Question about Fisher Paykel Eco IWL16
Error code 43 on F& P washing machine
We have error code 43 on F &P washing machine - does anyone know how o fix this? Thanks
  • Anonymous Mar 25, 2014
    I am looking for the manual to a Lenco lwm4501v washing machine, and can't seem to find it anywhere. I need to machine wash a blanket with a high-sentimental value, and don't want to ruin it. the blanket calls for a cold wash and I don't know how to set it up on the machine I have.
    If anyone knows where I can get the manual, or how to set up a cold wash on said lenco machine, I would love to hear about it. Thanks :)
The micro switch or the lever that activates it seems to have been the cause of the Error Code 43. Have re-seated the switch in its holder and ensured the activating (out of balance) lever is moving freely. The switch appears to be OK and now it is all re-assembled, the Error Code 43 is gone. Machine is operating normally again.
Out of Balance Switch was located below the right hand side of the computer board (module).
Rgdz John T
Posted on Sep 20, 2008
F & P Intuitive Eco Washing Machine Code 43. I followed the instructions from of an entry on this site to look at the out-of-balance switch behind the computer board. (I can't find this advice again to add my findings.) One of the two connection points into the switch was badly corroded. I cleaned the terminal with an automotive points file then sprayed both parts of the connection with WD40.
The machine is now working OK and the code 43 message has gone.
Posted on Feb 22, 2009
The out of balance switch is playing up which is located under the right hand side of the computer board. This can be bypassed by joining the two wires togeather which will get it going straight away without swapping parts, but it will not stop when out of balance so you will have to manually stop it after that. Best solution is to replace the micro switch.
Posted on Apr 05, 2008
Who can replace micro switch and how much it cost?
Posted on May 14, 2008
2 Suggested Answers
SOURCE:
  • 3 Answers
SOURCE: error code 43 on F& P washing machine
Carefully remove control console, then control board. Take note of which connector came from which terminal! Balance sensor is located under control board. Remove with care. Check that little button (size of pen top or pencil lead) is moving in & out freely. It is spring loaded. If it sticks, replace it. Hope this helps.
Posted on Jun 17, 2008
Wme8227s. What does code E18 indicate?
Beko Washing Machine ' WMA Series ' Error Codes
www.ukwhitegoods.co.uk/.../fault-codes/...fault-codes/3623-beko-wma-...
Feb 6, 2013 - ... Fault Codes. Beko WMA Washing Machines With Display ... BekoWMA Series Washing Machine Fault Codes. These fault codes are ... E18 ...
UK Whitegoods • View topic - Beko WME7247W showing error code e18 ...
www.ukwhitegoods.co.uk/.../washing-machine.../beko-wme7247w-show...
Jun 19, 2011 - Hi, does anyone know what error code e18 is on a beko wme7247wwashing machine? thanks. User avatar louisebaxter: Whitegoods Newbie Beko wme7247w dc module burnt out
Apr 27, 2014
Bosch WAS24460GB showing error F:57
Sep 28, 2013
beko washer error code
Aug 18, 2012
Samsung B1415J showing error code EA ...
Jan 9, 2012
More results from www.ukwhitegoods.co.uk
Oct 30, 2015 | Beko Washing Machines
Siemens WM16S794GB F 43 fault
Try the following, it's the procedure to erase the stored errors.
Turn the knob to off.
Close the door.
Turn the knob to 6 o'clock position.
Wait 2 seconds.
The start/pause should begin flashing.
(If the start button doesn't flash, just carry on trying to erase the codes).
Press and hold the spin button. (it may be marked RPM)
Turn the knob to 7 o'clock position.
Wait 2 seconds.
Release the button.
Hope this helps
Thanks
Jun 02, 2014 | Washing Machines
My washing machine keeps displaying error code F17 and won't go on. Does anyone know what this means and what I can do to fix it?
F17 indicates no water coming into the condensing chamber during drying.
Unplug the appliance.
Take the top off.
Check to see if the condensing chamber below the heating chamber is blocked.
Oct 15, 2012 | Siemens Washing Machines
My F&P washing machine is displaying code 43
Fault Code 43 is out of balance switch.
The out of balance micro switch under the brown motor controller board is corroded and needs replacing.
Aug 02, 2012 | Fisher and Paykel Washing Machines
Error code 43 on intuitive top loader
hello click this link for error code 43 this is an out of balace error and this link will tell how to fix as well http://applianceguru.com/forum2/3397.html if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations Thanks Rick
Mar 01, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
Please I have got error code H 43 on display monitor of Panasonic washing machine model NA-14VX1, If you please may I know what is meaning this code and where is the problem. Thanks in Advance
This is a code for an internal leak. Same happened to us today 2 weeks after buying the machine from John Lewis. We had a small pool of water appear in front of trhe machine. Waiting for Panasonic to sort out a repair.
Feb 05, 2011 | Washing Machines
FP fault 43
code 43 is an out of balance switch problem.Once replaced, would fix the issue.
One trick that might work ;-
I unscrewed top cover, then unscrewed and lifted up the grey computer cover. The balance switch is underneath on the right with a yellow and white wire coming off.
I removed switch from clip and then removed the wires/clips from contacts. There was definitely corrosion on the contacts. I soaked switch overnight in vinegar. Then rinsed with water. Then dried switch out for day.
Put it all back together and am now on second load of washing.
Thanks.
Jul 01, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Jun 02, 2008 | Fisher and Paykel GWL11 Top Load Washer
Intuitive washer code 43
Thx to fixya l sovled my code 43 by removing and cleaning my balance control switch. If anyone needs to know here step by step
1 Make sure the plug is out ( dont want curly hair do you )
2 Remove 2 screws from back of control panel and lift off
3 Remove 1 screw holding grey module panel
4 Under grey module on right hand side is the balance control switch with 1 white and 1 yellow set of wires
5 remove wires ( make note on where they plug back into )
6 2 small clips hold the switch in place, open them gently and pull switch out
Its that simple , clean the contacts with some wd40 or bicarb soda in hot water to get rid of any corrosion, make sure that the little button on the side springs out freely ( tiny drop of oil/wd40 ) clean or replace plugs on the white / yellow wires. install and do that washing!!! It worked for me but if the switch is too far gone no need for a service man just get a new one and go for it .
Good luck Pieman
Oct 06, 2006 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher Paykel Eco IWL16 Logo
4,905 people viewed this question
Top Fisher Washing Machines Experts
Mike
Gerry Harvey
Gerry Harvey
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
