Question about Samsung LNT4066F 40 in. LCD Television
Samsung LNT4066F, backlight is out
When I turn on my LNT4066F, the backlight comes on for a couple of seconds and then goes out. TV stays on, and if I hold a flashlight at 45 degree angle I can see a picture, sound works fine, and blue power light stays on.
What do i need to replace or repair?
Thanks in advance
  • 7 more comments
  • Greg Bonhotal Apr 27, 2010
    is there a way to verify inverter board is bad?
    I have checked resistance of all transformers on inverter board,and they are all around 3oo ohms.
    I have multimeter, and am willing to trouble shoot.
    I do not want to REPAIR inverter board, I just want a way to be sure that the board is the problem and not the POWER SUPPLY BOARD, since the high voltage transformer is on the power supply board, as well as a low voltage cable that goes to the inverter board.
    I just want to be sure that everything else is working, before the inverter board.
    I do not want to REPAIR the inverter board.
    I just want to know if there is a way to be sure board is bad.
    I don't want to replace it and then find out that the POWER SUPPLY BOARD is bad.
    Ther is a low voltage cable that goes from the power supply board to the inverter board.
    There is also a high voltage transformer on the power supply board, that powers the inverter board.
    What is the likelyhood that replacing the inverter board will fix this issue?
    Thanks
  • Greg Bonhotal Apr 28, 2010
    Hi, Thank you for responding,
    I feel like I finally found someone who is an expert on samsung.
    My the sticker says model code = LNT4066FX/XAA
    version = SS03
    When I hold the non contact voltage tester over the HV transformer, if beeps for the 1.5 seconds the backlight is on, and then stops when the backlight goes off.
    I could not find anything marked (CNM802 & CNM803) but i did check the power connector called CNI803 that runs from the power supply to the motherboard.(5 pin).
    on that connector pin 1 inverter on/off stayed at 5.28 v
    pin 2 - dim . starts at 3.5v then goes to .63 while backlight is on then slowly climbs to then to .82v after backlight goes off. where it stays.
    pin 5 stays at 5.39 v no matter what.
    not sure where the 24 volts is, but, if it is supposed to be on this connector it is bad.
    if it is on a connector between 2 boards which 2 boards would it be?
    if a testpoint or lead of a cap, which one?
    Thanks, I think we are almost there.
    version = SS03
    I could not find anything marked (CNM802 & CNM803) but I did check the power connetor called CNI803 that runs from the power supply to the motherboard.(5 pin).
    not sure where the 24 volts is, but if it is supposed to be on this connector it is bad.
    Thanks,
    You ROCK, It is wonderful dealing with a TRUE PROFESSIONAL!
    Thanks for ALL Your Help and Patience :)
    This Guy Knows His Stuff, and knows How to Explain it to layman. He3 is a True Professional and a GURU!
    Thanks For your help.
  • Greg Bonhotal May 01, 2010
    Hi again,
    I replaced the power supply and it still does the same thing.
    when I check the connector on the inverter, I get 12v steady at vcc,
    ld starts at 10.18, and then goes to almost 0 while the backlight is on, and then once light is out it goes back to 10v]
    the others don't seem to have any voltage.
    Not sure where to go from here, any suggestions?
    Thanks
  • Greg Bonhotal May 06, 2010
    Hi again,
    I replaced the inverter, and still getting the same behavior.
    If I disconnect one og the high voltage wires, It still lights up for the same amountof timebefore going out. (1.5 sec)
    Is there a way to diagnose and/or repair or replace a bulb?
    Not sure how to proceed.
    Thanks,
    Greg
    Guru:
  • 416 Answers
You need to make sure the 24v supply (CNM802 & CNM803 on the power supply) is staying up when the backlight drops out. You will be able to see the light through a few holes if you have the TV on its face with the back cover off. If the 24v stays steady and is not bouncing more than a few volts, your power supply is OK.
Next, you need to find the Sw-Inverter (5 wire cable to power supply) signal which comes from the main PCB. See if stays HIGH (5v or so).
Last thing... you need a tool... a cheap AC detector:
Samsung LNT4066F, backlight is out - a4296ee.jpg You need to see if the inverter transformer is staying ON:
f96899f.jpg Put the pen next to it and see if it still detect high voltage when the backlight shuts down.
If you have the 24v and it's good... and the ON line is good... and you have HV detection on the inverter transformer, you have a bad CCFL tube in the backlighting system. If this is the case, you would have to replace the panel. If the 24V line is bouncing around and dropping more than a few volts or your HV detection drops out, your power supply is bad. If the ON line is cutting out, you probably have a bad main board... inverters don't typically feedback errors to the main board. So if the main is shutting the ON line down, it's suspect. I hope this was helpful, best wishes.
Posted on Apr 27, 2010
  • 3 more comments
  • Adam Halfhill
    Adam Halfhill Apr 27, 2010
    If you need part numbers, supply the full model and version code from the side sticker (side of rear cover).
  • Adam Halfhill
    Adam Halfhill Apr 28, 2010
    The secondard supply that is feeding the transformer or the transformer has a problem. And with that said... replace the power board, PN: BN44-00167A. You should be set.
  • Adam Halfhill
    Glad to help, hit me with some thumbs :)
  • Adam Halfhill
    Adam Halfhill May 02, 2010
    Sorry, I thought we had it. This model and those of the same production year split the ballast up. Some of the function is on the power board (that transformer you checked with the ac detector) and the rest is on the ballast. Maybe the power supply is going into a current protection mode. The only real meat on that ballast board are the transformers that directly feed the lamps. Disconnect the ballast from the TV and do some measurements. Check the resistance (in circuit) of each transformers output terminals. You may be able to check this on the lamp connectors. See if 1 of them is different then the others. If they are all the same, you may have a CCFL lamp that is dead.
  • Adam Halfhill
    Adam Halfhill May 07, 2010
    The road has come to an end and there are no paths to follow short of changing the panel. To purchase a panel at this point would be borderline crazy. The best advise I can now give you is to call upon your favorite online auction site. Sell the TV part-by-part to maximize your return. Do yourself a favor and sell the LCD panel "as-is" and make a note that it has a bad lamp. Not sure if it will sell, but you never know. Include the Model and Version number of the TV when you list the part, along with the part number. Sell the Screen frame, Rear Cover, and especially the stand, people misplace those and often try to purchase them. Best of luck, I hope it all works out.
  • 10,594 Answers
Replace back light inverter board to get continue back light to view lcd screen image.
Back light inverter board turns off for some reason and no schematics are available to repair it on component level so have to replace complete board.
Check with local tv repair shops as they might have spare board for you.
Hope this info will help you.
Thanks.
Posted on Apr 26, 2010
  • 1 more comment
  • Shahid Electronics
    Shahid Electronics Apr 27, 2010
    Without schematics, troubleshoot is not possible and if you find out few defective parts, will not be available as individually because inverter boards are not suppose to be repaired on component level.
    OK, in low voltage cable/ connector, please check back light error signal, if that pin goes high that means inverter board generate that signal due to internal problem and this signal goes to main board (system control chip) to turn off back light inverter supply.
    It would be fine if you post here low voltage connector label/ names to point out back light error pin.
    Shahid Electronics May 01, 2010
    Hi again,
    thing.
    at vcc,
    the
    Thanks
    Please replace back light inverter board.
What causes my Samsung TV to turn on and off by it self
I was having problem with the TV freezing up vertical lines and shutting off then restarting and doing it all over again over and over and over , I realized that if I took the back off the TV I no longer had this problem?realizing that the processor was overheating...
I installed a tiny computer fan using the USB 5 volts as a power supply, this fix the problem. Good luck
Nov 20, 2015 | Samsung Televison & Video
Samsung 32'' LCD TV backlight works occasionally
Check for any loose soder points or loose connections with wiring sockets to backlight inverter board.
Apr 20, 2012 | Samsung LA32B450 32 in. TV
FLX3211b when plugged in the red power light comes. Then when the TV is turned the red light turns blue and stays on. The Element logo appears for a couple seconds then the screen goes black. There is a...
the transformer for the backlight is usually what fails on the elements especially if the logo comes up briefly then the screen goes out. I would check the transformers.
Apr 04, 2012 | Element Electronics FLX-3211B 32 in. LCD...
I have a samsung syncmaster 943NW which goes on for about 5 seconds and then just goes black. When restarting the screen it does the same again, goes on for about 5 seconds and then black. Is there...
I had the same problem with this monitor (Samsung 943nw)
When turned on it would only stay on for less then a full second.
When shining a light on the screen I could see what was on it, so it was just the backlight that was shutting down.
After I turned down the brightness of the monitor, the next time I powered on the screen the backlight stayed lit and it was back to normal.
Dec 11, 2010 | Samsung 943NW Monitor
Samsung 920nw Turns on, warms up then goes off.
Yes, it can be bad lamp assemblies (see my bad backlight album) due to poor soldering works or just worn out. You need a set of spare lamp assemblies to find out if it is the lamps or the inverter circuits, the inverter goes into shutdown mode if there are short circuits, or the lamps are drawing too much current, or the lamps do not conduct after firing voltage is applied to the lamps. You can also have open/shorts winding of the inverter transformers. One thing about the caps are that they can look OK but have high ESR. One experiment you can do is to heat up the caps using hair dryer for about 3~4 minutes then plug the monitor to the outlet and see if the lamps will stay on.
Here is the service manuals, at least you can take some voltage measurements.
http://elektrotanya.com/?q=showresult&megnev=samsung&megnev2=920nw&kategoria=&kat2=all
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 04, 2010 | Samsung SyncMaster 920NW Monitor
Screen goes black but still sound
This is inverter or backlighting problem. Can you try switching it on and off quickly for a couple of times and tell me if these '2 seconds' get any longer'. If picture stays longer and longer before shutting down, one lamp needs replaced-if not, please replace inverter board
Jan 15, 2010 | Goodmans GTVL19W17HDF 19 in. LCD TV
Screen goes black after about 10 minutes...POLAROID TLX-04240B
Simple Fix Repaire the backlight
repair man sure www.teexp.com
dont shoot the messanger!
Jun 13, 2009 | Insignia 42" LCD Flat-Panel HDTV
Flat screen monitor
Possibly a bad inverter that turns on the fluorescent backlight or a bad bulb.
Jan 17, 2009 | Envision EN-7100e 17" Flat Panel LCD...
Samsung LNT4066F 40 in. LCD Television Logo
529 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
