Question about RIM BlackBerry Storm 9530 Smartphone
I hav the jvm error on a verizon phone which i want to unlock and the JL_Cmder is not appearing on my computer how can i get this straight?
Will unlocking my verizon bb 8330 with jvm error 102 fix this phone
codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Jul 27, 2012 | RIM BlackBerry? Curve 8330 Cellular Phone
App error523
App Error 523 is a software hiccup usually caused by a 3rd-party application that is not compatible with the BlackBerry device OS.
Follow the below steps to get rid of this error message:
1. Take the battery out and put it back in after 30 seconds or so
2. While the device is rebooting (or while the hourglass is still spinning), plug it into the PC
3. Then open the application loader and remove the 3rd-party application that's causing the issue
4. Worst-case is when you need to wipe the device using JL_Cmder. Follow the instructions here: How do I wipe the BlackBerry using Jl Cmder?
Dec 03, 2010 | RIM BlackBerry Bold 9700 Smartphone
My blackberry pearl keeps giving me the jvm error 102 and won't reset. How do I fix this?
You can fix this by hooking up to computer and reloading the software using the BB desktop manager software, will usually also auto backup your data before it writes software.
Jul 01, 2010 | Verizon Communications BlackBerry Pearl...
JVM error 517
the JMV 517 error code is as a result of software corruption. One way or the other, your Blackberry's operating system file has be corrupt.
Your Blackberry OS needs to be reinstalled in order for the problem to be solved. You will need Blackberry Desktop Manager installed on a computer, download the latest device software from your carrier website and perform a clean reload of the device software. Below is a link that will guide you on how to do the clean reload :
http://www.blackberry.com/btsc/microsites/search.do?cmd=displayKC&docType=kc&externalId=KB11320&sliceId=1&docTypeID=DT_SUPPORTISSUE_1_1&dialogID=355444498&stateId=0%200%20355434510
Once the link is opened, scroll scroll down the page to be able to read information.
Note that due to the JVM error(s) , unless you have done a backup of your personal data of have contacts on a SIM card, you WILL LOOSE all personal data on the device.
If your Desktop Manager can't recognise your device, you will need to contact your Carrier and have a Technical Support Agent assist you.
Good luck.
Apr 20, 2010 | RIM BlackBerry Bold 9700 Smartphone
How do i reset my blackberry with JVM Error 513 code
Plug it into the computer open desktop manager and click application loader then click update software.
you may need to wipe the phone using jl commander first if it does not recognize the usb connection. JL commander is free just google it and extremely easy to use.
Feb 21, 2010 | AT&T Blackberry Curve 8300 Smartphone
White screen on my blackberry curve that's reading jvm error 547 flash write failed what does that mean
That you will probably need to reinstall the OS. Try doing this through the Desktop Mnager. If it works great. If not then you will need to wipe your phone (try using JL Cmndr) and the reinstall the OS.
Dec 09, 2009 | RIM BlackBerry Pearl 8100
Reload error:507 curve 8900
well you have done great so far. Error 507 means that JL-CMDER has done its job and wiped all applications off your phone. So just do the next step by connecting it to your 4.7 Blackberry Desktop and select App Loader and install the OS and Applications on the phone. Please write again if you need more help
Jun 20, 2009 | RIM BlackBerry 7290
Jvm error 547 blackberry 8320
try running app loader again but before you connect your phone up to the computer pull the battery out, then connect the phone, then put the battery back in. A lot of times it will force the connection to get established and then you should be able to run app loader.
Nov 16, 2008 | RIM BlackBerry Pearl 8100
RIM BlackBerry Storm 9530 Smartphone Logo
62 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
