Question about Whirlpool 3.2 cu. ft. Plus Washer
Agitator is not agitating. Cant seem to get
Agitator is not agitating ( rotating clockwise and counter clockwise). Just seems to shake or vibrate. Cant seem to get agitator out of wash machine either. Seems loose. Is it supposed to be on the column tight?
  • 5,911 Answers
If this is a Whirlpool manufactured TOP LOADER, and this is a simple matter of the agitator not working, but everything else does, you may just have a worn agitator cam assembly, worn agitator dogs, loose agitator bolt, or all of the above. The following link explains what agitator dogs are and how to access them:
http://www.fixya.com/support/r3608577-replacing_agitator_dogs
Whirlpool manufactured washers use a split agitator design. The top half is known as the "auger, while the lower half is the agitator. Between the two pieces is a cam assembly, with small teflon teeth known as "dogs". There's also an agitator bolt that holds the entire assembly to the center post.
If the auger (top half of the agitator) is slipping, I would suspect the dogs or cam assembly need to be replaced. The part number for the dogs is included in the link I provided. For a little more you can purchase the entire cam assembly which includes the dogs, the cam, the cam seal and thrust bearing.
If the entire agitator appears loose or slipping, check the agitator bolt to ensure it is tight. DO NOT overtighten as this can restrict movement of the agitator or damage it. Tighten until snug.
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need. If you do not wish to order parts on line, use the part numbers from the Sears website and go to your nearest appliance parts retailer. All these parts are commonly sold as part of their in-store inventory.
If you have any questions, please post back and let me know. I hope this helps you.
Posted on Apr 26, 2010
Towel stuck under the agitator..cannot be pulled out, agitator turns clockwise, agititor gets stuck turning counter clockwise
You will probably have to remove the agitator, There is a bolt on the top, take this off and lift off the agitator
sudinw8a1y.gifitator
Sep 22, 2011 | GE WPRB9250C Top Load Washer
I have a Whirlpool washing machine LA8800XT. It seems the timer knob can no longer engage the timer shaft. Part number of the timer is 3352091. I am positive the machine and the timer are fine. I tried...
I have a Whirlpool washer #LA8800XT and want to remove the Fabric Softener dispenser so I can remove the agitator. Does it just screw off? It seems to be stuck and I didn't want to break it if it didn't screw off.
Oct 09, 2010 | Whirlpool 3362624 Washer Control Timer...
Agitator seems to not turn right. Is there a gear that could be broken?
I'll assume that this is a standard direct drive, top loading washer. Try manually turning the agitator counter-clockwise, it should catch. if the top of the agitator spins freely, you will need to replace the agitator dogs. Part#80040 Just remove the agitator cap, (or softener dispenser) and remove the inner cap and seal. There should be a 7/16th bolt that holds the agitator onto the tranny shaft. Remove bolt and pull the agitator up from the base. Once you have the dogs, you'll see where to go from there, it's hard to explain on a post, but is actually rather simple to perform. The doga are what catches back against the grain to create the agitating action. Hopefully that's all it is.
Dec 30, 2009 | Whirlpool Washing Machines
My whirlpool ultimate care 2 washer works great, however, the agitator misses and clicks before it catches up
Is this a two piece agitator? You may just need dogs, they are inside the agitator. Rotate the top of the agitator back and forth, top should engage the bottom portion when turning counter clockwise.
Jun 19, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag MAV7000 AWW washing machine agitator won't spin freely.
When you grab the fabric dispenser and move the agitator "counter "clockwise you should hear the rachet noise,once you try and move it back "clockwise" the fabric dispenser should slide inside the agitator and the agitator should NOT move.
Apr 02, 2009 | Maytag Atlantis MAV7000
I just bought a refurbished kenmore 90 series washer and my brother is telling me that it is not agitating correctly, when it fills with water it starts to agitate clockwise and continues to do so until it...
Hi, seems like this drive shaft and clutch assembly wasn't assembled properly. the agitator should spin counter clockwise and clock wise(both ways). I would return this unit for an exchange before the warranty is canceled.
Apr 02, 2009 | Kenmore 24032\24036 Top Load Washer
Locked up agitator,
If your agitator is a 2 piece, it has a rachet action and turns free counter clockwise and locks to the bottom piece when turning counter clockwise.
The transmission disengages the agitator when it is in the spin mode. If you put the washer in the spin cycle the agitator should free up.
If the washer is spining ok and the agitator is not turning free you have a transmission problem.
Jan 27, 2009 | Admiral AW22 Top Load Washer
Agitator locks up
The agitator is supposed to turn freely one way then catch the other. in the top of the agitator there is three teeth that retract when you go counter clockwise and then when they go clockwise they come back out to bite on the inside of the agitator and then spin it. Those teeth are called DOGS. It is only when you can spin it freely both ways that you have a problem. There is nothing wrong with it. Congrats.
Jan 04, 2009 | Washing Machines
Hoover Washer only agitates in one direction
Check the paw. It is a plastic somewhat u shaped piece that sits on the bottom of the machine and is connected by a plastic lever and a solenoid. It usually breaks on the end and as such won't lock the gearbox in. If you keep running it like that there is every chance you will probably burn the motor out.
Oct 08, 2008 | Washing Machines
Kenmore 90 series washer
most likely the agitator dogs are bad. if the agitator engages clockwise and free spins counter clockwise they are good, if it slips they are bad. remove the bolt in the center of the agitator, take off cap or dispenser and remove the inner cap first. pull out the agitator, put on the floor, stand on the base of the agitator and pull up on the upper part to separate, take out the dog holder and replace dogs. Most appliance repair shops should have part on hand for about 5-6 dollars. part number 80040-fsp.
Jan 14, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool 3.2 cu. ft. Plus Washer Logo
502 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
