Question about RTO Atwood Water Heater - 6 Gal LP
Atwwod water heater 6 gallon changed thermostate made sure everything is lined up and cleaned out for spiders still will not stay lighted ticks lights then goes out 3 sec
  • RTO Master
  • 6,674 Answers
Try taking that little thermo cut-off out of the circuit. It's inside the plastic sleeve. Look close where it attaches, remove it, and connect wire to where it was connected and then try it. Also make sure electrode is clean and aligned to sense the flame from burner. Let me know.
Posted on Apr 26, 2010
Tip
Rv water heater gas not igniting!
Go outside to the access panel and open panel.check to see that burner tube does not have any spider webs blocking gas flow through the burner tube.You can clesn tube with air compressor our can air for cleaning computers and electronics.
on Oct 21, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
!990 Bounder By Fleetwood Water Heater is not lighting the propane
Check the gas line orifice for a spider web. Its possible the gas is not able to get past the web.
Nov 30, 2012 | Atwood Mobile Products Llc Water Heaters...
Rheem 22V50F1 pilot won't stay lit. Changed thermo couple & it lit, ran then went out. Let it sit overnight & it lit, ran then went out. What next? p.s. The unit is 5 years old. Thanks
If pilot lights and flame is robust and clear blue, and pilot goes out later, then some suspects can be excluded: air in gas line, low gas pressure, thermocouple is overtightened (finger-tight + 1/4 turn), thermocouple not positioned correctly in the flame, dirty pilot tube.
If flame is yellowish and small: then clean pilot tube and combustion parts.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean
Remaining suspects can include: air in gas line, low gas pressure, bad gas control valve, tight house so household vent fans pull air down water heater vent that blows out pilot, hot attic with inadequate ventilation, water dripping down vent.
Open following links to read troubleshoot resources.
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Aug 16, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
AFTER LIGHTING MY RICHMOND 6G40-36F1 WATER HEATER IT LIGHT FOR A FEW SECONDS AND THE FLAME AND THE PILOT LIGHT GOES OUT. WHAT CAUSE THIS TO HAPPEN?
There is air in the gas line. The best way to get the air out, is with the gas on, loosen the nut that attaches to the gas valve and make sure you can smell a little gas, then reattach the gas line, making sure everything is tight, and then relight the pilot making sure to hold the pilot light button down for at least 1 minute. Please rate
May 24, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Warm water, not hot , Atwood 6 gal.- burner , propane -ok
can you turn it up ... ? Maybe the burner needs cleaned ... might have spider web in the burner ... blow out with compressed air or canned air ...
May 02, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Atwwod 10 gal gas/elec water heater won't work on elec.
THE LIGHTED SWITCH SHOULD BE THE 12V ENERGY SOURCE TO ACTIVATE THE LP SIDE OF THE HEATER. THERE SHOULDN'T BE A LIGHTED SWITCH FOR THE 110 SIDE. THERE SHOULD BE A SWITCH OR A COMBINATION OF SWITCHES. ONE ON THE WALL LIKE A LIGHT SWITCH AND ONE MOUNTED BEHIND THE HEATER.
Jul 07, 2009 | RTO Atwood DSI-RV Water Heater-6 Gallon
Water heater locks out on my motorhome.
Try cleaning electrode and insure that it is in line to get heat from flame when burner ignites. That electrode is also a flame sensor. let me know if that helps. How long does it run when it does light?
Jul 04, 2009 | RTO Atwood DSI-RV Water Heater-6 Gallon
Heating element
Is the water gas or electric?It could be both.So if it gas then the burner is inside the front cover.If it's a electric one then it would have two wires coming out of it.
Apr 30, 2009 | RTO Atwood DSI-RV Water Heater-6 Gallon
RTO Atwood Water Heater - 6 Gal LP Logo
Top RTO Water Heaters Experts
Jim Goldsmith
Jim Goldsmith
Donni Steen
Are you a RTO Water Heater Expert? Answer questions, earn points and help others
