Question about Aqua Eco Plus 1056 Submersible Pump Hydroponics riums
I cannot get any ecoplus submersible pump to work inline!! Whenever I hook it up to hose it stops pumping. Can you help?
  • 990 Answers
It may be colapsing the hose and you may have to hard plumb the suction so it can get water.
Posted on Apr 26, 2010
Well water pump won't stop running
if it is a submersible well pump it could be crack in your line leading to the bottom of your commercial welcome and called it to leak water and still feel pressured
if it is a submersible well pump it could have a crack in the line leading to the summer double well pump in the ground it will cause it to leak but the tank will still be build up pressure
Jan 10, 2015 | Pentair Water 123324 1hp Submersible Well...
I have a Little Giant 6CIA submersible pump for about 3 years now, used once an in a trap in the basement waiting for a flood. Tried to test it today submersed and it would not work, banged it around a...
This pump works off of a pressure switch. You can remove the cover on the switch located on the side of the pump.You can either buy a switch repair kit, or you can open it up and take a look and see if the diaphragm is sticking. If you remove and clean the parts, you may have some success. Or, just buy the switch repair kit from your local Little Giant dealer. Good luck!
May 02, 2017 | Little Giant 6 Cia, 1/3 Hp, 45 Gpm, 230V...
Hubby installed new pump and it shortcycled for awhile then, no psi... not even sure about the condition of the pressure tank ... when water does come it works for a short time and then trickles and stops...
Did he install a self-priming pump, sometimes the will not prime or this one is stopped up from dirt. also is it submersed in the water or above water level. if it is submersed and is not meant to be, it's probably toast and you need to replace it with a submersible type pump that is also self priming. To find the schematic for your system go to your manufacturer, I'm now assuming that this is a recreation type situation, trailer, motorhome. There at the dealer the parta department should be able to help you. Hope I helped.
Oct 06, 2010 | Flotec Corrosion Resistant Shallow Well...
What wires go to 3 prog plug
THE CENTER ONE IS GROUND , DON'T WORRY YA CAN'T HURT IT IF YA HOOK IT UP WRONG AND IF IT DOES THE MOTOR IS SHORTED AND IT WAS JUNK IN THE FIRST PLACE.. THESE ARE A CHEAP PUMP AND NOT REALLY WORTH FIX'N .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
May 23, 2010 | Flotec 3.4 Hp Floodmate Submersible Sump...
My Flotec pump runs 5 seconds shuts off for 30
fully submerse pump in bucket of water, tilt to get all air bubles out,(keep hose off) plug in and it should work fine
Dec 02, 2009 | Flotec 1/6 Hp 1260 Gph Utility Submersible...
Ecoplus 230 surface pump plugged. Is there a filter or debris screen to clean? pump is primed. runs without excess noise. no water out the outlet port
Hi ! Nothing to clean on this, just make it pump some hydroponics cleaning pump products with distilled water to remove the deposit without taking risk to damage your system/plants. Thanks and have a nice day J -
Oct 24, 2009 | National EcoPlus 100 GPH Submersible Water...
Pond pump types
There are basically two types of pond pumps to choose from - externally mounted and submersible. External pumps were traditionally used in water gardens. They sit outside the pond, with a hose that leads from a strainer in the pond to the pump. From there the water is forced either to a waterfall, stream or fountain. Because external pond pumps are often noisy and require extra plumbing, they are usually not suited for most backyard ponds. Due to easier accessibility and ease of repair, however, external water pumps are often the best choice for larger water gardens and public installations. Submersible water pumps are usually preferred by most do-it-yourselfers. They sit underwater where they are quiet and unseen. These pumps are easy to install, require no priming and stay cool thanks to the surrounding water. Submersible pumps draw water from the bottom of the pond, either through a strainer or biological filter. A hose attached to the outlet then feeds water to whichever water feature you have installed.
Aug 27, 2008 | Little Giant Opwg 71 71 Gpm Out of Pond...
Aqua Eco Plus 1056 Submersible Pump Hydroponics riums Logo
121 people viewed this question
Top Aqua Garden Experts
ray gallant
gbob59
Tom Chichester
Are you an Aqua Garden Expert? Answer questions, earn points and help others
