Question about Samsung SyncMaster 740N 17" LCD Monitor
Samsung 740N blank screen
Samsung 740N began buzzing at startup, otherwise normal function, buzzing faded, unit continued operating as normal. Then suddenly, screen went blank, power indicator light is on. No buzzing. Currently not connected to VGA, but but there isn't a "no signal" message - nothing.
Suspect backlight power system. ("ballast"). Also help to disassemble and replace part(s).
louearl@shaw.ca
  • Samsung Master
  • 1,606 Answers
That sounds like a capacitor or maybe a mosfet died. Usually only capacitors 'sing'.
first you need to confirm it is the backlight section that died. simple visual inspection. You want the monitor plugged into a running booted computer. If you have anything that will do dual screen that lets you know what and where something should be on the screen being tested.If not anything will work. Let the computer boot up and then you will need to get close and near an edge. What you are looking for is a ghost image of the normal desktop. You may even be able to see the mouse move around. This is the actual picture produced by the lcd. It is very faint. The backlight acts somehwat like a projector bulb and shines through the lcd panel. So if you can see anything then your backlight or the backlight power are the problem. I'm in BC so its hard to reccomend any place for parts. Most of the ones I have fixed the parts were out of California.Cost should be about $70-$100.
If the backlight isn't the problem then it is usually a power section problem. The parts are cheap but the time to find the bad one can cost a bit. If you can find a place to fix it get an estimate. Then check out the replacement price of a new monitor. The prices have dropped and sometimes it isn;t cost effective to repair even a backlight on some models.
Posted on Apr 26, 2010
Testimonial: "Sounds like he went right to the problem. I think I can take it from here. "
Frig buzzing even when it's unplugged
I have encountered numerous issues like this one. Normally, when you unplug a refrigerator, all mechanical noises should cease operating. A buzzing sound may be emanating from some other appliance, clock, or other product in close proximity, transmitting a frequency toward your unit. Basically if there is no power supplied to the unit, it virtually can make no noise.
Oct 07, 2017 | Samsung Refrigerators
F 56-2 ERROR CODE
Key Operator Mode
To the Key Operator
The key operator is trained to handle all special key operator functions that are not
accessible to the general user, such as monitoring overall copier activity, machine
performance, and service information; modifying machine settings; and controlling user
activity, for billing purposes.
A unique 4-digit key operator password is normally set by service at installation. If the
unique code is not set by service, the copier will not display Key Operator Password
Entry Screen when the Key Operator mode is being accessed, and a key operator
password will not be required. A service-set 8-digit ECM master key code must be
entered by the key operator to access the Electronic Copy Monitor functions, and a
service-set 4-digit Weekly timer master key code must be entered by the key operator to
access the Weekly timer functions.
To ensure the security of Key Operator mode, it is recommended that you establish a
unique key operator password, along with the key operator ECM master key code and
Weekly timer master key code, and keep them in a confidential file.
r HELP is unavailable in the Key Operator Mode
Key Operator Mode Screen 2
NOTE: The function number [12] Call remote service center and [13] Save ECM data to memory card on the
Key Operator Mode Screen will be dimmed and cannot be selected on the copier without the remote
diagnostics activated.
Key Operator Password Entry Screen Key Operator Mode Screen 1
Key Operator Mode 13-3
Key Operator Mode
To the Key Operator (continued)
How to Access the Key Operator Mode
1 First, be sure the copier power switch is OFF.
2 Then, turn power back ON while pressing the [HELP].
The Key Operator Password Entry Screen displays when the 4-digit key operator
password is set by service.
Otherwise, the Key Operator Mode Screen displays without the password
requirement.
3 If the Key Operator Password Entry Screen is displayed, use the keypad on the
touch screen to enter your 4-digit key operator password; then touch OK, to display
the Key Operator Mode Screen. (See note.)
If the key operator password is not valid, check with your service representative.
4 To display menus [11] to [13] of the Key Operator Mode Screen, touch the lower
arrow key. To return the menu [1] to [10] of the Key Operator Mode Screen, touch
the upper arrow key.
5 Make setting changes from the Key Operator Mode Screen, as described on the
following pages.
NOTE: If an invalid Key operator password is entered, continue by entering the valid 4-digit password.
13-4 Key Operator Mode
Key Operator Mode
Function Menu Map
FUNCTION MENU SUB FUNCTION MENU AND SETTING OPTIONS
[1] Initial setting [1] Copy mode: [RADF; 1-1; 1-2; 2-2; 2-1]
[2] Copy density: [AES; manual]
[3] Lens mode: [AMS; ratio 0.33~4.00]
[4] Paper tray: [APS; trays 1, 2, 3, 4, 5, or Multi-sheet bypass tray]
[5] Output: [sort; group; staple-sort]
[6] Staple: [Normal 1 position left; Normal 1 position right;
Normal 2 positions left; Normal 2 positions right; Upsidedown
1 position left; Upsidedown 1 position right; Upsidedown 2
positions left; Upsidedown 2 positions right]
[7] Image scan: [Normal mode; High mode; Very High mode]
[2] Lens mode ratio [User Set ratio]
[3] ECM [1] ECM Password and User name setting
[2] ECM Count limit setting
[3] ECM Count Reset
[4] ECM On/Off Setting
[5] Copy-Limit-reached effect
[4] Lock/delete [1] Lock Job memory
job memory [2] Delete Job memory
[5] Paper type [Recycled; Colored; Letterhead; Special; Labels; Invoice; Legal;
Ledger; Blank]
[6] Control panel [Dimmer; Brighter]
contrast
[7] Key operator
[5-digit number]
Tel. No.
[8] Weekly timer
[1] Weekly timer On/Off setting
[2] Summer time setting
[3] Date & Time setting
[4] Timer setting
[5] Timer action On/Off setting
Feb 22, 2013 | Konica Minolta Copier Toner 7055/7065...
When i switch my laptop on it only shows SAMSUNG startup screen then the screen goes blank... Any help please...Thanks!
is your base unit still working when screen remain blank? if so it is related to video. consult a good laptop technician near you.
Dec 03, 2012 | Samsung RF510-S01 Notebook
Vertical lines on screen looks very bad
maybe your TV have a deffective LCD PANEL,cause those are the systoms of the deffective lcd panel..better to put your unit the nearest service cnter or well trained technician to do the job,,goodluck
Feb 25, 2012 | Samsung SyncMaster 740N (Silver) 17 inch...
740N blank screen
I would inspect all the caps, if you find even one bulging top/leak you should replace them as a set.
See failed SAMSUNG here, use good caps, such as PANASONIC FM or FC series from DIGIKEY.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Service manuals:
http://elektrotanya.com/?q=showresult&megnev=SAMSUNG megnev2 =% 20 & 740N = & Category = & kat2 schematics
May 02, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
Unit crashes then will not restart after being unresponsive.
After removing the battery, I discovered a small brass reset button, about 3 mm in diameter, near the battery connection terminal. This was gently pressed with a pen for 15 seconds. After refitting the battery, the unit was fully functional again. This reset results in needing to set the clock again. No other settings are affected.
Jan 08, 2010 | Archos 504 500870 Digital Media Player
Need ecm code for konica 7055 or a reset code is there an override code?????
Key Operator Mode
To the Key Operator
Key Operator Mode
requirement.
following pages.
Key Operator Mode
Function Menu Map
[3] ECM Count Reset
Ledger; Blank]
contrast
[7] Key operator
[5-digit number]
Tel. No.
[8] Weekly timer
[4] Timer setting
Jul 23, 2009 | Konica Minolta Office Equipment & Supplies
Acer Aspire blank screen
yes its a virus that's blocking explorer
a complete clean xp installation is needed to fix this problem.
rate plz
Mar 09, 2009 | Acer Aspire 5315 Notebook
My monitor goes blank repeatedly
1. First u can check any dry points in power supply board and controlling circuit.
2. check all connectors (connected properly)
3.To replace front pannle Micro switches.
Oct 04, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Samsubg 17"LCD 740N monitor flickers
It sounds like the CCFLs (backlight lamps) in the monitor are failing. You might be able to get them replaced by the manufacturer if it's still within warranty. Otherwise the fix might involve an expensive technician and replacement parts.
Jun 10, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Samsung SyncMaster 740N 17" LCD Monitor Logo
2,528 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
