Question about KitchenAid KAWS850L Top Load Washer
Water leaking from the bottom of washer
How do you fix water leaking from washer from the bottom?
I had this problem the other week we turned the machine around and took off the water hose got to the water pump and found 5cents, hair pins, badges ect in there once cleaned out and put back together worked great again and no more leaks!
Posted on Apr 26, 2010
My equator clothes processor ez2500 is leaking water from the bottom..where can i get parts to fix it?
Please contact Appliance Desk or Equator to get Tech Support & Parts for your machine. their contact no is 713 464 3422 or 713 464 3858 Ext 186 / 175
Sep 23, 2012 | Equator EZ 3600 CEE Front Load Washer /...
Water wants to drain and keeps trying
Sounds like anti flood system has triggered (polystireen float and micro switch) that puts the washer in pump out mode only and shuts the inlet water off. You need to look at the bottom of the washer and check that water leak / spill is not causing the float to activate. Clear the water and fix leak (pipe or pipe clamp) and this should fix the problem.
May 18, 2010 | Bosch 23 in. SHU 8805 Built-in Dishwasher
It's leaking at bottom of washer, can I fix it?
It is very difficult for you to solve kindly call technician for solving the problem since the inner bearings and water seal is damaged
May 15, 2010 | Washing Machines
Water leak from bottom of Maytag Neptune washer
The water pump is cracke,. replace the water pump. Peter
Mar 18, 2009 | Maytag Neptune MAH5500B Front Load Washer
Water leak at front of washer
You should have a drain at the bottom of the rubber boot inside the washer. There is a possibility the drain hose clamp came loose or the boot has a hole in it. If you take the front of the washer cabinet off, you should be able to see where the water is coming from. Take the two screws out of either side of the door opening, pull on both sides of the front panel at the same time, tilt downward, and the panel should come off.
Jan 19, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer leaking
Check for cracks and corrosion on the outer tub. Water might be leaking from there. Please do comment. Good luck.
Jan 09, 2009 | Estate TAWX700JQ Top Load Washer
How can I fix my Kenmore portable washer 100.49722990?
Most common cause for water leak
is around the water level sensor connection, a small hose from the tank bottom rear, to the control panel, if loose or removed it is a small constant leak. if loose snip 1/8 inch off the hose refit and pull a zip tie around it tight
if it were the drain hose or pump, it would usually be a very large leak that increases when the pump is running and floods the laundry
Jun 21, 2008 | Kenmore 2.1 cu. ft. Portable Top Load...
KitchenAid KAWS850L Top Load Washer Logo
335 people viewed this question
Top KitchenAid Washing Machines Experts
kj henriksen
kj henriksen
gbob59
Mike
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
