Question about Maytag 24 in. MDBH970AWS Built-in Dishwasher
Water wont empty
Wateail.comr wont empty
  • 192 Answers
The pump out motor is in line with the outlet hose. This motor must spin to pump out water. The motor has 2 push on electrical connectors and mains voltage must be across the connectors in pump out mode. If mains voltage is across and motor does not spin ... motor open circuit and need replacing. If motor spins but no water pumped out indicates either pipe blocked or impeler in motor not turning. No voltage across terminals indicates a wire fault or timer / switching fault that must supply voltage to the pump at the correct time. The removal of the motor is quit easy to do.
Posted on Apr 26, 2010
My front loading machine does not appear to be pumping water in a light flashes H20 and beeps
? im confused are you saying its not filling with water or its not emptying of water , if its not emptying of water , yes its true the pump in it is driven by a motor and yes they d go bad and yes if the pump wont turn then yes it wont empty out , this makes sense to the blinking light of water detection you see ? ohh and most times the pump and motor are all one assembly , if it wont fill with water then you need to ck the inlet valves they get clogged or go bad too ) there is no motor that is assoc with these valves that I know of
May 25, 2016 | Washing Machines
The water comrs bown water is that good
Are you saying that the water in the radiator is brown?
If the water is brown it would indicate rust from the engine which means there is probably no antifreeze which is also a corrosion inhibitor. If the water has a lot of sludge it would indicate a blown head gasket which is not so good.
Aug 22, 2014 | Cars & Trucks
Help my machine hotpoint ultima wma 60 wont empty water tried 5 times water sitting there had turn machine off
p my machine hotpoint ultima wma 60 wont empty water tried various times water sitting there had turn machine off
Dec 21, 2009 | Hotpoint Washing Machines
Hotpoint wma13 wont empty, think pump is blocked
Yes,
The water pump most be clugged and/or defective.
Aug 18, 2009 | Washing Machines
Front strut problems?
if you wont to know how the spring is held in you need to comres it and push the top mount down the shock then you will see a small retaining ring that fits in a reses on the shock and thats all that holds it together
May 04, 2009 | 1998 Volkswagen Jetta
Hotpoint dwf 30 - Water wont empty
if the drain is plumbed into a spigot on the sink trap, then this spigot is blanked off to prevent water coming out when you empty the sink. remove blank
Aug 31, 2008 | Dishwashers
1999 nubra
You could try checking the reversing sensor on the side of the gearbox,
Jul 24, 2008 | 1999 Daewoo Nubira
Washing machine wont empty
hi there this is a common fault empty the water into a bucket and remove the water pump to check for blockages, the pump is located at the rerar lefthand side of the w/m.
also check your drain hose where it connects under your sink.
hope this helps
Dec 11, 2007 | Washing Machines
Maytag 24 in. MDBH970AWS Built-in Dishwasher Logo
112 people viewed this question
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
