Question about Sony STR-DG910
MY KNOBS ON THE RIGHT OF THE REACEIVER BROKE OFF.... 1 FOR BASS AND TREBBLE ONE FOR IMPUT SELECTION HOW CAN I GET IT FIXED
    President:
  • 1,348 Answers
That depends if the knobs or the shafts are broken.the knobs are easily replaced as they just pull off. the controls is a different problem as they are soldered into the pc board.the input selector switch will have alot of pins and the bass and treble 6 pins each.the front panel has to be removed,the lock nuts taken out and sometimes the input selector has a small pc board that is wired to the main pc on a connector,and the replacement comes with the pc board.the parts can be got from sony parts or an authorized repair depot.unless you are really good with electronics,it is best left to a pro to fix,the power supply in that unit runs on over 100 volts dc
Posted on Apr 26, 2010
I play my music on low and it has bass wen i turn the radio up it starts hiting only certain bass notes the lowest dont hit hard it starts sounding weird???? i have it hooked to a audiobahn aw1206t...
sounds like you have some wires crossed. check your radio setting and make sure that the subs are only playing bass and no trebble. buy some new rcas
Mar 10, 2010 | Nitro BMW-486 Car Audio Amplifier
How to set up trebble or bass without a remote on denon dvr 688?
1. Press systems setup. Then press Enter.
2. Press the left or right arrow to select then press enter.
3. Press up, down, left or right and then make your selection and press enter.
4. Press enter to confirm selection.
5.
Oct 28, 2009 | Denon AVR588 Receiver
How do you adjust the bass levels on a Yamaha HTR6130 receiver? I can get the display to show Bass 0db, but what button changes the settings?
When you touch tone button on your front panel repeatedly, you will get two option for setting bass and trebble, when you select Bass immediatly press your updown Sound field Program Button.
Please note:for better sound if your using Small front speaker keep bass to 0db and select the low frequency through sub woofer and program manually LFE from only Sub woofer and addjust CUT off frequency of Subwoofer to 160 and incase if your bass is not clear put it into rev mode.
Oct 05, 2009 | Yamaha HTR-6130 Receiver
How to make the eq so that speakers play nice and loud so the subs don't over power them?
On an eq, the level farthest left is for bass. Then all the way right is for trebble.
Oct 01, 2009 | Car Audio & Video
Bass control knob broke off, what di I do?
You don't list the brand, but you can buy replacement knobs for many brands from http://www.pacparts.com/. Note that while the parts are very reasonably priced, you may end up paying $12 shipping for a $1 knob. If it doesn't have to be a matching knob, you may be able to find one that will fit on a radio at a yard sale or junk yard. Another possibility is to try Radio Shack. http://www.radioshack.com/search/index.jsp?kwCatId=&kw=knob&origkw=knob&sr=1
Aug 17, 2009 | Parts Express Car Audio & Video
How do I adjust the trebble on my Denon Receiver?
go to sound parameter in your parameter menu under the setup. There should be a tone control option, when there you can adjust the bass and treble by a variable decibel range. the range is -14db to 14db.
Jul 07, 2009 | Denon AVR588 Receiver
BASS,TREBBLE,MIDS SETTING
Hello 1rocknroller,
Press the mode button repeatedly to select BASS, TREBLE, SUBW, BALANCE, FADER, DEFEAT, AND VOLUME. When subwoofer mode is set to off, it's level cannot be adjusted. If DEFEAT is set to ON, the player returns to factory defaults. Turn the volume control to adjust the setting. If no adjustment is made within 5 seconds after selecting, the player returns to normal mode.
Hope this helps.
May 29, 2009 | Alpine CDA-9856 CD Player
Bose home theater
It may not have bass and treble controls, since most newer TV's now have these adjustments. Play around with your TV and see if you can find bass and treble adjustments from the remote.
Dec 24, 2008 | Bose Cinemate Digital Home Theater System...
Adjusting audio
If you are wanting to adjust the bass and trebble etc. just push in the left joy stick and either push it right and left for the selections and turn it up and down to change or use the touchscreen function to adjust
Sep 30, 2008 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
BASS KNOBS
please bring a good brand lubricant contact cleaner and apply it in knob and move it forward and back.(you can get it from radio shack near you).
May 30, 2008 | Pioneer DJM-600 Silver Professional DJ...
Sony STR-DG910 Logo
135 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
