Question about Canon MultiPASS C555 InkJet Printer
Replaced Black Ink Cartridge reading empty
I got my sister's Multipass C555 after she passed away. I've been working to set it up all afternoon. I did not recieve the printer manual with it.
All the black ink cartridges were reading enpty, so used our refill kit and replaced it. The machine is still saing it is empty. Can you help please?
  • deslius Mar 29, 2008
    my machine will not copy it says that it is and will not, I have replaced the cartridges, cleaned and aligned the head, and still it will not print.
  • crazypj Jul 13, 2008
    There is no information on Canon site on aligning print head. I have changed cartridges 3 times (one is dried up, one set sitting in a drawer for about a year, still in foil packaging, unopened and third brand new)
    Bought de-natured alcohol to clean everything just in case ink had dried in somewhere
    Still have alarm flashing and 'put in cartridge' on display How do I align print head when it wont recognise cartridge is installed?
    Thanks
    PJ
What page would I find printhead alignment . I have replaced both color and Black/ White still is not printing.
Posted on Jun 20, 2008
  • 667 Answers
Do a printhead alignment. This will let the printer know your cartridges are full. Here is a link for your manual if you want one. If this doesn't fix the problem just add a coment and I'll be glad to come back and help you out. http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=8000
Posted on Mar 24, 2008
The black will not print.
You may need to buy black ink cartridge because it maybe empty anyway...buy new black ink cartridge and replace the old empty one
Sep 17, 2011 | Canon MultiPASS MP730 All-In-One InkJet...
Replaced ink and wrong catridge message comes up
What I would do is check your maunal to see what cartridge you need for your printer and purchase this cartridge. If you have not need color cartridges before than you wont need them now. Just make sure you inserted the right ink cartridge for your printer
Sep 24, 2009 | Canon MultiPASS MP700 All-In-One InkJet...
Canon multipass C555 will not recognize new cartridge
their may be dryed out ink in the jets. check for that.
Sep 10, 2009 | Canon MultiPASS C555 InkJet Printer
Shows black ink empty after new cartridge inserted
Replacing the cartridge should resolve this problem: Follow these steps to replace the cartridge:
Installing / Replacing the BJ Cartridge Follow this procedure to replace the BJ cartridge:
1. Make sure the MultiPASS is plugged in.
2. Open the document tray.
3. Lift the document guides to open the ADF (Automatic Document Feeder).
If the ADF (Automatic Document Feeder) does not open easily, slide the document guides outward and then open the ADF (Automatic Document Feeder).
Or slide the Document Feed Lever to either the automatic or manual setting.
4. Pressthingtopress.gif. If installing the BJ Cartridge for the first time, skip to step 6.
Caution: Do not try to manually move or stop the cartridge holder since this may damage the unit. Do not touch the components shown or any metal parts since this may adversely affect operation of the unit and/or affect print quality.
The MultiPASS has an automatic protection feature that helps keep it from overheating. If the cartridge holder does not move, unplug the MultiPASS and let it cool for several minutes. Then plug it in again.
Press thingtopress.gifto move the cartridge holder.
5. Raise the blue cartridge lock lever on the cartridge holder and remove the BJ cartridge.
Caution: Discard the old BJ cartridge immediately according to the local laws and regulations for disposal of consumables.You may want to place it in a plastic bag to keep any residual ink from spilling. Spilled ink can stain any surface; protect yourself and your work area. If removing a BJ cartridge to use one of the optional BJ cartridges, be sure to store the BJ cartridge in the container provided with your MultiPASS. Otherwise the ink will dry and affect print quality.
container.gif 6. Remove the new BJ cartridge from its package, then remove the orange protective cap (1) and tape (2).
Caution: Discard the cap and tape. Never attempt to reattach them to the BJ cartridge print head. Install the BJ cartridge immediately after removing the cap and tape. Spilled ink can stain any surface; protect yourself and your work area.
7. With the label facing outward, insert the BJ cartridge into the cartridge holder. Lower the blue cartridge lock lever until it locks into position.
lockinpos.gif 8. Press thingtopress.gif.
The cartridge holder moves to its home position on the right side of the unit and begins cleaning the BJ cartridge print head. This process takes about 55 seconds.
9. Close the ADF (Automatic Document Feeder).
10. Close the document tray.
Note: If you need to unplug the MultiPASS, wait until the unit is in standby mode (date and receive mode displayed in the LCD). Otherwise the cartridge holder may not be in its home position causing the BJ cartridge to remain uncapped and dry out.
Apr 11, 2009 | Canon MultiPASS C530 InkJet Printer
CANON C555 - Black & white only?
You could remove the color cartridge altogether, or just select "Print in grey scale" from the printer properties box.
Oct 04, 2008 | Canon MultiPASS C555 InkJet Printer
Black Ink Cartridge error
i ended up putting a color and black cartridge in and everything is fine.
Mar 27, 2008 | Lexmark X2500 All-In-One Printer
MultiPASS F60 Cartridge
"K" simply means black. Replace your black ink cartridge and it will be fine.
Mar 10, 2008 | Canon MultiPASS F60 All-In-One InkJet...
Color Ink Cartridge
the support of both the cartridges is required to get a printout in this printer so if it is showing empty get it refilled properly to start printing again or buy new one.
Feb 23, 2008 | Canon MultiPASS C555 InkJet Printer
Print quality is poor
if you replace the black ink cart with an original one then it's the print head
Solution: Cleaning the Print Head - C555 / C560 / C635 / C530 / C545
Untitled Document Follow this procedure to clean the BJ cartridge print head:
1. Press c755funckey.gif 2. Press c755cleankey.gif 3. Use c755down.gif or c755up.gif to select the [HEAD CLEANING]..
4. Press c755set.gif.
The MultiPASS cleans the print head.
Feb 12, 2008 | Cannon MULTIPASS C530 Printer
Canon MultiPASS C555 InkJet Printer Logo
85 people viewed this question
old marine
old marine
