Question about Epson Stylus CX3200 All-In-One InkJet Printer
Epson stylus cx3200
My printer is making a squeaky noise as the cartrides move into place and then it barely prints anything. It has lots of ink. I am so frustrated!CX3200
  • 99 Answers
If using XP or Vista:
Go under Control Panel -> Printers -> Right Click on printer preferences and choose option to service/clean print heads.
After that print test page.
If still not right suggest new printer due to cost of repairing.
Hope this helps.
Thanks!
Posted on Mar 24, 2008
SOURCE:
How do you remove printer heads on cx3200
The two clips that swing down and hold the ink cartridges can be easily removed without breaking anything or removing screws. Look at the hinge points and use a screwdriver to gently pry one hinge of each clip out and the clips will simply lift out. But after that there are 2 small screws that hold the print heads in that ink cartridge carriage. Remove them and keep track of them. The white clip positioned in the color ink cartridge bay helps to hold the ribbon cable in place, but once you see what will move in regard to the print head, you can loosen the white clip and the print head should lift up. In this way, conceivably, the CX3200 print head should detach from the ribbon cables (there are 2) and a new one goes in its place. I'm dealing with a friend's CX3200 that the black is not printing and I'm cleaning it out and finding a lot of dried sticky ink. Probably used until dry or refilled the cartridge with the wrong type of black ink.
Apr 10, 2010 | Epson Stylus CX3200 All-In-One InkJet...
Epson Stylus cx3200 wont print good.
You're jets are pretty much shot. Have you recently used generic ink or used ink that has sat for a while? I had almost the same model and bought my ink in bulk not thinking about it and same thing occurred. Time to upgrade to a new printer...sorry.
Oct 30, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Not printing clearly even after cleaning the head
Hello sir; Not only to clean the print head also the ink cell.;
turn power on, open the cover, the ink cartridge will move to the center, then UNPLUG power cord, now you can manually move the cartridge check the ink cell which ink cartridge allway seating, there should be have a lot ink stick, just remove it.
Aug 02, 2009 | Epson Stylus CX3200 All-In-One InkJet...
My epson stylus cx3200 is not printing in black but does print colour even though ink levels in both colour and black cartridges are fine
If you are brave I had the same problem. I removed my ink disconnected the data ribbon to the Head. Took off the nozzles. I used a child's med. syringe with the tube. Filled it will rubbing alcohol. placed the tube on the head where the ink cartage attaches and slowly put pressure on the syringe. Be care full it will flush the black ink everywhere. I kept doing this till the black was all flushed out. Put it back together. make sure you put the ribbons back in the right way. Mine works great.
Mar 04, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Won,t print
Take it back and buy an Epson brand.
Feb 05, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Error inkcartridge
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200
Nov 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Epsom cx3200 off brand ink refill
Make sure the print head nozzles are not clogged. You may need to clean the print head. This unclogs the nozzles so they can deliver ink properly. Print head cleaning uses ink, so clean it only if quality declines.
When you don't turn on your EPSON CX3200 for a long time, the print quality can decline. It's a good idea to turn on your EPSON CX3200 at least once a month to maintain good print quality.
1. Make sure the EPSON CX3200 is turned on but not printing, and the Error light is off.
If the Error light is flashing or on, you may need to replace an ink cartridge.
2. Press the left Menu button on the control panel several times until you see Cleaning and then press the Copy button.
Cleaning takes about 30 seconds, during which the EPSON CX3200 makes some noise and the Operate light flashes. Never turn off the EPSON CX3200 while the Operate light is flashing, unless the EPSON CX3200 hasn't moved or made noise for more than 5 minutes. setViewedFAQCookie(14082, 31605);
Oct 02, 2008 | Laser 3115cn All-In-One Printer
Help Epson CX3200
I just like to ask to where specifically you can see the red light. It will help us determine what cause the red light. To give you heads up as well, the Printer's LCD screen can help us determine what exactly the offline condition of the CX3200 is:
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200.
May 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Epson stylus cx5400 reset???
try doing this :
Reclamping the Ink Cartridges
Once you start the ink cartridge reclamp procedure, you must complete all the steps in one session.
1. Make sure the EPSON Stylus CX5400 is turned on and not printing.
2. Press a MENU button until you see CHANGE CARTRIDGE, then press the COLOR COPY BUTTON. The ink cartridges will move to the replacement position.
3. Lift up the unit's cover, to access the ink cartridges.
4. Pinch the tabs on the front and back of the cartridge, and lift it out of the printer.
5. Lower the cartridge back into its holder, then press down on the top of the cartridge until it clicks in place.
Caution: Don't touch the green circuit board on the back of the cartridge, as you may inhibit normal operation and printing.
6. Carefully lower the scanner and press it down until it clicks into place. The EPSON Stylus CX5400 begins charging the ink delivery system.
The On light flashes and the EPSON Stylus CX5400 makes noise. Charging takes about 30 seconds. When it's finished, the On light stops flashing and stays on steady.
Caution: Never turn off the EPSON Stylus CX5400 while the On light is flashing, unless the Stylus CX5400 hasn't moved or made noise for more than 5 minutes.
if the issue still persists - you need to call the vendor - it´s a hardware issue
Dec 30, 2007 | Epson Stylus CX5400 All-In-One InkJet...
Epson Stylus CX3200 All-In-One InkJet Printer Logo
140 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
