Question about HP vp17 Monitor
The base of my monitor keeps separating
The base of my monitor keeps detaching from the monitor itself, and the monitor then falls onto my computer desk. About 2 weeks ago, the monitor fell onto the floor, and I'm wondering if something might have broken off, or is there a way of locking the base onto the monitor neck.
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 80 Answers
Good day to you. This is simply a loose base connector problem. The best way to tighten the base onto the monitor is to apply adhesive pastes like "mighty bond" or you can also tie a rubber bond onto it. Thank you and hope it helps.
Posted on Apr 26, 2010
Testimonial: "Hi thanks for your advice. I've just taped it with some duct tape, and it seems to be holding."
Can't get it to stand up right, my screen keeps falling down and won't stay up
look for the adjustment screw at the base go from there
and download teh manual
Sep 14, 2014 | HP 1730 LCD Monitor
How open va1903wb?
If there are no screws on the rear side to hold it together, the unit will be basically held together by internal latches. If so, then remove the base stand and screws. Then place the unit on a flat surface. Begin at the top side and curl your fingers and press against the edge of the front bezel lip area. With upward force, pull up until you hear a snap sound and the front bezel separates from the rear cover. Do this all the way around until the front bezel is completely separated from the rear cover. Then flip the monitor over face down onto a soft towel. Avoid any object under the screen to prevent scratches or nicks. Then carefully remove the rear bezel.
Jul 22, 2014 | ViewSonic VA1903wb (Black) Monitor
Assemble stand
There is a tab that locks the assembly onto the monitor. Find the tab, press it & unslide the assembly off of the monitor or arm. The rotate properly, reslide into position until you hear it snap the locking tab into position. You should never have to pry this tab to umlock it. -DellTech1
Nov 01, 2013 | Acer Computers & Internet
Can't install base on acer monitor
I, too, struggled with the same issue; however, after a fairly exhaustive search of the Internet, I came across a review that provided the answer: Attach the base to the monitor as you have been doing, but this time, place both base and monitor on the floor--while the base is still flimsily attached to the monitor--and then push down on the monitor. It will secure itself in place. It may seem like you are going to break it, but you won't. It requires little pressure--far, far less than the way we have heretofore been trying to push or jam the base into the monitor. Again, the key is to place the base and monitor (upright position) on the floor, and gently but forcefully push down on the monitor, using both hands, one astride each corner of the monitor.
Jun 02, 2012 | Acer Computers & Internet
How do you replace a laptop screen l555d serial number...its a toshiba.
1. Turn off the computer and remove the battery.
2. Loosen the plastic frame bordering the Toshiba Satellite L555D-S7005 Screen. This frame is attached to the notebook's back shell and holds the screen in place. Pry open two to six small rubber seals from the frame and undo concealed screws.
3. Detach the frame after removing all screws. Hold the bezel from either side of the screen and gently pull it away from the screen and toward you. If the bezel seems to be stuck, find any points of attachment, such as clips or hooks, and undo to detach it from the outer shell. Work with your fingers and go all around the frame to release and completely detach it.
4. Free the LCD panel from its position in the notebook's lid. When you remove the bezel, you will notice that the screen is held in place, enclosed in hinges. Undo screws from either side of the screen to release its attachment to the lid. Place a finger at the top center of the screen to keep it from falling down as you remove the screws. With all screws undone, tilt the panel and lower it face down onto the keyboard.
5. Disconnect the power cable and video cable from the screen. The power cable connects the screen's power source of the lcd inverter to the backlight lamp attached to a side of the panel. Unplug cables from either end of the inverter board and unscrew the board from the base of the screen. Next, find and unplug the video cable a broad, ribbon like arrangement taped to the back of the panel. Pull at the plastic head of the cable to detach it.
6. Remove the screen. With the screen's cables unplugged and inverter board removed, it is completely detached from the notebook's display assembly and may be safely removed. Pick up the panel from the keyboard and keep it to a side.
7. Orient the replacement screen by bringing it to the work area and aligning it to the laptop's shell. Gently rest the screen on the keyboard and attach the power cable and the video cable. Raise the screen and attach the inverter board to its base. Plug in the inverter board's cable to the screen's backlight lamp. Screw the screen in place and reorganize the display assembly.
May 04, 2011 | Toshiba Computers & Internet
Is it possible to remove the monitor standfrom na Acer AL2016W monitor
Im under the impression you want to wall mount the monitor. Ive done this with a few monitors it should just unscrew and basically fall off? Have a look underneath the base for any screws they will be somewhere keep looking.
Oct 31, 2009 | Acer AL1916W 19" LCD Monitor
Don't understand how to detach base
Just lay down the monitor, wirh the screen facing upwards and the swivell base facing your .
Press the four claps that are fixing the monitor to the the swivel base to release it.
Download the ACER AL1511 Install Guide if you need to.
Aug 24, 2009 | Computers & Internet
How to detach the screen from the base.
Here is what I did on my last 2 moves with a 22" LCD.
Just wrap it in soft blanket like velour or a comforter and put it in a box so it doesn't move around. You could take off hte base but usually at risk. Most of those bases clip on and aren't really easy to slide out or meant to take back apart. You risk more damage taking it out apart then just wrapping it securely and putting it in a box.
May 29, 2009 | ViewSonic VE170m (Beige) 17" LCD Monitor
I need to detach the stand of HP 1950 TFT monitor screen and then mounth the monitor on a special stand. How can detach the monitor from the hinge seen below the screen.
Removing the base is covered in the manual. You can download a copy from HP here.
If you don't like clicking a link the full URL is
http://h20000.www2.hp.com/bizsupport/TechSupport/CoreRedirect.jsp?redirectReason=DocIndexPDF&prodSeriesId=3463255&targetPage=http%3A%2F%2Fbizsupport2.austin.hp.com%2Fbc%2Fdocs%2Fsupport%2FSupportManual%2Fc01446658%2Fc01446658.pdf
If I have helped you, please take a moment to rate this solution. Thanks for asking here!
Mar 18, 2009 | HP w19 19" LCD Monitor
Disassembly for shipping
As per page 4 of the User's Manual from Acer:
Detaching the Monitor
If you need to repackage the monitor, please separate the monitor and base, and restore them to
the carton. To detach the monitor:
1. Unplug the AC power cord to make sure the power is off.
2. Pull the 4 hooks on bottom side of the base and hold.
3. Separate the monitor and base and put them into carton.
Jun 19, 2008 | Acer AL1716B 17" LCD Monitor
HP vp17 Monitor Logo
85 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
