Question about Sony Playstation 3 (PS3) Console
My ps3 slim reads corrupted data - Sony Playstation 3 (PS3) Console
  • 1,472 Answers
Veloz_raptor
If you are getting the corrupted hard drive message this means that you have corrupted data on your hard drive. The link below will help you address this.
http://www.fixya.com/support/r4853494-fix_playstation_3_corrupted_hard_drive
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Posted on Oct 09, 2010
5 Suggested Answers
SOURCE: ps3 freezes and says i have corrupted data but it
so i had the same prob all u got to do is delete your data it will only delete the si9ngle player data cuz multiplayer data is saved on ur psn account your welcome if you dont know how to delete it goto games>saved data utility>cod5>(triangle)>delete if you want to say thanks my psn name is kakashi1012
Posted on Apr 14, 2009
  • 5 Answers
SOURCE: ps3 system update data corrupted
Hook up the external to your USB port and copy everything over. I had to do that when I installed a larger hard drive in my PS3
Posted on Jun 21, 2008
  • 27 Answers
SOURCE: PS3 SLIM FREEZING
The problem is update 3.30. Whatever it contained, it hurt the systems ability to read from the BD Drive. I suspect you can play downloaded content forever without freezing. If correct, the is currently no fix. I am in the same boat. Our only hope is that Sony will come forward with a fix. Currently, if you call them they will say your system is faulty and you need to send it back to them for a swap.
Posted on May 02, 2010
issken
  • 1472 Answers
SOURCE: DATA CORRUPTION ON PS3 CODE 80029209
cwsgds
Issken
My Ps3 slim won't play gta4 and the episodes from
appallonia3
Unfortunately this is a sign that the data on the drive is corrupted or the drive its self is goning bad. The link below tell you how to fix the issue.
Issken
Aug 11, 2011 | Sony Playstation 3 Slim Console
Tip
How to remove the hard drive on a Playstation 3 Slim Removing the hard drive on...
Removing the hard drive on the PS3 Slim is simular to removing the hard drive on an original PS3, however the drive is in a different location.
Note if you are upgrading PS3 hard drive you will need to back up your data first so that you are able to put your files back onto the new hard drive.
1. Make sure you have all your cables unplugged from the PS3.
2. Turn the PS3 upside and locate the hard drive access door (it will be at the front of the system next to the small info sticker).
3. Ether with your finger nail or a small screw driver lift up the cover.
4. Next carefully unscrew the blue screw. Note you will want to make sure you get the right size phillips head to make sure you do not strip out the screw head. On the few systems I have seen a PH1 head you be the right size you need.
5. After you have the screw removed you will want to slide the hard drive cover to the right to expose the hard drive.
6. Next pull down on the lever and pull strait back in the drive caddy to remove it from the PS3.
If you have remove the drive to upgrade the drive you will want to unscrew the drive from the caddy and install your new drive.
If you have removed to corrupted data on the hard drive the link below will walk you through formatting the hard drive on your computer just skip to step 4 as the first steps are for removing the hard drive from the original PS3.
How to fix PlayStation 3 corrupted hard drive
on Oct 08, 2010 | Sony Playstation 3 Slim Console
My ps3 slim gets stuck in the wave screen (the fisrt 1 after choosing user) no menu no nothing i cant even turn it on,what can i do?
gastycure
If the system is freezing up at the main menu this is sign that you have corrupted data on your PS3. The link below will help you fix the problem.
Issken
Jul 21, 2011 | Sony Playstation 3 (PS3) Console
My ps3 slim wont load any of my games and it freezes when i turn it on. It wont let me look at anything, play an music, or anything. It wont even turn off. What do i do?
all you have to do is pull out the plug and then when u turn it on it wud say that the system did not take of properly and u just press ok. after that u just go to system settings and chose format data.it says that it will delete data but it wont by just pressing your hand on the eject button. it will then delete all the corrupt data and u will still have your tropies and saved data.it shud then read disc and stop freezing.
Mar 04, 2011 | Sony Playstation 3 (PS3) Console
When I start up my PS3 slim it goes to a screen saying my drive is corrupt it lads to 100% then turns the system off automatically then when it turns on it brings me to the same screen about the drive...
Guest
If you are getting the corrupted drive message this means that you have corrupted data on your hard drive. The link below will help you address this. If you still have trouble you may need to replace the hard drive.
Note the link below I made is based off the original PS3 but everything still applies. If you need the actual physical steps I just got access to a Slim and will be updating the steps this weekend. Also with your Slim it should be in warranty so if the hard drive is bad I would contact Sony's techsupport about getting it replaced.
Let me know if you have any more problems or quesitons
Issken
Jul 20, 2010 | Sony Playstation 3 (PS3) Console
PS3 SLIM FREEZING AFTER 15-20 MIN OF PLAY OR MOVIES.I PERFORM FILE SYSTEM RESTORE FROM SAFE MODE AND IT SAYS CORRUPT DATA.I RESTORE..AND 15-20 MIN LATER..IT FREEZES AGAIN.
Apr 30, 2010 | Sony Playstation 3 (PS3) Console
New slim ps3 model have an error code of 10710d23 other ps3 is fine its a fat one but works fine 03/24/2010
Be sure to folleow these instructions to the letter, you could damage your PS32_bing.gif if you choose the wrong option! I do not take any responsibility! Please proceed at your own risk! If you read and follow the instructions exactly you should not loose any data! Feel free to ask questions if you are confused so you don’t make a mistake!! Sorry, I had to say it, I don’t want anyone mad at me if they make a mistake, don’t back up their data and erase it, and then blame me…
The current version of the ps3 firmware has a “recovery console”.
You access it by
1. Start with having the system in standby (redlight is on)
2. Hold the power button down; the system will turn on and turn off once again.
3. Press and hold the power button again and keep holding, it will beep as it turns on and then it will double beep. When you hear the double beeps immediately take your finger off the power button (if your system turns off before you get a double beep just try again and hold the button, it should double beep the 2nd time you try)
4. You will be prompted to plug in your controller via USB and then hit the PS button
You will now have a screen with these options
1. Restart System: Restarts the PLAYSTATION®3 System.
2. Restore Default Settings: Reset all system settings back to default.
CHOOSE THIS ONE 3.Restore File System: Checks for corrupt/missing system files.
4. Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
5. Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
6. System Update: Update the PLAYSTATION®3 System
IT IS VERY IMPORTANT THAT YOU DO NOT CHOOSE THE WRONG OPTION HERE OR YOU WILL LOSE ALL YOUR DATA. The one that fixed my blu-ray drive is option 3: RESTORE FILE SYSTEM
I REPEAT CHOOSE RESTORE FILE SYSTEM
After this, it is going to restart and bring up a screen reading something like “you have Corrupted System Data. Your PS will now replace this data” Then you choose continue and that should be it.
This option reinstalls the system files and drivers inside the PS3 with the original ones that are stored on your hard drive. In this case, it replaced a corrupted driver for the blu ray drive thus fixing my issue and hopefully yours!! This option will only replace all system files thus saving you from loosing any data that’s stored on your hard drive. Again this option does nothing to your hard drive it reads a file from the drive and rewrites it to the PS3 system.
Here is a video of the recovery screen.
www.youtube.com/watch?v=m0SPmkV-jco
If you want a more technical understanding of what this is really doing continue reading. DO NOT NEED TO READ THIS TO COMPLETE REPAIR. The PS3 does not boot from your hard drive as a computer does. It has a flash memory like a cell phone that stores all system files and system firmware updates that you get when the PS3 updates. This is why reformatting your hard drive will not fix your problem, none of the system files are stored on your hard drive (ex. XMB, system firmware, etc.) nor do they run from the drive. However, your hard drive does contain a full backup of your SYSTEM files and thus when you choose option 3: RESTORE FILE SYSTEM it rewrites the original system files from your drive (which aren’t corrupted) back to the flash memory, which is corrupt, thus solving the problem.
Mar 25, 2010 | Video Game Consoles & Games
I have got a new playstion3 slim 120gb the
You access it by
Mar 21, 2010 | Sony Playstation 3 (PS3) Console
I HAVE SOME CORRUPTED DATA IN MY MEMORY STICK
check if magicgate in your memory stick is supported, if not...it´s an alternative MS...but you can try to format all your memory stick using your psp , PS3 or even with a pc MS card reader...re-install all ms softs...
Sep 14, 2009 | Sony PlayStation Portable (PSP) Slim...
Sony Playstation 3 (PS3) Console Logo
578 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
