Question about Bosch HGS435UC Gas Kitchen Range
Clock and lights work but cook top and oven do
Kenmore Model# 79095722990 - Clock and lights work but cook top and oven do nothing?
    President:
  • 949 Answers
The clock and the lights run off of 120 volts and the heating elements work off of 240 volts.
It would be safe to say that one leg of the power is missing. Try turning the circuit breaker off then back on fully.
If this does not solve the problem then you will need an electrician to check the plug behind the range or the 'L2' in the range.
Posted on Apr 26, 2010
Model # 79094320300 the clock and oven does not work on my Kenmove flattop stove, what can I do about it?
The clock runs on 110 volts and the oven at 220 volts. If the cook top is on, the issue is in the stove. Best left to a qualified technician.
If the cooktop is also not functioning, check the breaker.
Jun 19, 2014 | Kenmore 30 in. 42701 / 42702 / 42709...
Microwave just stopped working while in the middle of cooking. clock and inside light went black - nothing works!
You could have over heated the microwave or blown a fuse due to a problem in the door circuit. Either way this can be repaired with minimal parts. I would suspect you blow the fuse to the cabinet due to temperature where to high in the unit. I would need a model number to assist you further..
Good Luck
Aug 03, 2011 | Kenmore Microwave Ovens
Our Kenmore Microwave Oven # 721.89941490 does not respond when the "start" button on the touch pad is depressed. All other functions of the oven work normally, including time set, count down, light,...
poosible burned contacts on cook relay mounted on circuit board; or, a defective solder connection(s) on same board. another spot to check in the door microswitches.
Aug 30, 2010 | Microwave Ovens
Plugged in my Emerson MW7300W. Light works, won't cook
there is a thermal (white ceramic) fuse located right under the cover on the top of your microwave replace it.
an electronics part store should stock it.
Feb 01, 2010 | Emerson MW8777W Microwave Oven
I have an amana gas stove model ARG7800WW . The cook top works but the display (Clock Timer) doesn't light up and the oven doesn't work.
u need a new clock , or the oven wont work , u can bypass the clock to get the oven going but u need to know which two wire to join
Oct 27, 2009 | Amana ARGS7650SS Gas Kitchen Range
Power Failure results in no oven or digital display.
The low voltage has ruined the CCU (clock) YOu will need to replace it. You can order the part via model # on sears.com
Nov 02, 2008 | Kenmore 92002 / 92004 Kitchen Range
Kenmore Galaxy Microwave Hood Combo Model 72180002400
Do the inside light and turntable come on when you try to cook?
Is it making any unusual noise or is it louder or quieter than normal?
Do you have the model number?
Jul 29, 2008 | Kenmore 62622 Microwave Oven
Bosch HGS435UC Gas Kitchen Range Logo
143 people viewed this question
Top Bosch Kitchen Ranges Experts
William Miller
William Miller
ashburton
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
