Question about Dell E152FPb 15" TFT LCD Flat Panel Monitor
After changing c5707/c5706 transistors its burnt after 10 minute? i have changed its 3 times, pls advise me about actual problem
  • 4 Answers
On E152fpb dell only replace all driver transistor the c5706 or c5707 this 2 types of transistor is not desame one is PNP & NPN so you must be careful of replacing component maybe it will help you
Posted on Jun 14, 2012
  • 11,361 Answers
You need to check the tuning caps (if these caps change the value or have high ESR, the oscillator will not run at the correct frequency and burnt up the transformer and the transistors) located by the inverter transformer also, need to check its value and ESR (Equivalent Series Resistance, use LC-75 tester), check the inverter transformer (use inductor tester, LC-75). Also make sure to resolder all the conennection on the transformers and other places that you can see poor solder joints.
Read more tips here:
http://www.electronicrepairguide.com/dell-e152fpb-lcd-monitor-repair.html
http://s807.photobucket.com/home/budm/allalbums
Posted on Apr 26, 2010
Para resolver el problema de este modelo de monitores dell solo solo hay que cambiarle un fusible encapsulado que tiene cerca de un discipador de calor. parece un diodo pero no tiene la raya gris que tienen los diodos. es un fusible de 2amperes.
Posted on Jul 29, 2011
KONZERT AV-502A KARAOKE AMPLIFIER,POOR AUDIO,2-RESISTOR WORN OUT PLS. HELP ME
pls check burnt resistors, if ceramic it's value is .25 0hms 5 watts, if big carbon film resistor it's value is 10 ohms 3 watts. check also power transistors A1941 & C5198. also check driver transistor A940 & C2073
Jan 06, 2013 | Car Audio & Video
My monitor is on but the backlight is off. When you swicht the monitor at first, the lights come and go. I did check the inverter side and i fund out that pair of the driver transistors were dead. I did...
When you replace the transistors you should change all 4 of the C5707 transistors. You also need to resolder all of the connections to the 4 output transformers and the 4 output plug connections. If you did not resolder the these additional connections then the new transistors you install are more the likely dead now. The solder joints can crack because of the current and this causes the circuit to pull more amps than the transistors can handle. The new ones will blow within 2-3 seconds if you did not resolder the other connections.
Sep 23, 2012 | Dell E173FP 17" LCD Monitor
The power button on my monitor flashes but will not trun on
There is a chance that you may have a couple bad capacitors on the power-inverter board but more than likely the problem will be a shorted out transistor. There are 4 on the inverter side of the board and one set may have gone bad. Capacitor problems may have caused the transistors to fail. Transistors are probably c5706 or c5707 and are black with 3 legs going though the board.
You would have to open it up to check and would need an ohm meter to verify if the transistors are shorted out.
Aug 18, 2010 | Dell 1703FPt 17" TFT LCD Flat Panel...
Picture goes black at random intervals
There are 4 c5707/5706 in the inverter transformer driving circuits, the cause of the problem was due to poor solder connection in the bias circuits of the transistors. Make sure to check that after you install the new transistors otherwise you will blowthem up. Common problem with this model. When the circuit drwas too much power from the power supply, it will shut itself off to ptotect itself.
Dec 16, 2009 | Dell E173FP 17" LCD Monitor
Monitor loses screen after 5-10 mins and then 5-10 seconds
Sounds more like the transformer's getting overheated/shorting internally. If you unplug it and leave it off for about 10 minutes, then plug it back in and get the 5 minutes of working video back, then I'd suspect it's heat related and something's breaking down internally.
Aug 28, 2009 | HP Pavilion F1703 17" LCD Monitor
Pavilion f1903 silver goes blank seconds after turning on.
The monitor you have has bad components on the circuit boards inside.
This is a classic problem with all LCD monitors.
I rebuild them on a daily basis so I recognize the symptoms.
I would suggest finding someone who can do component level repair on the circuit boards inside.
I also suggest not trying to repair yourself as there are many breakable components to them as well as components inside that do not like static electricity discharges.
May 17, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
Benq t7q3
look at the 3 amp. fuse on the mainboard! By the way, you can buy very cheap USB light, wich are working with a small lighttube. Use the transistors of their generator!
Mar 09, 2009 | BenQ T705 17" LCD Monitor
BenQ 17inc LCD Monitor
change c5707 transistors ...all 4 of them plus fuse
Feb 10, 2009 | BenQ FP731 - 17" LCD Monitor
Found them
If you are referring to the C5707 inverter driver transistors, you can test them in circuit with an ohmmeter. Usually one pair will show shorted although only one may be actually shorted. Normal procedure is to replace the pair that shows in circuit short. If you do not resolder the transformer connections your transistors will short again.
Monitor Mike
May 30, 2008 | BenQ FP737S-D 17" LCD Monitor
Gone from blinkid led to lights out.
You really need to replace all 4 and also the 2 FU9024 chips and examine all the solder in the inverter area. Also if you have the 2 lamp connector board with a chungwa LCD panel them your lower lamp is probably also bad. Check out www.lcdrepair.us for instructional videos on Dell models as well as repair kits and boards for that unit.
Apr 25, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Dell E152FPb 15" TFT LCD Flat Panel Monitor Logo
1,828 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
