Question about Canon PIXMA MP780 All-In-One InkJet Printer
Canon Pixma MP780 not printing/copying black
Was fine this morning, then I tried to photocopy my daughters hands and it did not give a clear image.
Can print in colour, but this is obviously not helpful.
Black 3e was new two weeks ago, and is a proper Canon ink cartridge. I have aligned heads, cleaned etc. Please help.
  • Canon Master
  • 12,061 Answers
You cannot get a "Clear Image" when you cannot, completely, remove any external light sources. Whenever one tries to copy any 3D object, it MUST exclude all external light, this can be very difficult, Often, you need to use some sort of White opaque cloth, and surround whatever the 3D object is. Now the Scanning and Printing are independent from each other, you can get a perfect scan, but for whatever reason, the printer makes a bad print. When you printed, you may need to print in "Greyscale" this can be selected, from the "printer Properties" menu. Also when you "Scan" you MUST select, weather or not, you scan in Black & White, or Color. usually if you Scan in B&W, it will also print in B&W. However if Color was chosen, then the printer will attempt to print using the color cartridges, and "Mix" the Black & White, from the palette, whereas with plain B&W, it ONLY uses the Black, ink cartridge.
http://www.retrevo.com/support/Canon-MP780-Multifunction-Printers-manual/id/259bh643/t/2/
http://rapidshare.com/files/36633254/Canon_PIXMA_MP750_MP780_SERVICE_MANUAL.rar
Service manual for your printer above, above that is the user manual.
Use the Service manual, and work through, the troubleshooting and set it all up again. Do a "Reset' on the printer, and make sure you do ALL alignment and cleaning of the heads, also empty the ink overflow tank too, this sometimes helps too.
Posted on Apr 26, 2010
Canon PIXMA MP780 - will copy only in greyscale and color - not in black and white
Try first fo clean the cartridge/nozzle using the printer utility installled on your computer then after that try to print a plain text and see if its working fine already...
Good luck........
Aug 16, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon mp780 is stuck on fine mode and it will not
yes, first change the paper setting button to normal, then you can lower the image quality on copies.
Nov 10, 2009 | Canon PIXMA MP780 All-In-One InkJet...
I have a Canon PIXMA MP780. It won't print except
If you can print the nozzle test then that proves most of the electronics, it could be the driver is screwed.
Since you can get something out that is intelligent e.g. the larger font lettering then it is processing the file sent to it.
By that I mean rasterising it, converting it to dots of ink, so it can print onto the page as the heads moves back and forth.
Why not try another computer and connect your printer to that one, or try a different file, or even send it a file you've printed successfully in the past before you started to have this problem.
Sep 26, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Canon MP 780 Won't print black and white
First off I would recomment a new printhead. Short of that run the printhead alignment and calibration.
Jun 19, 2009 | Canon PIXMA MP780 All-In-One InkJet...
My incoming faxes won't print. both black ink cartridges r full
Is there any message when you try to print the faxes?
If there is an "Image Quality" message, probably the printer is set up to "Copy" in "Photo" or "Fine" mode and it needs to be set to something other than "Fine" or "Photo"
Apr 01, 2009 | Canon PIXMA MP780 All-In-One InkJet...
In copy mode I can't get Image Quality to change from Fine
Ok what I just found out is that if you use the paper key then the menu key to get down to image quality the n the + and - keys to change the selection.
Jan 05, 2009 | Canon PIXMA MP780 All-In-One InkJet...
MP780 copy mode/resolution
Mine was stuck on fine photo resolution too and it wouldn't print in normal black. I tried lots of things and the only thing that seemed to work was pushing the photo button and then pushing the copy button again. Good luck.
Dec 13, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon pixma mp780
Try uninstalling/reinstalling the drivers.
Is the error light flashing?
From the printer utility can you print a nozzle check sheet or align the printhead?
Does it seem to be printing (feeding sheet and moving printhead) or nothing happening at all?
Try removing all the tanks, take out the head. If blocked try cleaning manualy by running warm water over the ink ports/printhead jets - dry off and reinstall.
May 10, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon pixma mp780 Copying mode very slow
is this using it on its own[Stand alone mode] or through the computer?
May 13, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
82 people viewed this question
old marine
old marine
