Question about Sewing Machines
I cannot turn the clutch release on my 158 1040
I cannot turn the clutch release on my Kenmore 158 1040 sewing machine. Is there a way to unstick it?
  • 980 Answers
If you have the stop motion that turn and it is jammed the best way is to get a wide bladed screwdriver, as you are looking at the stop motion from the end of the machine put the screwdriver on the left hand side on one of the ridges if you have them and then give the screw driver a good thump and that will indo it, if you have a smooth stop motion then it is perseverence only.
Posted on Apr 26, 2010
Disengage clutch kenmore sewing machine
http://www.shopyourway.com/manuals/9253 is the manual. Turn the center of the handwheel knob toward to you to disengage the clutch.
Dec 26, 2013 | Kenmore Sewing Machines
Clutch won't release
the machine needs to be serviced by a sewing machine repair shop
Jan 25, 2012 | Kenmore Sewing Machines
My bobbin will not refill but motor is turning over fine. The machine sews well, too.
Do you have your thread wound around the guide the right way so that there is the proper tension? Do you also have your bobbin resting against the bobbin winder all of the way? Have you released the knob (clutch) to stop the needle bar from going up and down? If, all these things are correct and it still does not wind the bobbin, call Sears.
Sep 17, 2010 | Kenmore 15202 Mechanical Sewing Machine
On my Kenmore 15250 sewing machine to wind the bobbin I need to release the clutch by turning clutch knob towards me, so says the instructions booklet. But the clutch knob does not move apart from the...
On my Kenmore I had to pull the knob out to release the clutch, then push it bak in. I don't know if that is the same for you. You can try it, if it doesn;t move, it was worth a try. You could just take to Sears, sewing machine department and ask the salesperson what to do, they should help you for free, our Sears is pretty good about such matters.
Sep 13, 2010 | Kenmore 15208 Mechanical Sewing Machine
Clutch won't release.
This what you do, get a wide blade screwdriver, place the screwdriver blade on one of the slots or grooves on the stop motion wheel on the left hand side as you look at the machine from the end, the the top of the handle a good thump and you will find it will release, don't over tighten once you have freed it off.
May 28, 2009 | Kenmore Sewing Machines
To make bobbins the instructions say to release wheel (flywheel) and turn knob inside to release clutch. The two wheel seem stuck
H there,
Initially, Turn power off and wait about 20 minutes. Safety device will reset, and machine will be ready to operate.
Let me know
May 07, 2009 | Kenmore Sewing Machines
Can't tighten clutch on Kenmore zig zag sewing machine.
The clutch has fallen off the shaft. Remove the very small screw in the clutch release screw to remove the clutch release. Place the clutch(round thing with ears on it) back on the shaft with the center ears pointing towards the outside. Put the clutch release screw back on. Tighten it to make sure it works
properly. Put the small screw back in the clutch release screw and test it again. If it will not tighten or release properly, remove the clutch ,rotate it180 degrees and try it again.This should solve your problem.
sewman7
Feb 14, 2009 | Kenmore 15516 Mechanical Sewing Machine
Kenmore 15516 bobbin
1. Remove the bobbin case
2. Release the clutch by pulling out the handwheel
3. Draw the thread from the spool andguide the thread throught the hole in the bobbin from the inside to the outside
4. Put the bobbin on the bobbin spindle
5. Push the bobbin to the right
6. Hold the free end of the thread and depress the foot control, wind until full
7. Push the handwheel in (to wngage the clutch)
8. Push the bobbin spindle back tot he left to resume sewing mode.
9. Place the bobbin in the bobbin case (thread should feed clockwise)
10. Draw the thread through the slot in the bobbin case
11. Continue to draw the thread under the tension spring and through the opening Pull out about 4"' of thread
12. Holding the latch open position the bobbin case into the shuttle and release the latch
13. Case should lock into place when released
Hope this helps!
Bonnie
Sep 27, 2008 | Kenmore 15516 Mechanical Sewing Machine
Kenmore Sewing Machine model # c877.15
I have a Kenmore as well ,I hope that this will work for you ,too bad that I don't live close to you otherwise I would give a hand. This is the way I fill the bobbin on mine. Mine is located on the top right ,I put the thread into the bobbin hole leaving a small piece of thread hanging for me to hold when I begin the winding, I pull the wheele out to stop the needle from moving while winding, when I am done just push it back in .I run the thread from the spool into the top left it looks like a U turn with a screw go around that without winding just pull it into the bobbin hole. press the foot control and it will begin winding .
Jul 17, 2007 | Kenmore 15208 Mechanical Sewing Machine
Sewing Machines Logo
219 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
