Question about LG Washing Machines
We have a front loading machine. The model number is 7 kg WD-12 380TP It is a foreign make and was given to us. We do not have the Performance Manual and do not understand how to operate the dials on the front. Mr D. Wright
  • LG Master
  • 12,061 Answers
Www.shema.ru/0_s/wm/samsung/P1091GW.pdf Above is a generic service manual, in case you have any problems, all Washers are the same basically, in troubleshooting.
Hopefully that will help you sort out you problems?
http://www.devicemanuals.com/guide/Laundry/Indesit/INDESIT-LAUNDRY-IWDE12-Instruction-Manual-==TVRJek1ESTA=.html
There is your manual, hopefully, these will help you.
Posted on Apr 26, 2010
Washing machine
I see a little confusion here...there is LG WD-1280FHD which is the MODEL number, WD= washer-dryer, LG=Life's (not so) Good. The "F" is for Front Load... HD for dryer Heated Dryer. The numbers correlate to date and assembly plant location. IDK this other number your showing is a Part Number
Mar 15, 2014 | LG WD-1280FHD Front Load Washer
I have ifb 6 kg front loading washing machine.my problem is that whenever i put clothes in it ,after 30 min of washing it shows error 7..how to fix it? please help
You will need to type into your search engine the '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
Dec 02, 2012 | Washing Machines
How much air (p.s.i.) should there be in the front and back shocks
Hi.
Depends on what you want to get. In theory the fork can be between 0 and 43 psi. In practice if you put 40 psi it will be completely stiff and seals may start leaking.
In practice the front take 0 to 12 psi, and rear shock from 7 to 21 psi.
If you need street performance put more pressure. Settings for comfort in long travels will require lower pressure.
Here tables from service manual:
FRONT
REAR:
Rear shock absorber air pressure can vary from 0.5 kg/cm2 (7 psi) to 1.5 kg/cm2 (21 psi) as the road conditions become more severe or the load increases.
For the front here below the procedure from service manual. I suggest staying far from the 43 psi limit suggested if you do not want to break the seals.
8. Make sure the front wheel is off the ground and inflate the forks to 0-0.4 kg/cm2 (0-6 psi). Do not use compressed air; use only a small hand-operated air pump.
CAUTION
Never exceed an air pressure of 43 psi (3.0 kg/cm2) as damage may occur to internal components of the fork assembly.
Jun 12, 2011 | 1986 Honda VF 500 F
Could I "stack" a front
i would not recommend stacking one machine directly on top of another. there are various issues with weight, and movement due to vibration.
what you can do is built a solid "workbench" that you can fit one machine under, and then put the other machine on top of the "bench"
personally i would overbuild the bench, using 2" by 1" wood for the frame, braced and bolted to the wall for stability, and use a 1"thick worktop forv the top of the unit. on the top surface, i would also put a 3/8" wooden beading strip about 1/2" fron the outside edges of the worktop to stop the machine moving with vibration and falling off.
i have done this a number of times when space is limited, although i find it much easier to put tehr dryer on the top as it is the lightest of the 2 units.
hope this helps
Apr 01, 2011 | Washing Machines
I have a Whirlpool 7 KG, Front Load Washing Machine Model SUL 701. Need a USER'S MANUAL for this. Kindly suggest.
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C
Mar 05, 2011 | Washing Machines
7 kg intellowasher noise when in wash cycle
if its a direct drive remove the rotor and see if theres a loose magnet etc,hope this helps
Feb 21, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
