Question about Liquid Video A170E101 Monitor
My liquid video a170e101 appears to have a blue green hue so i would assume that the red is malfunctioning is there a way to fix it change a chip etc. a schematic would be cool as well if some has it
    Sergeant:
  • 279 Answers
First of all ensure that it's not the the monitor cable (to PC) that causing that problem. If the Red/ Green/Blue data cable (inside the bundle of the monitor cable) or one of them not connected (due to too much bending) can make the monitor displayed improperly
Posted on Apr 26, 2010
The picture has hues orf red and appears dark in night shots.
Please do us a favor and rate this solution after reading.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 16, 2011 | Hitachi 53UDX10B 53" Rear Projection...
I need drivers for the liquid video A170E101 monitor for Windows XP
Here is the website to click onto which you can download the needed driver below
Thanks for the 4 thumbs up in advance too
http://www.driverstart.com/start545058.html
Aug 08, 2010 | Liquid Video A170E101 Monitor
Where are the convergence chips located on my 60PP9202 for the red
There are 2 Convergence Chips: 1 for Horizontal (it includes Red, Green and Blue Convergence channels) and 1 for Vertical (it includes Red, Green and Blue Convergence channels). Horizontal Convergence Chip is 7044 and Vertical convergence Chip is 7045 (both STK392-120). They are fixed in same "big" Heat Sink, with a 2 metal black clips, from Video Inputs board side.
Oct 19, 2009 | Philips 60PP9202 60" Rear Projection...
The screen on my windows xp media center changed colors out of no where..red is black, blue is still blue but every othe ris color is green..how do i fix it..i already rebooted it and everything but dis...
Oh!!! no!!! ITS not the video card or what so ever rebooting will fix this problem.... its the monitor..... it is waht they called virtual chip inside the monitor that is malfunctioning, I already experience this problem.... and i will suggest that if your using basic monitor, which to an LCD monitor, its better.
Oct 12, 2009 | Microsoft Windows XP Media Center Edition...
Some times the picture gets a green and red hue and the menu turns from green to red ,
HI. this is being caused by a faulty convergence chip that is located on the convergence board. simply replacing this chip or replacing the entire board will fix this issue.
May 21, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Green and pink shadow on my samsung 55in proj tv what can i do to fix it. i all ready fixed red and blue line but green is way off and i dont see any way to fix it
hi, this is the early signs of convergence board chip failure. you will need to replace this board in order to correct the collaboration feature. the convergence is responsible for regulating the RGB stream in you set. if it is malfunctioning, you will not be able to regulate the red blue green streams.
May 16, 2009 | Samsung HCL5515W 55" Rear Projection...
ALOT OF BLUE ON THE SCREEN!!
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Aug 20, 2008 | Philips 60PP9200D Television
Yellow hue
1)Please verify your model # from back of set......
2)Reduce the color to minimum or tune in a black & white chan.
you should see gray, not yellow hue
3)Remove lower front grill cover & access panel.....locate the
focus / screen control block...turn blue screen control slightly
CW......red,green and blue must mix to equal gray
4) reset color to normal level.......reassemble
Dec 22, 2007 | Toshiba 57H82 57" Rear Projection...
Liquid Video A170E101 Monitor Logo
105 people viewed this question
Top Liquid Video Computers & Internet Experts
Marcin
Are you a Liquid Video Computer and Internet Expert? Answer questions, earn points and help others
