Question about Polyview S17E 17" LCD Flat Panel Monitor
There is no image on the screen at all even when its all set up
Poly view doesn work propley
    President:
  • 1,561 Answers
Is it that the when you power on the lcd monitor, the led power button powers on but no display? if it is, the means the picture board of your lcd monitor is malfunctioning.
It could be that the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Posted on Apr 26, 2010
  • Sulaimon Jimoh Olayemi Apr 26, 2010
    Since the monitor power on but no display of any image, it means the picture board of your monitor is faulty and will need to be replaced.
    Take care
Can't view photos on camera screen
Hello Celia.
Try going to the menu and look for the "storage" setting. Check to see if it is set on memory card or internal. Switch the setting to see if you can access the photos.
If this doesn't work your 30 photos may be in a folder "type" your Canon cant access. Try moving them to a "Canon" folder that your camera created.
Hopr this helps. Dale
Dec 21, 2011 | Canon IXUS 960 IS Digital Camera
Power Supply for Poly view V372 lcd monitor.
can you find the part number from the power supply?
Oct 24, 2008 | Chi Mei Corporation Computers & Internet
My webcam doesn't work. The green light shows up next to it, but when I come to view through the camera all I can see is a black screen. It literally doesn't show anything, even lights.
Hi cazjenks...
Try this solution to your problem
Follow the instructions below to use your webcam
Click on Start then >Control panel>hardware and sound >device manager>imaging devices>web cam....enable it
Another way is to use a IM application like Yahoo messenger,NetMeeting,etc. They will have video capabilities that will work with your webcam.
Please take time to rate me thumbs up
Sep 10, 2011 | Computers & Internet
I have a 19in Emerson Flat Screen TV that I am using as a PC Monitor and it isn't using the full screen. How do I fix it to use the whole screen?
You might not be able to. If the screen size doesn't adjust with the wide/view mode/picture format button on the television remote control you have to change the resolution on the pc. You right click on an empty spot on the desktop, choose properties, and then choose the settings tab. A lower resolution will cause the image to fill the screen but the icons get really big. The image isn't as refined. However you may be able to play around with it enough to find a good enough resolution and a view mode with the Emerson remote that will work out for you (a combination of the two).
May 31, 2011 | Televison & Video
Takes pictures but you cannot see image in lcd screen
This model only lets you see the image in certain modes. Test if it is properly working by changing the image mode to "P" and pressing the "Set" button (its in the middle of the arrow keys if you're having difficulty finding it. That should display the image on the LCD screen.
If that doesn't display an image, press "Menu" (upper left hand corner) and press the right arrow 4 times to get to the wrench with two dots menu (says "LCD brightness" on the first line. Press down 5 times and select Live view function settings and press "Set". Make sure the first line is set to enable. This should resolve the issue.
Please leave feedback if this was helpful, thanks.
Apr 18, 2011 | Canon EOS Rebel XSi Digital Camera
The touch screen doesnt work propley if i press for example 4 the * key gets pressed.. its jusst not write i cant even check my text please help me out.
try looking for the pen calibration in the settings menu, after you have located it perform what is said on screen, just follow the instructions, if that doesnt work, it means that your touch screen has physical damage already and the only thing you can do is to replace the lcd assembly.
Jun 01, 2010 | LG KP501 Cell Phone
Where is the thermostat located
Coolant Pump, Exploded View 42398463
IMAGE REFERENCE:
  1. 2O Nm (15 ft lb)
  2. Coolant pump pulley (For poly-ribbed belt)
  3. Coolant pump
  4. Gasket (Always replace)
  5. Thermostat
  6. Connector pipe
  7. 0-ring (Always replace)
  8. Clip
  9. 10 Nm (7 ft lb)
  10. Flange
  11. Coolant pump pulley (For V-belt)
Jun 05, 2009 | 1996 Volkswagen Jetta
Ps3 doesn't work propley with samsung hd tv
keep ypur finger on the off button for 20sec
Jan 11, 2009 | Sony Playstation 3 (PS3) Console
Viewing screen is black
Defective ccd imager!! company will replace this ccd imager free of charge. Year 2002 up to 2005 released unit has a factory defect ccd imager. the company recalled those units and replaced with a stronger version of ccd imager ( they are still doing it). check it out.
Nov 08, 2007 | Canon PowerShot SD700 IS Digital ELPH /...
Polyview S17E 17" LCD Flat Panel Monitor Logo
66 people viewed this question
Top Polyview Computers & Internet Experts
David Payne
David Payne
Are you a Polyview Computer and Internet Expert? Answer questions, earn points and help others
