Question about Oreck Sanapathic DMS2000 Handheld Steam Vacuum
I have the Oreck Sanapathic DMS2000 Handheld Steam Vacuum, but no steam comes out when I push the button. I hear the motor, is there any buttons I am missing or any help on how to make it work, been plugged in for 5 min now. Held button down for 2... nothing. Just a drip of water.
ORECK DMS2000 No Steam
First, tested tank and filter flow together using suction via
plastic tubing. Worked freely Second, removed pump
and disconnected hoses and terminals [watch location,
three terminals on pump, two plugs]. Pump has a slug inside
and I could blow water either way. Sucked white vinegar
both ways until check action returned. Use distilled water
in future!
Posted on May 04, 2010
Oreck steam cleaner, it doesn't give out steam
Use the tool that came with it to clean the nozzle where steam comes out. End nozzle also comes off so you can clean the larger hole with the other scrublike side of the tool.
Also, listen for steam assembly working, a low rumble like sound. If you do not hear it, it is broken and needs to be replaced.
Oct 07, 2016 | Oreck Vacuums
Oreck vacum steamer stopped steaming
Probable failure of the steam generator
Jun 03, 2014 | Oreck steam-it Stick Vacuum
Gets super hot but steam won't come out.
i have a simular steamer made by a different company. it used to work when i had first gotten it, but i think one time that i had plugged it in for a long period of time without using it has caused the plastic parts under the trigger that releases the steam flow to melt. so now the steamer that i have still heats up really hot but when i try to push the button it does nothing, no steam will come out of it at all... so i think my mistake was plugging it in without using it for too long, making it now inoperable basically garbage. sorry to say
Apr 17, 2014 | Scunci 52067 Handheld Steam Vacuum
Water heats up but no steam comes out
Make sure the nozzle where the steam comes out is not clogged. Minerals in tap water may clog it cause it's very small opening.
Sep 03, 2013 | Oreck Sanapathic DMS2000 Handheld Steam...
Parts
check heater coil & hand switch.
May 28, 2012 | Oreck Sanapathic DMS2000 Handheld Steam...
I got it and I cannot figure out how to work it because I did not get an owner's manual. I need one.
Hi Chat: Sorry it has taken so long to answer. Have had problems with my computer and have been travelling. I have been able to locate your manual and have temporarly posted it here.
Please let me know when you have downloaded.
Thank you for using FixYa!
Mar 05, 2012 | Oreck Sanapathic DMS2000 Handheld Steam...
Sanapathic
do you not have instruction book opration guide?? to make steam you req water then a method of heating it thus produce of steam results and pressure which expels via a nozzle ? just like the electri kettle
Oct 19, 2008 | Oreck Sanapathic DMS2000 Handheld Steam...
Heats up and produces steam but the release button does not open the flow of steam.
To remedy this, I did the following:
1) Removed screws from: a) Lower area of handle (1 screw), b) Top of steamer, under round rubber flap around fill hole (2 screws), c) Front of steamer where nozzles attach (2 screws)
2) Removed back of handle, top of steamer, front of steamer where nozzles attach
3) Once all parts are removed, you can see a brass button that is pushed by the trigger
4) Using a needle-nose pliers, grasp and rotate the button several times in both directions (you may hear it cranking against the interior spring). Do this until it turns fairly easily with the pliers.
5) Once this is done, you fill find that the brass button can be very slightly depressed with a bit of force. You may also need/want to unfold a large paper clip to push into the nozzle hole to help unsticking the brass button (not sure if that helped in my case, but it was something I tried along the way). When the brass button moves in and out (again, it won't move much), the steam release mechanism is unstuck!
6) Reassemble all parts (everything snaps back neatly into place).
This worked for my unit!
Nov 11, 2007 | Scunci 52067 Handheld Steam Vacuum
Oreck Sanapathic DMS2000 Handheld Steam Vacuum Logo
631 people viewed this question
Top Oreck Vacuums Experts
Kory Ronning
Randy Schumann
Randy Schumann
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
