Question about Dryers
Kenmore 80 series heats but then you hear a click and stops heating
  • 2 more comments
  • Marisamar711 Apr 26, 2010
    do I have to replace the whole motor or just the centrifugal switch? It is an electric dryer and sounds like it could be it. The click sound is coming from the bottom of the dryer. Am I safe to assume it is coming from the motor?
    Thanks. The model no. is 110.74842400 and the serial no. is MR 2805396
    Thanks, again. Yes, I just recalled it is a gas dryer. Will do. I live in San Diego, CA. Can you give me an estimate on both parts, just in case. I will listen again to see where the noise is coming from.
    Thanks, Phil. Awesome. Will do. I will let you know how it works out.
  • 10,319 Answers
Either the moister control sensor is weak or its good.
If good the vent is clogged up full of lint and needs to be torn apart and cleaned all the way out to the outside vent. The sensor will shut down any dryer that has a clogged vent. If the vent is clear the sensor is at fault then and needs a replacement
The sensor works as a saftey for fire hazzards as well as you can tell by know fron reading this information
Posted on Apr 26, 2010
    President:
  • 949 Answers
If it is a gas dryer it is most likely the gas valve coils. They can work for a while typically when cold, then break down and fail once they warm up.
The other thing that can do this is on gas or electric models is the centrifugal switch inside the motor. If the motor slows down after running for a bit it can turn off the heat.
The last thing that could cause it would be the high limit on electric dryers or the thermal fuse on a gas dryer. If the venting is plugged up with lint and no air is flowing or poor air to outside the heat builds up to fast in the dryer and it can trip the limit control off.
  • 1 more comment
  • Philip Apr 26, 2010
    That would be the most likely failure as the motor is down there, yes the motor would have to be replaced as it is what is slowing down causing the switch to open up. They are one piece and cannot be purchased separately. If you have your complete model number from the tag on the front just inside the door I can look up the part number for you and get you a ballpark price on a motor.
    This is the part number for the motor 279827
    I would suggest looking around the web for the best price. What part of the country are you in? I might know a good parts supplier.
    Now that I look at this model it is a gas dryer. Saying that I would suspect the coils again first. The coil part number is 279834 and they are much cheaper.
    The way you can tell is listen for the click or clunk, if it from the right side bottom it is the motor, if it is the left side is the coil.
    The gas valve coils should run about $20.00
    The motor should run about $110.00
    A reputable service company will charge about $110.00 labor to make either one of these repairs. I do not have any contacts down there to recommend but be sure to use new parts vs. rebuild and price shop.
    Let me know if I can be of further assistance.
    Phil
Kenmore series 80 heats and turns fine but stops after 30 minutes or so at any heat setting
Does it restart after it cools down? If so your motor may be overheating and shutting down.
Jun 20, 2012 | Kenmore series 70 80 90 Dryer Motor...
Where is the thermal fuse on a series 80 kenmore electric dryer. will this act as though the power is off? How can i test the fuse?
Yes, but there are several thermal limiters, they should reset when the unit cools, so likely that is not what is happening.... Forcefully turn the breaker FULLY off, and then back on, and test again...
The thermal limiters are located along the air flow path, typically downstream of your burner, the purpose is to prevent overheating and fire. These limiters stop the HEATING element and not the drum motor...
Feb 27, 2011 | Kenmore 63942 Dryer
My kenmore 80 series dryer wont heat up how do i fix it
could be the igniter or thermal fuse if you hear the gas valve click open and there is no glow inspect the igniter for a hot spot or white spot where the brek occured,some dryer will spin but not heat up if the thermal fuse is blown
Mar 20, 2010 | Dryers
Kenmore 80 series get very low heat
some of the 80 have two part element . one is burned out . or loke for a bad thermo. / hope this helps .
Nov 24, 2009 | Washing Machines
Kenmore 80 series runs but dont blow hot air
Check your heating element. #1 cause for no heat. Easy to replace and ea VERY easy to break. Just for your own well being also make sure that gas pressure us correct
Feb 12, 2009 | Kenmore Dryers
Where is the location of the heating element for a Kenmore 80 series dryer heavy duty model # 77834795
Dec 09, 2008 | Kenmore 63942 Dryer
Kenmore series 80 dryer not heating up
LOOK TO THE HEATING THERMOSTAT IT HAS A SAFETY AND IT SWITCH OFF YOU HAVE TO RESET IT
May 02, 2008 | Whirlpool LER5636P Electric Dryer
Kenmore series 80 Gas Dryer: No heat
ck the thermo fuse then ck the gas valve for power and the igniter to see if its broken probley igniter if you dont see a glow comeing from it
Mar 18, 2008 | Dryers
Dryers Logo
41 people viewed this question
Top Dryers Experts
