The paper goes through my pinter as if is printing when the paper is fed out there is no print on it
    President:
  • 1,194 Answers
Thanks for using Fixya.
The possible solutions for your problem are:-
(i) Check the ink levels
Some products continue to print even after the cartridges are completely out of ink.
Click the Windows icon< Hardware and Sounds< Printers<Right-click the icon for the product<Properties<Click Printing Preferences<Click the Features tab< Printer Services button. The Toolbox window opens.
Click the Estimated Ink Levels tab.
If the ink level indicators show that a cartridge is empty, replace the cartridge.
(ii) Restart the printer
(iii) Restart the computer
(iv) Check the printer cables
(v) Make sure the computer has adequate free hard drive space.Printing requires a certain amount of free hard drive space to process print jobs and send them to the product.
(vi) Check the printer settings on the computer.
If these steps do not solve your problem, then revert back with your Printer model.
Good Luck and have a nice day.
Posted on Apr 26, 2010
HP designjet 130NR won't pick up paper from the tray.
paper tray lift clutch failure is likely the cause - common for this machine - repair with new feeder assy ordered whole from HP/ or Partsurfer
Jan 28, 2014 | HP DesignJet 130NR InkJet Printer
Paper Jam in Duplex mode when printing more than 1 sheet
check between the rollers there will be small bits of paper jammed in that is the reason.
Sep 09, 2008 | Minolta magicolor 2350 Laser Printer
When i go to print a doucument, the paper goes in at an angle
take the paper out and try to print something, but look down in where the paper is fed into the printer. Make sure all the wheels are spinning. If they aren't, then thats your problem. If they are working, then make sure nothing is blocking the one side of the paper.
Mar 08, 2011 | Canon Office Equipment & Supplies
I have a Dell V313w. I am running off of Windows 7. When I go to print a job, it will shoot a blank page through the pinter before it begins to print the job. How can I ge that to stop?
Ensure you installed the correct driver.
The paper size in the tray is not the same you are sending for printing. Maybe the paper size the printer recognizes is smaller than you sent to print.
Thanks
Dec 11, 2010 | Dell V313w AllInOne InkJet Printer
C4680 All-In-One Inkjet Printer: paper won't fed and nothing prints...
Hi, i dont know you've got the same problem as i did. But i tell you how i fixed my problem. My printer said i ran out of paper, but there's plenty of paper where it should be. What i did to fix it was that i pulled some paper (remove the gray back plastic, turn pinter around, you can see the rubber rollers now) futher out and then placed the gray plastic back. Put the printer off and on the paper comes out. Then again off and on, then go rpint of copy something and it works again. I hope you it does the trick for your problem.
May 16, 2010 | HP C4680 All-In-One Inkjet Printer
Printer does not attempt to pick up paper but gives out of paper message and or flashing paper sign on panel
steps:
(a) driving a pickup roller, picking up printing paper stacked in a paper cassette, and then, feeding the picked up printing paper to an image forming unit
(b) after picking up the printing paper in step (a), checking to determine whether or not the printing paper has been fed to the image forming unit(c) when it has been determined in step (b) that the printing paper has not been fed and a paper feed error has been generated, again driving the pickup roller, so as to attempt to pick up the printing paper stacked in the paper cassette again.
Apr 21, 2010 | HP Officejet Pro K5400 All-In-One InkJet...
Printer is not feeding the paper through but acts as though it is printing
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prirweto-i-7
Apr 20, 2009 | Canon PIXMA MP160 All-In-One InkJet...
R265 chewing paper
Suggest a small piece of paper or dirt is stuck in the print path near the print heads. Use vacuum tube to **** out any dirt
Mar 19, 2008 | Epson Stylus R265 InkJet Photo Printer
Paper will not feed
These are basically throw away printers. But you might try checking the paper path. There are small plastic "arms" that guide the paper as its picked up and goes throught he printer. Sometimes one of these may get stuck in a position that makes the printer think there is paper in the path somewhere.
Mar 19, 2007 | Apple Epson Stylus Color 777i InkJet...
jasbo
jasbo
