Question about Goodmans Televison & Video
Hi. My Goodmans GDVD161DX DVD Player won't display any picture. It has been working until today. There is no picture at all so I can't go to the menu. When I try to play any DVD, there is audio but no picture. I have tried three different scart leads and I've tried it in AV1 and AV2. It is plugged directly into the TV. I hope you can help...
5 Suggested Answers
SOURCE:
SOURCE: dvd video player
through a process of elimimation I identified the problem as a faulty scart lead
replaced lead and all was okey dokey
thanks for advice posted
colin the cat
Posted on Feb 07, 2008
SOURCE: Need to connect the following: Foxtel
how can i recover my dvdrecorder's HDD?
Posted on Mar 09, 2008
SOURCE: playback of any dvd you
the solution is very simple you have to go out and spend more money on hdmi leads problem sorted.COST ME ANOTHER £44 POUNDS ON TOP OF THE TV AND DVD PRICE BUT NEVER MIND!!!!!!!!!!!!!
Posted on Jul 21, 2008
SOURCE: Can't switch from AV2 to AV1 with Samsung DVD-VR375 DVD Recorder / VCR Combo
To be able to select AV1, you have to first go into the setup menu and set the control set top box setting to OFF. I think you go to the menu >> setup >> features >> set top box control >> select OFF. Note that this has the side effect of erasing any previously stored timer settings.
Posted on May 28, 2009
Auto tuning digital tv lcd
i cured the buzzing by replacing the 120uf/450v capacitor on the power board (the biggest one on there )
Dec 29, 2013 | Goodmans Televison & Video
The tray on DVD won't open when pressing OPEN button DVD/CD is inside
Often the tray is powered by a rubber belt. If the latter breaks or slips the try will not open/close. The motor will work and tell the electronics that all is well because it has done its job but it really hasn't since the tray is inert!
Sep 10, 2017 | RCA DRC247N DVD Player
Need remote code for goodmans dvd 2200
Hi there I just found this on google. Give it a try.
www.amazon.co.uk/gp/feature.html?ie=UTF8&docId...Cached - Similar
Jun 12, 2012 | Televison & Video
Magnavox MPD850 dvd player won't play, only display no disc
The problem is in the laser pickup assembly, over time the laser becomes weak until it can no longer read the disc, but you can buy a DVD cleaning kit that might breath more life into the player, if no! cheaper to replace the DVD player.
Mar 17, 2012 | Magnavox Televison & Video
My LG ht303su dvd player won't eject and it says it's locked
my LG ht303su DVD player won\'t eject and it says it\'s locked
Jan 15, 2011 | LG HT303SU Theater System
Goodmans 17" LCD TV always sound, intermitent picture.
Give little spray of W-40 contact cleaner in Scart, seems has lil dust / rust.
Aug 02, 2008 | Goodmans Televison & Video
Denon DVD-1740 component video to RGB cable
YOU HAVE THE RIGHT CABLES FOR THIS INSTALL, GREEN, RED, BLUE FOR COMPENENT VIDEO AND RED AND WHITE FOR AUDIO UNLESS USING THE OPTIACL OR COAXIAL, FROM THE DVD PLAYER TO THE AMP OR TV.
ON THE FRONT OF THE DVD PLAYER IS A HDMI BUTTON PRESS THIS BUTTON UNTILL OFF IS DISPLAYED AND YOU SHOULD HAVE PICTURE
Jun 02, 2008 | Denon DVD-1740 DVD Player
Goodmans Tv wont show dvds
Usually with DVD players, picture & no sound, or sound & no picture is caused by the scart lead not being plugged in properly.
Sound pins are at one end of the connector and audio pins at the other.
If you are using scart make sure that the plugs at both ends are pushed in all the way. The plastic part of the plug should just touch the socket.
If you are using S-Video (Round connector with 4 pins) you also need to connect a twin phono-phono (Red & Black or White) lead to carry the audio, as S-Video only carries video.
Feb 09, 2008 | Goodmans 1475TS 14" TV
Televison & Video Logo
29 people viewed this question
Top Goodmans Televison & Video Experts
Ekse
Colin Stickland
Colin Stickland
Steven Wander
Steven Wander
Are you a Goodmans Televison and Video Expert? Answer questions, earn points and help others
