Question about HP Officejet 6310 All-In-One InkJet Printer
There is double printing or shadow-like printing with my HP 6313
Since my HP6313 chewed up some paper that was subsequently removed, I have noticed a permanent double printing or overprinting or shadow-like printing with each character
    Director Badge:
    Uploaded 100 video answers.
  • 1,751 Answers
Change cartridge
the print head of our cartridge is damaged
Posted on May 01, 2010
Epsom stylus sx610fw insists there is a paper jam - none to see, but will chew up ordinary paper when working. is there any way to open it up more to look for torn paper that could be registering as a
Yes it can be repaired, but it will most likely take a sensor to do it, this is a common issue. I think the way it works is it senses the force required to turn the roller, if the sensor or the chip it sends its signal to is defective a false paper jam is triggered and the printer stops printing. The problem here is with printers being so cheap to buy why not just replace it. The last time i got a printer it was free with the rebate, and it was a Canon "all in one" that was far better than the HP it replaced. Your decision.
Jan 19, 2012 | Office Equipment & Supplies
Orange light blinking, cleared paper jam, changed printer cartridge, won't print subsequent documents.
Double check all doors/ rollers for small pieces of paper stuck in the rollers. Sometimes just opening the door in question and closing will reset the paper jam sensors. Paper jams can be smaller than your pinky finger nail. So double check,
Comment if it still isn't working.
Oct 21, 2011 | HP Deskjet F335 All-In-One InkJet Printer
Canon mfc 4350 d printing with shadow.or double printing is coming out .how to solve
I have had a similar problem since purchase 1 year ago. Mine has this issue on first 2-sided copy I print, problem is on the second side only. I disassembled the machine and could not discover the problem. However I did notice one paper transport roller (there are $) was askew. After reassembly all was well for about 40 copies then problem returned, I will remove that transport roller and retest machine
Jan 10, 2011 | Canon ImageCLASS MF4350d Laser All-in-One ...
Hi, the trouble with my hp 1022 is when i print something, in the printed paper appears a shadow from the original text. can you help me. thanks
use plane paper of 60-80 gsm if your printed paper is offset/screen print it will repeat and shadow appears because of high temprature in fussing unit.
Feb 03, 2010 | HP LaserJet 1022 Printer
HP Laserjet 4plus chewing us paper
This is most likely cased by a dirty paper feed path so it will need cleaning and blowing out. Make sure that all the internal paper guides and separators are free of obstruction. Make sure that the fuser area is clean that the internal paper guides are ll in place and operate freely. Also clean it with a vacuum with a soft haired brush tool to avoid any damage. Also fan the paper before using it and do not overload the print paper tray. Also check that the pick up rollers are not work or contaminated with dirt / debris etc. Also make sure that the print tray is not overloaded and make sure that the paper is not to tightly held by the tray side guide.
Sep 30, 2009 | HP LaserJet 4 plus Printer
Need drivers for hp6313
driverscollection.com
drivers-download-driver.com/tag/hp-6313
h10025.www1.hp.com/ewfrf/wc/softwareCategory?.
Either one of these links you can copy and paste in your address bar which will bring you to a driver download site.
Sep 15, 2009 | Office Equipment & Supplies
HP LaserJet 4700N
paper jam on tray 1. How to open the back part of the printer.
Oct 17, 2008 | HP LaserJet 4700N Printer
Printouts with shadow
Two things - Fuser or cartridge - stop print halfway in machine, if fault occurs before paper has gone threw the fuser then it is a faulty cartridge, if print is ok before fuser (the hot bit at rear) but gets doubled up after fuser then the hear roller in fuser are faulty change fuser....but 95 % of the time it is due to dodgy refill cartridge or worn cartridge (the rubber blade inside cartridge fails to apply enough pressure against drum to clean away old image  hence duplicating itself onto your nice clean paper! Try a known good cartridge if in doubt..
Oct 16, 2007 | HP LaserJet 1300 Printer
HP Officejet 6310 All-In-One InkJet Printer Logo
586 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
