Question about Electrolux Guardian Bagged Canister Vacuum
I need a manual for an epic 6500,lux legacy, and a guardian
  • 694 Answers
Owner's manuals are available on the Aerus site. Those three are under the "Older Model" tab. Simply download.
http://www.aerusvacuums.com/support/manuals/
Service manuals are only availabe to franchise owners and service technicians in authorized Aerus stores. They're available to those personnel through software Aerus provides to them.
Posted on Aug 30, 2010
Tip
Electrolux Epic 6500: Trouble Shooting I
Electrolux Canister Vacuum Shuts Off During Use<br /> <br /> This actually cover several models of Aerus and Electrolux canister vacuums. Models covered include: 2100, Epic 6000, Epic 6500, Aerus Lux 5500, Aerus Lux 7000, and Aerus Lux Legacy. Be aware that some of these models may still be under warranty. Any disassembly of those machines will void the warranty. Use of non-genuine bags also voids the warranty. Use only Home Solutions Aerus/Electrolux bags.<br /> <br /> First, turn dial on top of vacuum counter-clockwise so the smallest dot lines up with the arrow. See if it stays on. If not, detach hose and turn vacuum on. Place palm of hand over intake. If it turns off, it's possible that the tubes connecting to the CVA are clogged and simply need cleaned. This is most often caused by using "made to fit" Electrolux bags. Dust is sucked through the bags and into the motor compartment of the machine. All interior parts get covered in dust and need to be cleaned. If this is the cause, the vacuum is best cleaned and repaired at an authorized Aerus Electrolux store. If the vacuum shuts off, or won't turn on before placing hand over the intake, it's probable the control valve assembly is bad and needs replaced.<br /> <br /> Another cause is an overheated motor due to clogged screen at back of bag well, full or clogged bag, dirty afterfilter, bad wiring/connections, clogged hose, clogged power head, or bad motor. It depends largely on the type and model of cleaner. Clogged wands are also a possibility, but unlikely.<br /> <br /> Check and clean screen at back of bag well.<br /> <br /> Replace bag. Make sure it's a genuine Electrolux bag made by Home Solutions.<br /> <br /> Check and replace afterfilter if necessary. These should be replaced after every six bags.<br /> <br /> Broken and worn wiring connections are often found in the hose ends due to abuse and normal wear and tear. You can check the continuity of the hose using a continuity tester or multi-tester. If a multi-tester, turn dial to one of the Ohm settings. Place one probe into one of the terminals on the end of the hose. This will be referred to as T1. Touch the other probe to each of the terminals/connections on the other end of the hose. These will be T3 and T4. One of them should read zero, the other should read infinity. Repeat this with the other terminal, which will be T2.<br /> <br /> Drop a marble in one end of hose and let it roll through. If it doesn't roll through, the hose is clogged and needs to be cleared. Plug hose into the exhaust port of the vacuum, place other end in the in port. Turn vacuum on. This provides a blowing and sucking action which should clear the hose.<br /> Detach hose from power nozzle (PN). Drop a marble into the wand end of PN. If it rolls through, it's clear. If not, there's probably a clog behind the brush where the intake opening is. You may be able to reach this through wand end with needle nose pliers, or either end with a knitting/crochet needle or a bent coat hanger.<br /> <br /> If none of these "fixes" provide the answer to the problem, it should be taken to the nearest Aerus Electrolux store for diagnosis. Repairs or checks involving disassembly of the vacuum should always be done by an authorized Aerus Electrolux service technician.<br /> <br /> The store nearest you can be found by following the instructions at the below listed link:<br /> <a href="http://www.aerushome.com/storelocator/">http://www.aerushome.com/storelocator/</a><br />
on Dec 20, 2010 | Electrolux Epic 6500 Vacuum
I need a operating manual for EPIC 6500 Model 1763
You can download the manual from the Aerus/Electrolux site.
http://www.aerushome.com/Site/Manuals
I hope this isn't too late.
Jan 15, 2016 | Electrolux Vacuums
Epic 6500 Sr. Why does it keep turning on and off?
Electrolux Epic 6500 - Bag Full Indicator Bypass - YouTube
? 0:55
https://www.youtube.com/watch?v=YrMgoUAHcI4
Jun 23, 2013 - Uploaded by easilen
The rear pops off. There's a vac. ... Yeah, keep it. Undo Close ...Electrolux Epic 6500 - Bag Full Indicator ...
Questions and Answers for Electrolux Vacuum Unit
builtinvacuum.com/help/electrolux/qanda/main-central-unit.html
For Electrolux; Central Vacuum Attachment Kits and Hose and Tool Kits for Electrolux Attachment ... With a clean bag in, the unit starts up and immediately shuts off. If you hold ... From what I have read hear, it sounds like the motor is going. ... How can I fixmy electrolux epic 6500 SR vacuum? ..... It keeps cutting off and on.
Electrolux Epic 6500 SR Shuts off when power hose ...
Dec 28, 2015 | Electrolux Vacuums
Need manual for epic series 6500sr
Go to aerusonline.com. They have a section under the "surface" heading that you can download the manual. If no Epic 6500 is showing, use the Legacy manual. Same thing.
Hope that helps. :-)
May 13, 2014 | Electrolux Epic 6500 Vacuum
I cannoot find bags to fit my Little Lux Model # L673BA
You can find those bags at
http://www.totalvac.com/850-12.html
Fits all Electrolux canisters/tanks made after 1954, (except Lux 9000, Guardian, Epic 8000, Renaissance, Harmony or Oxygen models) Generic 12 pack of Electrolux vacuum bags.
Mar 01, 2011 | Electrolux Little Lux Bagged Handheld...
I am looking for an owners manual for my Epic Series 6500 SR.
Owners manual in pdf-format Electrolux Epic Series 6500 SR:
http://homeappliance.manualsonline.com/ex/thread/view/idThread/1424472
Clicking "Epic6500.pdf" will pop up a registration shortly,
but the manual appears directly after that.
Aug 09, 2009 | Electrolux Epic 6500 Vacuum
Electrolux Epic 6500 Power head
Call your local Aerus repair shop.
Feb 27, 2008 | Vacuums
Owner's Manual
Apparently there was a split in the company and many repair manuals are under the company Aerus. http://www.aerusonline.com/service/manuals.cfm
Apr 28, 2007 | Electrolux Epic 6500 Vacuum
Electrolux Guardian Bagged Canister Vacuum Logo
369 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
