Question about Microsoft Windows Vista Ultimate Edition
I THINK I DELETED MY VOLUME BECAUSE THERE IS NO SOUND ON MY COMP. I TRIED DEVICE MANAGER AND ALL THAT OTHER STUFF AND I DNT KNW WHAT ELSE TO DO PLZ HELP ME GET SOFTWARE OR AUDIO DEVICES FOR MY COMP. IM NEW TO COMPUTERS AND I DONT KNOW WHAT TO DO
  • 781 Answers
Let's try a couple of things
first check the obvious and correct as needed:
a. is the speaker powered?
b. is the volume all they way down on the speaker?
c. is the volume all the way down on your computer, (see the corner where the clock is, and look for a speaker icon, it's it has an x clic on it and remove the mute, if no x still click on it and check that the volume is up.
you can look further into volume settings and try to see if there's something muted by doing this
  1. Open Volume Control by clicking the Start button I THINK I DELETED MY - 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Hardware and Sound, and then, under Audio Devices and Sound, clicking Adjust system volume.
  2. Under Main Volume, move the slider up or down to raise or lower the volume.
note: some audio device manufacturers may have specialized sofware, review the settings carefully and confirm that there's nothing muted. feel free to provide more details as you find any and we'll try to help you diagnose the issue.
if there's no speaker icon proceed to next steps
1.assuming that you had volume before try system recovery to revert the changes automatically: the easier way to revert some configuration changes is to do a system recovery to a date prior the change took place.
to do system recovery in vista see here, don't worry about files. no files will be changed if you created those files, only configuration is reverted back to a previous date, as you proceed your computer may be restarted.
2. let's try to figure out the source of the problem and correct it. you said you went to device manager, under sound devices did you see "?" or "!" in yellow?, the ? means that there's no driver for your sound controller, the ! usually means that there's a driver but it's not properly installed or it's corrupted.
if you get ?, you need to go to your computer manufacturer website, to to support, go to drivers and afer selecting drivers for vista proceed to download the audio driver (if you want to post you computer brand and model number, also serial number, we will try to help getting the download page for you.)
if you get !, try to reset the driver by right clicking on that item, select uninstall and restart your system, the driver should go through a self-reinstallation routine as windows loads at startup. if the problem persist try to getting an updated driver from the computer manufacture's website.
finally try this guide tool to check audio problems (the link is for hp but for general tips it may work for other brands
if you are posting back. please describe what you did (or think you did) when the problem appear, the more details the better!
hope this helps!
Posted on Apr 26, 2010
My speaker wont work when i play anytin on internet wit sound i dnt hear a sound from my speakers
1: check the speaker wire. it should connect to a green port at the back of the computer.
2. In control panel open realtek audio device manager. it will tell you where its connected
3. try to configure the speaker from audio device manager on the system tray volume icon
still doesnt work then uninstall the driver for sound card from device manger
restart the computer
Apr 01, 2011 | Computers & Internet
I dnt knw why i cannot hear sound...i have cheked and it is not in mut my pc...plzzz...help me...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
don
Feb 27, 2011 | Audio Players & Recorders
My cdrom was working & from no where it disappeared from my computer....its like it lodt its drivers...i dnt knw what happened...can some one halp plse...?
Right click your My Computer icon>Properties>Hardware>Device Manager
Go into Device Manager and see if you see any error messages (yellow exclamation marks) for the CD Rom. You can try to delete the device and then reboot. Windows should reinstall the drivers.
Jan 08, 2011 | Computers & Internet
Sound is not working
Try doing a check in the device manager for flags.
Remove any flags and remove any external devices.
Reboot the unit in safe mode and see if you get the same error messages2.gif.
If so, you can remove your sound and modem drivers in the device manager and reload from restoration disks or partation. Or you can allow windows to reload the drivers after a reboot.
If you are useing VISTA2.gif the best way is to type in recovery manager, and choose re-install hardware but you should have removed the audio and modem drivers first.
Hope this helps, Please readers rate your techs
Sep 26, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
Dnt knw hw 2 lock d phne for security purposes
Protect your private photos, voice and sound files, videos, confidential documents - just any kind of files on your Nokia 6110 Navigator! Has a desktop companion.
it's a cool software Best crypto
http://www.smartphoneware.com/download/crypto_wm/best_crypto_v2_00_wm.cab
or
http://www.fileden.com/files/2008/10/14/2142396/FileLock.jar
Aug 23, 2009 | Nokia 6110 Navigator Cell Phone
No sound with or without earphones, mute is not on, device manager ok
thanks for you problem,
i think i can help u.
dear frn, don't worry, if device manager looks fine altho you are no able to hear the sound then it is better to uninstall the software driver then reinstall it. coz, if any files of driver is deleted then also it help u to repair it, so plz reinstall the sounddriver. i hope it will ok fine.
ok have a nice day.
good gyee
May 23, 2009 | Dell Inspiron 8000, 8100, 8200 Series...
Duno if i have a sound card, cause i dnt have sound at all
to check if ur system has a Sound card go to Device manager ie rightclick on myComputer>manage>on ur Left handside click on Devicemanager>there u will be able to Find if there is a Sound Card.Or wht u cand do id help us with the Modelnumber of ur system or Moboinfo we can Let u knw about it.
May 08, 2009 | HP (400745-001) Sound Card
I want a sound driver for my old computer...plz help.
Try here.www.soundcard-drivers.com/
You need to know what card you have or is it itegrated into the MB
Good Luck
Kurt
Mar 16, 2009 | Computers & Internet
I Have lost all sounds on my pc but my speakers are working ok.Think it might be my sound drivers
i think it should be the sound drivers ,go to the system configuration through device manager and check the status of your sound device ,if not seen then re-install the drivers and check for possible sound if still no sound let me knw
Jul 16, 2008 | Gateway Computers & Internet
Ext WD500GB drive not being recognised by my computer,but seen in device manager
try downloading this and and scan may be it might locate yr drive since windows can still see it in device manager. and with these u can recover even deleted and formated files. try it
http://services.seagate.com its trial version so u can get a full version n pay little or find similar software but i know yr drive can still work fine its just that we r missing something here.
thank u
May 27, 2008 | Computers & Internet
Microsoft Windows Vista Ultimate Edition Logo
14 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
