge and boot up it is battery issue
Mar 25, 2010 | Panasonic Toughbook CF-27 Notebook
Panasonic CF-51,s are becoming common on Ebay but most do not have hard drives or caddies installed.The caddies cost more than the computers & are almost impossible to find for sale.Is it possible to...
I found this via pendrivelinux.com:
http://www.pendrivelinux.com/testing-your-system-for-usb-boot-compatibility/
So try that out. I just got a toughbook cf-51 and will try it soon myself. Mine came with an XP reg code so maybe that can run from a virtual machine inside of linux.
My advice is to resist the urge to drop yours onto cement from a couple of feet. Not quite that tough.
The hard drive caddy is "the catch", for certain.
Too lazy to look into what the hdd connector is for that, maybe there's a cable or converter somewhere.
AV
Oct 22, 2009 | Panasonic Toughbook CF-51 Notebook
Upgrade the Toshiba Libretto 50 CT
if you want to improve the speed of your laptop you could buy a faster harddrive with an higher rpm per minute than the one installed in the unit, that WILL speed up the system:), and yes its possible to boot from the 2gb flash card but i recommend if you are going to use a flash card you get a bigger one:)
Cheers
Jan 04, 2009 | Toshiba Libretto 50CT Notebook
PanasonicToughbook CF-27: PCMCIA/USB 2.0 Card
Unless you can use external power to the usb 2.0 pcmcia card, a CF-27 probly won't handle the load.
Their power adapters are only 15V and the unit itself is a P2 433 at best. It's just pulling too much power.
Sorry
Good luck
Nov 28, 2007 | Panasonic Toughbook CF-27 Notebook
i need help i have a panasonic cf-27 toughbook with a usb cd drive and usb floppy drive ive tried both seperate and with a multi usb connector to boot both but it doesnt find them can anyone help me?
Oct 26, 2007 | Panasonic Toughbook CF-27 Notebook
Connection speed
the usual maximum speed for a v92 dial up modem is around 48-52kbps, although sometimes the way windows calculates the speed can be different, showing higher speeds than is actually possible, hence the 115k that shows when connected. The only way you can get faster download speeds is to download the 'Onspeed' software which compresses pictures etc to enable twice the download speed.
Aug 22, 2007 | Zonet PCMCIA 56K V.92 Modem (ZFM5600-CF)...
1GB IBM Microdrive
I got my 1gig microdrive last Wed. UPS says my Axim is going to be delivered today. I'll let you know how the microdrive performs as soon as he axim is charged.
Sep 13, 2005 | Dell Axim X5 Pocket PC
Open Questions:
See all Fujitsu Siemens LifeBook P5020 Notebook Questions
Fujitsu Siemens LifeBook P5020 Notebook Logo
420 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Ekse
Alun Cox
Cliff itsasecret
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
