Question about Western Digital Elements powered by WD 320 GB External USB (WDE1U3200N) Hard Drive
My WD hdd was working properly till yesterday. But it was not detecting in any of the laptops around.
    Problem Solver:
  • 10 Answers
Try change the external casing. Try with another casing(connection). try in few pc.
send to manufacturer if still under warranty.
Posted on Apr 26, 2010
My WD my passport not working
maybe the cable plug of the WD my passport is broken
Apr 18, 2013 | Western Digital My Passport Essential...
Clicking noises from unit and computer failure to start up
The clicking noise is commonly known as the "click of death" on a hard drive. The hard drive is faulty and the clicking noise is the read/write heads clicking back and forth.
The hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Jul 07, 2012 | Hitachi Travelstar 80GN 60 GB Hard Drive
Shows up as "Initio Combo Device Class" not a "Disk Drive"
RESOLVED the ISSUE...!!
Hi, Yesterday I get into similar problem of having my USB Drive ( WD passport Elite 320gb ) not being detected by my PC and as soon as I connect to it, Initio Combo device class drivers gets loaded and Drive do not show up in the device list...!!
I tried several options.1. Freezed my hard drive for 12 hrs in the freezer. It did not help me today.2. I have opened the USB drive shell ( becareful, I have damaged it.. see the instructions before you try t ). You can find the 2.5' HDD inside and there will be SATA to USB bridge adapter. I was having doubt on this bridge unit as I read through several blogs.3. luckily I have a unused 2.5' Laptop HDD. So I have removed this bridge unit carefully and tried to connect to my HDD. If the bridge is good, my HDD must be detected right away..But it is the same problem.. It did not work.. Hence I have confirmed that it is the bridge problem..
4. I bought a Rs. 250/- ( 5$ ) 2.5 SATA casing that is available in the market to use the 2.5' SATA HDD through USB. ( actually I do not know where I can buy only the bridge..hence bought the entire unit..which is still cheaper )
5. From the new unit, I have the USB to SATA bridge, which I have connected to my WD HDD SATA USB hard drive... Bingo.........It is detected by OS and I have started copying my important data immediately...
6. This Unit comes with a casing ..hence you may continue using this case... But some units may not fit well..still the bridge is usable..!!
I GOT all my data..with just Rs.250/- ( $5 ) ..I am happy to try this on my own..!!
Good luck with your drive..!!
Jan 01, 2012 | Western Digital My Book Essential 500GB...
Hi. My computer says I ejected my WD My Passport external drive but it was not properly ejected. How can I fix this. I need all my thesis files but computer can read the external drive! Help please!
Try to test your WD Ext HDD to a different computer and check if you will get the same problem.
If the same problem persist try to use a different cable for your WD Ext HDD.
If still fails kindly ask the store where you bought the WD Ext HDD on how to retrieve your files and have WD EXT HDD replaced?
If your WD Ext HDD works to a different computer then update the BIOS and Chipset of the computer where your WD Ext HDD connected previously.
Hope this helps.
May 29, 2011 | Computers & Internet
External HDD not detected
have you try with the other usb cable and the usb port.
Jan 20, 2010 | Western Digital 320GB MyBook External USB...
Suddenly my laptop acer aspire 5810 cann't detect the hdd wd (it used to work well before), although the light on hdd wd still turn on each time it plugs to any laptop. Please help. Thanks
The drive is probably loosely connected. Powerdown. Remove thebattery. I would remove the chassis cover over the HDD, PULL IT OUT, and reseat the HDD firmly.You can also gently tap the drive perimiter several times. OR you can make a WDDiag CDROM, boot the machine with CD, and a program will diagnose you drive, and probably fix it.
Jan 06, 2010 | Western Digital Computers & Internet
Laptop shows only 4gb ram & 300 gb hdd
This is the limitation of a 32 bit (x86) Operating System. A 32 bit OS can detect upto 3GB RAM only.
You may either try installing the x64 Bit of XP Operating System or Vista Service Pack 1 or 2 for 32 bit Vista Operation System to resolve the issue.
After installing the SP 1 or 2 of the Vista OS in the Computer, the OS will detect 4GB RAM.
Good Luck!!!!!!!!!!!!!!
Oct 12, 2009 | Acer Computers & Internet
Hard Drive Not detected/Windows still boots
Try setting the first boot device as the device with the boot sector on it.
Feb 26, 2017 | Computers & Internet
Hdd not detecting
are you able to see the hd detected in the storage section of the bios setup?
try scanning for new hardware changes in the device manager
else try connecting the hd in some other system and try if it is getting detected in that...
Aug 31, 2008 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Western Digital Elements powered by WD 320 GB External USB (WDE1U3200N) Hard Drive Logo
246 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
