Garden Logo
Posted on Jan 03, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need a belt for a older murray riding mower 46'' deck
I need a belt for a older murray riding mower its a 46'' cut deck. the numbers i can read off of the old belt on it are 37870 or 32155 the 55 at the end might be ss not sure the lady i baught it from let it sit for 5 yrs the belt runs one blade and the main fly wheel that comes straight down from the mower
Ray Smythe
Level 2:
New Friend:
  • Expert 69 Answers
  • Posted on Jan 03, 2018
Ray Smythe
Expert
Level 2:
New Friend:
Answers
69
Questions
Helped
28309
Points
285
I think that's easy to find online. Very common mower. Here's a link to Amazon and Murray belts
Amazon com lawn mower belts murray 46
5 Related Answers
Anonymous
  • 6 Answers
  • Posted on Apr 06, 2009
SOURCE: how to install mower deck belt on a lt1000 craftsman riding mower
The manual will cover it.
http://www.disruptit.com/manuals/L0104168.pdf
Anonymous
  • Posted on Jun 21, 2009
SOURCE: John Deere Lt 166 ride on mower
jd lt 166 has 5 different decks
3 of which have the same belt routing
1st the belt needs to be adjusted correctly to stop it from "slacking off"
then on most decks the belt is routed in between the 2 small idler pulleys and then to the engine pulley
so let me know the deck i.e. 36", 42 ", 46", 48"
different belt sizes also
kendo
Anonymous
  • 226 Answers
  • Posted on Jul 19, 2009
SOURCE: I need a diagram for the deck belt on my Cub Cadet
go to partstree.com put in your make &model #.then clickdeck assembly.hope this helps
Anonymous
  • 582 Answers
  • Posted on Aug 21, 2009
SOURCE: Need model number and year of my murray ultra 19
OL BOY , MURRY PUT THE ID TAG ONE THE REAR OF THE MOWER SOME UNDER THE SEAT AND PLACES LIKE THAT THE ONLY PROBLEM IS IT'S A STICKER NOT A PLATE. COULD HAVE FADED OR NOT READABLE CHECK AROUND YOU SHOULD FIND IT
Anonymous
  • 123 Answers
  • Posted on Aug 26, 2009
SOURCE: replacing deck belt
Here ya go.
DIAGRAM OD DRIVE BELT ON 46 INCH CUT HUSKEE MOWER
You will need the model number to find this info. Usually on a plate or sticker under the seat. The use a parts site like jackssmallengines.com or simply Google your make and model followed by "deck belt"
2answers
I have a 91Murray 42inch riding mower need proper size belt to run blade,a blade belt
Contact a local auto parts store, a full service one, bring in the old belt and they can match it.
Will an older 42 inch murray riding lawn mower deck interchange with an older rally riding lawn mower deck ?
Mower decks are very specific to the tractor. Unless it was the same manufactured mower, and just branded differently, then not likely! Belts are your next problem as even an inch longer or shorter will cause problems.
Blade route
I can't give you an answer on this without knowing the model number of your mower.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/steve_f5a6ca85b5d1ffc9
2helpful
Need a drive belt diagram for a murray lawn mower model 465306x8
Please find attached a "amateur" drawing of the belt routing for the 37x89MA primary deck drive belt. Hope this helps.wefixem.jpg
Intall a deck belt on a 42" murray riding lawn mower
http://www.ereplacementparts.com/ type in your model number all the diags you need, yours Henry
2helpful
Need belt diagram for murray riding mower 17.5hp 46'' deck
here is website for parts diagrams
http://www.partstree.com/parts/?lc=murray&mh=8
enter / select your murray model fron the list and then go to approriate sub section
general belt layout should be shown with realative parts along with deck
just be sure to select correct model and size deck , this info should be on your mower somwhere most likly on a white sticker
cherrs hope it helps paul
Aug 02, 2010 • Garden
2helpful
2answers
The mower deck drive belt slipped off the idler pulley on my 42'' Murray riding mower deck because the idler pulley was worn out. I need to know how to loop the belt back around the pulleys after I replace...
Get the model number off the tractor, go to:
www.murray.com
enter the model number and you will find a manual with pictures of how to route the belts along with a lot of other good information
Sep 30, 2009 • Garden
Top Garden Experts
Jay Finke
Jay Finke
john h
