Question about Canon PIXMA MX700 All-In-One InkJet Printer
Can not print to my Canon MX700 printer. Error Code 5100 keeps coming up, have turned on and off several times
  • 4,041 Answers
Hi You can Try 2 things.
ERROR 5100 means that there is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 26, 2010
Error code 5100 has appeared
Here is what I could find on the issue. -Error code 5100 describes a physical problem either with a paper jam or an incorrectly seated ink tank.
This was found on e-how. If you would like to read more please see the link below. hope this helps.
http://www.ehow.com/how_6497472_fix-code-5100-canon-mx700.html
Apr 11, 2011 | Canon MX700 Office All-In-One InkJet...
Error code 5100 i have turned off machine, unplugged at electrical source. After 30 min replugged in to electrical source, turned on printer. Pressed print button. Machine processes for a few minutes...
Hello and Welcome
Error 5100 means that the cartridge can not be detected by the printer.
Actually the printer is not actually loading the cartridge and showing you the error 5100.
To solve these follow the following steps. I hope it works
  1. Turn off printer
  2. Remove both the cartridges from the printer
  3. Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches
  4. Return the cartridges
  5. Turn on the printer.
Error will be removed
Further assistance i am here to help
Please don't forget to click on Four thumbs which are given below if it is helpful
THANKS & Keep Using Fixya
Mar 11, 2011 | Canon PIXMA MX700 All-In-One InkJet...
Pixma MX700.Error code 5100 . Paper from rear printing stuck in printer. Please advise.
Hi You can Try
Error Code 5100 You need to get ant bits paper from it first, no easy way just go to get in to it and get it out try turning the rollers by hand.
Solution 1:
Solution 2:
Jan 29, 2010 | Canon PIXMA MX700 All-In-One InkJet...
Double images, error 5100 when printing, copying
5100 is a carriage error, check the timing strip for contamination(plastic strip about 1/4" in width)
The unit is not homing, check for obstructions.
Jan 02, 2010 | Canon PIXMA MX700 All-In-One InkJet...
Error code 5100
5100 means either there is paper stopping the carriage from moving properly, or there is grease on the plastic strip behind the carriage. If you wipe off the grease with a Q-tip the error will go away.
Jun 24, 2009 | Canon PIXMA MX700 All-In-One InkJet...
I have a Canon MX700 printer. I had a "business card paper" jam. Since the paper is perforated for business cards, it wasn't fun removing all the pieces. I finally removed the back panel & was able to...
Hi You can Try
Error Code 5100
Solution 1:
Solution 2:
Feb 18, 2009 | Canon MX700 Office All-In-One InkJet...
Printer error code 5100 I had a business card paper jam in my Canon MX700. I removed the back panel & was able to clear the obstruction, but I keep getting the Error code: 5100. I've tried turning the...
Hi You can Try
Same old Error Code 5100
Solution 1:
Solution 2:
Feb 16, 2009 | Canon MX700 Office All-In-One InkJet...
Error Code 5100
Carriage error. Paper or the print mechanism is blocked.
It could mean the rollers don't grip the paper, there is torn paper keeping the rollers from turning, the paper can't stick to the rollers etc.,
http://noel.bouvet.free.fr/ip4200/Canon%2520Servicemanual_ip4200.pdf
Sep 01, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Error code 5100 shows onscreen and there are no comments in guidebook
move ink tank to right and turn of then turn on, found in another canon printer fix it.
Jan 28, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Canon PIXMA MX700 All-In-One InkJet Printer Logo
480 people viewed this question
old marine
old marine
